R50/53 Dead battery, trunk locked. Now what?
Old Sep 26, 2009 | 10:07 PM
StorminNorm's Avatar
StorminNorm
Ordered an Optima R34, should be here in a week but for now, how do I get the trunk opened to get to the battery? Build date was 7-02 or earlier so no trunk release under the seat - I havent looked but from what I read, it wont be there.
Am I going to have to crawl my 6'3" 270 lb butt through the back seat to change the battery?
Old Sep 26, 2009 | 10:30 PM
rkw's Avatar
rkw
There is a tailgate release cable. Lift up the rear seat bottom and you should see a pull ring. It is described in the Owner's Manual.
Old Sep 26, 2009 | 10:39 PM
JAB 67's Avatar
JAB 67
His was early build date, so probably no release cable . . .
Old Sep 27, 2009 | 12:22 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
No release cable on mine either. You'll have to get someone into the back seat, fold up and reach under the cargo cover to fold down the seat and get to the battery that way. I'd imagine that once you had the seats down, you can fold the carpet over them and set the new battery next to the old, leaving it in place. Then you can just undo the cable and connect it to the new, just to get the trunk open so you can make the switch from outside.
Old Sep 27, 2009 | 12:37 AM
Eric_Rowland's Avatar
Eric_Rowland
Alternatively, jump it from the positive terminal under the bonnet (next to the airbox.) Much easier than getting 6'3" back there, or renting a small friend...
Old Sep 27, 2009 | 12:39 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
That's not as fun.
Old Sep 27, 2009 | 03:58 AM
veggivet's Avatar
veggivet
Nope, not as much 'fun', but that's what I did when my battery died during winter storage, despite being on a trickle charger.
Old Sep 27, 2009 | 04:02 AM
moreorless's Avatar
moreorless
That's how we did it on my old May 2002 build MCS. I just recently put an Optima Red Top in my '06.
Old Sep 27, 2009 | 05:48 AM
DOT191's Avatar
DOT191
Our 2003 Mini has the trunk release under the back seat
Old Sep 27, 2009 | 06:08 AM
NightFlyR's Avatar
NightFlyR
There is also a small battery with a connection you can buyat the Autoparts store it plugs into the cigarette lighter plug and that will put enough power to open the trunk
Old Sep 27, 2009 | 09:57 AM
rkw's Avatar
rkw
Have you verified that it works on a MINI? From the wiring diagrams, it isn't clear that it would do anything. The key would have to be in On position and a relay triggered before it would be able to feed any power into the system.
Old Sep 28, 2009 | 08:01 AM
Bigshot's Avatar
Bigshot
Yea......just connect the new battery to the jump leads and open the hatch.
OutMotoring
Mar 3, 2017 06:29 AM
schr5530
Oct 5, 2015 08:28 AM
schr5530
Oct 1, 2015 05:11 PM
dutchhome
Sep 30, 2015 07:17 AM
jennster
Sep 28, 2015 06:19 PM
