Navigation & Audio 04 HK same as 06 HK system? easy swap?
Old Dec 4, 2008 | 09:39 PM
hexproject's Avatar
hexproject
hi, my sister has an 04 MC with HK.
I have a 06 MCS with regular.
Is it a easy swap? I don't plant to swap out the HK grill, so is that possible?
has anyone done this before?
1) amp
2) 4 speakers in the front
3) 2 speakesr in the back.
Old Dec 4, 2008 | 09:58 PM
jgooch74's Avatar
jgooch74
The wiring is not the same.Not an easy swap.
Old Dec 4, 2008 | 10:23 PM
hexproject's Avatar
hexproject
How about just the HK speakers swap?
That should be easy right?
But will the non-HK system be enough to power the HK speakers?
Anyone upgrading a 06 HK system, let me know. i will buy your system.
Old Dec 5, 2008 | 01:10 AM
Eric_Rowland's Avatar
Eric_Rowland
Sadly, nothing simple about it. The swap has been done before - there are threads on it.
Special wiring from the HU to the amp, amp to the speakers. Speakers are a different impedance (4ohm??) than non-HK.
Old Dec 5, 2008 | 06:11 AM
pimpedout97x's Avatar
pimpedout97x
better to just buy a nice component set up front, maybe some 6x9 "subs" for the rear (look at the Tang Band's on partexpress.com) and a 4ch amp to power it all. and a head unit, unless you want to keep the stock one.
Old Dec 5, 2008 | 06:12 AM
GBMINI's Avatar
GBMINI
Don't try it! Please ...
The '04 / '06 issue is irrelevant. It's just that H/K is an "all in one" design that is seriously different to stock.
For example, no crossovers in the doors between low & mid/high - it's built in to the amp, with two separate feeds to each door!
Recommend instead looking at the DPSM; it's plug and play with the stock car, and more powerful ...
Old Dec 5, 2008 | 03:21 PM
Edge's Avatar
Edge
AdMINIstrator
Definitely.
hexproject... I don't know what your budget is, and how important staying with OEM solutions (versus the aftermarket)... but your MINI is a perfect candidate for the DPSM system.
The DPSM is WAY WAY better than H/K. Blows it away completely. You won't miss the H/K at all once you have the DPSM.
Installing the H/K in a non-H/K MINI is not easily done. Trust me, I did the reverse... went back to the regular Boost setup. Why? So I could have the DPSM instead. It was nuts, and although I love my DPSM, I wouldn't go through the H/K -> non-H/K conversion again, knowing what I know now. Here's the thread... and it also includes good links about the DPSM itself in the first post.
Mind you, if you're not willing to break the $1,000 mark on your car stereo, disregard the entire thing. The DPSM kit itself runs around $1320 just for the parts (when you buy from a dealer who discounts). Then there's the labor, although if you're confident, you can install it yourself.
Old Dec 5, 2008 | 08:34 PM
hexproject's Avatar
hexproject
thanks, guys. i think i will look into the DPSM route......
I have done all the outside already.. now i am looking into upgrading the inside...
https://www.northamericanmotoring.co...ml#post2580359
Old Dec 5, 2008 | 09:50 PM
hexproject's Avatar
hexproject
By the way... anyone got DPSM around in OC????
I want to check it out if anyone's got them......
Old Dec 6, 2008 | 08:14 AM
GBMINI's Avatar
GBMINI
OC?
Old Dec 6, 2008 | 11:05 AM
Edge's Avatar
Edge
AdMINIstrator
My guess is OC = Orange County
Old Dec 6, 2008 | 12:37 PM
hexproject's Avatar
hexproject
Yeap... OC.. anyone??
Just order it from Morristown, can't wait for it to get here....
one thing I may have to do with all the posts is that re-ripping my CD collection....
Old Dec 6, 2008 | 02:42 PM
GBMINI's Avatar
GBMINI
Sounds like you'll soon be the MINI guy with DPSM in OC
Old Dec 7, 2008 | 01:39 AM
Edge's Avatar
Edge
AdMINIstrator
Oh, like this?
iggi
18
Feb 9, 2026 01:00 AM
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
woodstudio
Mar 15, 2020 08:28 AM
ebowling
90
Aug 4, 2019 09:15 AM
Aug 25, 2015 01:32 PM
