R50/53 Clutch Question
Old Jul 1, 2008 | 07:23 PM
Rascasse's Avatar
Rascasse
Clutch Question
I tried the search and couldn't find an answer, so here goes....
I just replaced the clutch slave cylinder as it was leaking and there was no pedal.
It was a piece of cake to replace. I believe that we bled it completely, but the clutch disengages much farther in the throw of the pedal than before.
Is there an adjustment, or do I still need to further bleed the clutch?
Thanks......
Old Jul 1, 2008 | 07:31 PM
guidmini's Avatar
guidmini
bleed me baby
Dino its a nightmare to bleed. You need to have a power bleeder 1st of all
2nd. there is a special tool. With out that tool its kind of a pain. What that
tool does it compresses the piston all the way in.Keeps it there,then you open the bleeder,till no more bubbles. Then you close the bleeder,this tool then backs off the piston to the full travel,then youcompress it all the way in
then you open bleeder. You repat this about 4-5 times. Then you release the tool. Bolt it back up. And check pedal travel. If the pedal is still on the
down side, Guess what more fricken Air. I hate these thing and I work on Mini's all day long.
Ciao Guido
Old Jul 1, 2008 | 09:27 PM
Rascasse's Avatar
Rascasse
Ciao Guido
Guido:
Thanks allot! I have a power bleeder, but the buddy that helped me doesn't like using them (I think they are brilliant). Anyway..... this tool, I am assuming is holding the piston in the slave, in the opposite direction from arm that the slave is actuating. Is that correct?
Where do I get this tool? Do I need to know a special handshake? :D Heaven knows I enough I enough 'special' Ferrari tools. Or should I say 'specialle'! Why not add some MINI ones to the mix! I have yet to figure out why I like doing this stuff!
Old Jul 1, 2008 | 09:46 PM
Xymox's Avatar
Xymox
Dean, is your father Tony Soprano?
Old Jul 2, 2008 | 04:01 PM
Rascasse's Avatar
Rascasse
What is that supposed to mean?
Old Jul 2, 2008 | 05:04 PM
jhiggs26's Avatar
jhiggs26
See these threads for slave cylinder special tools and tips.
https://www.northamericanmotoring.co...d.php?t=132378
https://www.northamericanmotoring.co...d.php?t=131915
See Post # 77 for pics: https://www.northamericanmotoring.co...t=obx+atb+diff
Jeremy
Old Jul 2, 2008 | 05:20 PM
Rascasse's Avatar
Rascasse
Originally Posted by jhiggs26
Thanks. The pictures help. Since I already have the slave mounted, can you tell me the distance between the 2 holes on that block?
Old Jul 3, 2008 | 09:43 AM
AliceCooperWA's Avatar
AliceCooperWA
I wish I could help with the distance, but I can't. It is however much easier to bleed with the slave disconnected. I know there are like 10,000 threads on those bolts, but if you remove it, you can hold it with the bleed valve pointing up with the piston compressed. Then attach a suction source ( power suction bleeder, or topside oil changer) and it will take you all of 30 seconds to bleed! I kicked myself in the *** when I spent hours trying to pump the pedal and move fluid, then I realized I could use a dipstick oil changer, and I bled it in less than 30 seconds.
Old Jul 3, 2008 | 04:28 PM
jhiggs26's Avatar
jhiggs26
From my post #77: chunk of wood with 2.5" centered 5/16" holed, and a few strikes on the wood with a ball pean hammer(centers the slave pushrod on wood).
I left the slave unbolted and just watched when the bubbles stopped going into the catch can fluid.
Jeremy
Old Jul 4, 2008 | 03:24 PM
Rascasse's Avatar
Rascasse
Mission Accomplished!
I don't think that could have been a bigger pain! I ccan't believe that compressing that piston with a block of wood made a difference..... but that was the ticket. Ahhhhhh, the joys of British motoring.
From what gathered from AliceCooperWA, he compressed that thing by hand. God Bless you. You must be strong like bull!
Thanks guys. Hopefully this MCS will be easier to work on than my old MGB! ..... and less frequent!
andrewjg1994
Jan 29, 2021 07:45 PM
eliseo1981
Jan 28, 2021 02:45 PM
Sep 17, 2015 09:27 AM
Camaro108
Aug 25, 2015 02:44 PM
DiGiPiMP
Aug 24, 2015 11:04 AM
