Navigation & Audio Show Your iPod Installation
Hey guys!
Harman Kardon announced an update to its Drive+Play. It is now with color display and wireless controller. There are no detailes yet, but you can check it out HERE.
Alpine also came up with a cool looking in-car iPod solution. They don't mention though, if it is possible to change the illumination color. Everything else looks very good. You can find general info HERE.
According to Harman, “Drive + Play 2 is easily installed in any make and model automobile using an auxiliary line connection, hardwired FM connection or included wireless FM transmitter,” with the wireless FM transmitter and 3.5mm cable-based audio hub included in the core package. Hardwired connections will require additional installation expertise, but be aided by an included hard-wire harness capable of concealing the hub and cables. It will be priced at $400 - twice the cost of its predecessor - and is planned for Spring 2007 availability.
I want an aftermarket CD as I have an outboard amp to use and want to avoid a LOC. Any suggestions for red/amber display, steering wheel integration and most importantly, competent iPod control for a 5G 30gb model?
http://www.nakamichi.com/flash.html
This is what I did for the iPod install - been working very well ever since.
http://www.murmini.com/articles/2006...alling-an-ipod
Nakamichi make a quality product that has the closest look to the stock mini unit.
I'm perfectly happy with my Drive + Play. Don't necessarily want the $400 unit blaring through my windscreen, "Break in & take me!" I'll wait until the price drops to under $200, then we'll see if I think I just hafta have it.
It does bring to light, however, that I may choose not to hardwire it in afterall - may just run the already-long-enough cable through to the boot and plug it in there.
I've installed the Drive and Play in my 2006 and am very happy. However the display is a throwback to 1980 monitors. Does anyone know how to convert the display so it appears with an orange display. I've tried various plastic filters but can't get a satisfactory look. Is there a way to change LED screens and replace the HK with an orange one?
There is this MOD site but not sure what kind of LEDs are in the HK Drive+Play. Its way over priced but may be able to install your self with some electrical/solder knowlege. Just hope they are not those tricky right angle LEDs.
http://www.ipodmods.com/shop/1013-ha...-play-mod.html
Been meaning to post this for a while... but here it is! I'm using the DICE module. Unfortunately though, I purchased the DICE before I realized that an adapter existed for connecting the DICE behind the radio, so I used the boot CD-changer adapter. This is unfortunate because I wanted a 'pro' look to the install with *no* exposed wires anywhere. So, I took out the back seats, back right side panel, passenger kick panel next to the seat, glove box, down tubes, and the center console to install and hide the wire!
Overkill? Yeah, probably, but that's half the fun!
And, since I already had the center console removed, I bought from a local MINI dealership the $3 part that lights the cigarette lighter in the '02-'04 MINIs, and installed it. It was the part, about two inches of wire, a terminating end, and about 5 minutes worth of effort to relight the lighter! It makes a absolute difference in the appearance of the MINI at night. Definitely something that shouldn't have been removed for the '05-'06s.
Anyway, back to the iPod install, I ran the cable from the boot to the DICE unit hiding underneath the head unit, then ran the iPod interface cable from the DICE unit, down under the carpet, up through the center console, and through a hole I drilled through the right downtube. I 'finished' the hole by installing a rubber gromit from Lowe's.
You can kinda see the hole that the cable is ran though and the light from the cig lighter. You can go to my Flickr page for more pics and details here: http://www.flickr.com/photos/psbales...7594539650530/
-Paul!
Overkill? Yeah, probably, but that's half the fun!And, since I already had the center console removed, I bought from a local MINI dealership the $3 part that lights the cigarette lighter in the '02-'04 MINIs, and installed it. It was the part, about two inches of wire, a terminating end, and about 5 minutes worth of effort to relight the lighter! It makes a absolute difference in the appearance of the MINI at night. Definitely something that shouldn't have been removed for the '05-'06s.
-Paul!
-Paul!
-Paul!
Thanks!
What I would love to do for a truly 'wire-free' install is get a downtube that has the iPod cradle integrated into it, and the wire running through it! I seem to remember one existing somewhere, but I can't find any evidence of it.
-Paul!
-Paul!
http://www.realoem.com/bmw/showparts...=61&fg=35&hl=1
I'm assuming you got the item #5 bulb socket (p/n 61346915065). Does this part come with the bulb? And how did you wire it? According to the wiring diagram in the Haynes manual, it would normally be connected to a gray/red wire which carries switch light illumination, but I don't know whether this wire was removed from the harness for an '06.
You should just be able to jump it to the pos (+) lead on the cig lighter, & if the unit is not grounded to the cig lighter case, a ground jumper would also be needed.
If they removed the light, they prob. also removed the wire in the harness as a cost savings.
Thanks for the tip! I've wanted to do this for my '06 but wasn't sure because someone reported there was neither a place for a bulb nor wiring for it. I found this on RealOEM:
For the wire, I just ran about 2" wire. One end was terminated to the light socket, and for the other end I just exposed a bit of wire, inserted it into the little hole on the positive tab on the cig lighter, and simply shoved the standard connector over it. Worked perfectly!
-Paul!
First of all, I apologize for veering the thread off-topic, but this is good information. Paul, thanks for posting about it. At $3 for the part, I'll get two and I think it should also work for the lighter socket in the boot.
This may have already been answered but I didnt feel like fishing through 7 or 8 pages of post to see if it had been. If it has, I apollogize.
I have recently had the iPod adapter installed in my MC and I love it. I have a 2002 MC, and we installed it in the cd changer port on the back of the stereo. When I play my iPod all that displays is cd number-track number (i.e. 6-94 ).
This is my first Mini, and was wondering if/when the stereos were upgraded to display the song title/artist on the display of the stereo, or is that possible? I would really love to be able to see a display on my radio of what song is being played, but do I need to upgrade my stereo to do that or what needs to be done?
Any help/suggestions would be greatly appreciated. Please send me a private message if you have any information.
I keep my iPod in the glove compartment and it stays rather cool with the air vent that dumps out into the glove box..... I still cant get over that.... a Mini Refrigerator!!!
Becky
Becky
If so, you are out of luck, the factory unit is especially pathetic. I have no idea what BMW where thinking when they created the unit, but it was obviously something along the lines of
'I have very few songs on my iPod, I always know who/what is playing'. As the standard CD Changer only displays the CD number and track number, so the iPod interface does the same.
My wife has the same interface in her BMW and I utterly hate it, she has a post-it note under the passenger sun visor to remind her what play-list is what
1 - R&B
2 - Soul
3 - Pop
4 - Rock
5 - Max's stuff
Even then with ~2000 songs in each playlist, it really is an exercise in futility to try and figure out what you are listening to, especially when it is in random mode !
There are several after-market solutions that allow song ID display, but I understand that you need a much newer head unit.
Possibly the best solution is to ditch the MINI head unit and go aftermarket - I recently installed a really fantastic sounding system in my son's Nissan that includes iPod and XM integration (full), plus an additional AUX input, steering wheel controls, amplifier, new speakers and a sub for about $650 from crutchfield.com - the installation took an entire day working slowly.
I am on the edge of adding a similar system to my MR2, then maybe I will attack the MINI in the summer.......
FYI, I ditched my OEM iPod adaptor last week (same frustrations as listed by MaxN) and installed the DICE auxilary system. It is fantastic. I get Album, Artist and Song Title on both my radio and navigation screens. The steering wheel controls along with the radio controls allow for song skipping (or reversing) and volume selection. The unit was under $150 shipped. I keep my iPod Nano discreetly parked on my Euro Parcel Shelf where I have easy access if needed, but it doesn't show to passers by.
