MidCal MINIs MidCal MINIs...filling the MINI void between Northern and Southern California. Visit the club site at midcalminis.com
A Big Thanks
Old Oct 21, 2007 | 06:27 PM
  #10976
1nf3rn0's Avatar
1nf3rn0
Before you weld it, the megan header and test pipe is about 8" longer than the stock header.... Plan ahead for that so you dont have to cut and weld your exhaust later on.... Nitrous is getting refilled tomorrow and I'm paying the dyno shop a visit to make sure everything is set for Jan to come out and map my ECU...
Originally Posted by checkmate2006
It does have quite a drone. The only gasket is at the cat and right now i don't have a gasket because i need to get different bolts that are long enough to have a gasket in between. I was thinking about getting some flanges on the mid section and rear section welded on so i can create a way better connection then the slip fit method.
Old Oct 21, 2007 | 06:48 PM
  #10977
checkmate2006's Avatar
checkmate2006
Awesome I was looking on Jegs and they have these SS strap band clamps that will cover the compression cuts.
Old Oct 21, 2007 | 09:05 PM
  #10978
1nf3rn0's Avatar
1nf3rn0
That would probably be better.
Old Oct 22, 2007 | 09:20 AM
  #10979
checkmate2006
this week I am ordering 2 of those clamps and get it all secured together. For some reason my passenger airbag light won't go out I checked the connections under the seat I wonder if they went bad or the sensor in the seat went bad.
Old Oct 23, 2007 | 10:04 AM
  #10980
JIMINNI's Avatar
JIMINNI
Ok whats the deal? Where is everyone? Brad how is your car comming along? Anyone have any thoughts about getting tuning from Jan at RMW. Apparently he is set up for it now.
Old Oct 23, 2007 | 10:09 AM
  #10981
Scooby03's Avatar
Scooby03
Only one piece left to take off. Didn't find anything new broken.
Old Oct 23, 2007 | 10:44 AM
  #10982
checkers's Avatar
checkers
I'm going to try to get mine tuned next month by Jan if we can make a connection. My car's going back in the shop for some more polishing and powder coating and maybe after that a tune.
By the way, what time does the xcross on Nov 3rd & 4th ? I was thinging about come down and watching ( no car just a p/u).
Old Oct 23, 2007 | 10:55 AM
  #10983
Fracky's Avatar
Fracky
Transwarp - Warp 10.0
That's what I've been wondering! Since I'm not going to be getting a head/cam/intake manifold anytime soon, I've been thinking about getting a RMW tune for the mods I have. I already have the Shark, but from what I've read the Dyno tune will actually squeeze additional hp outta the motor along with all the stuff the Shark does. Does anybody have an idea of cost?
Old Oct 23, 2007 | 11:01 AM
  #10984
willum's Avatar
willum
Randy,
registration opens at 7:30am and 1st car out is usually around 9:30. We (street modified) will most likely run in the afternoon (last 2 events we ran in the morning groups) . Depends on who is running the show and how many cars there are as to how close to staying on schedule they will be. I'm probably going to miss Saturday....depends on where I end up at the conclusion of Fridays run over highway 36 to 101. And then may "flip a coin" to do AutoX or REME's run. on Sunday.
Go here for info and directions to the track.
http://www.sfrscca.org/solo2/Fresno/
Old Oct 23, 2007 | 11:12 AM
  #10985
1nf3rn0's Avatar
1nf3rn0
Go for it. I'm setting up a group buy for him to fly out to michigan to tune our club's cars.....
Old Oct 23, 2007 | 11:13 AM
  #10986
1nf3rn0's Avatar
1nf3rn0
$350 + dyno time (usually $100)
Old Oct 23, 2007 | 11:20 AM
  #10987
Fracky's Avatar
Fracky
Cool deal Blake!
Do you know the specifics of the tune, what parts of the software are modified, approximate gains to expect, etc? Cost sounds a-ok.
Old Oct 23, 2007 | 11:28 AM
  #10988
1nf3rn0's Avatar
1nf3rn0
Well, he uses Dimsport which is the best, IMO. Its the same tune that Luckydog uses. Jan says, the lowest gain hes ever gotten was 12 whp, and with a car like yours, you could gain as much as 20 or more.
The tune can be whatever you want. it all depends on how much time and money you want to put into the tune. You can just have them map WOT and a basic map on partial throttle, or you can have them do a full map for everything. The time could range from 30 minutes for a basic tune ($50) to hours.... It all depends on how deep you want them to go into it.
Cool deal Blake!
Old Oct 23, 2007 | 12:18 PM
  #10989
Scooby03's Avatar
Scooby03
Blake,
Are any of the SoCal fires near your old house?
Old Oct 23, 2007 | 12:32 PM
  #10990
1nf3rn0's Avatar
1nf3rn0
Nah, they're all fairly far away.
Originally Posted by Scooby03
Blake,
Old Oct 23, 2007 | 01:44 PM
  #10991
Fracky's Avatar
Fracky
Hmmmm...ok, assuming we're not worried about dyno time & can go for 2-3 hours - what kind of gains could be anticipated?
Old Oct 23, 2007 | 01:49 PM
  #10992
1nf3rn0's Avatar
1nf3rn0
It all depends on how good your tune from the factory was. Think 15whp conservativley. The time factor improves the smoothness of your engine and gas mileage at partial throttle. It will also increase power at partial throttle which helps on track and auto x.
Old Oct 23, 2007 | 01:52 PM
  #10993
ChrisW's Avatar
ChrisW
Man I don't mean to sound like a jerk but no one can answer that untill they get in there and see what they are working with. Plus its about a lot more than Numbers. They can make your TQ curve more linear. they can play with your A/F.
Old Oct 23, 2007 | 03:24 PM
  #10994
Fracky's Avatar
Fracky
No offense taken bruthaman Does anyone have a pre/post RMW custom dyno tune to post so we Mid-Cal'ers can see before and after results? It'd be neat to see a tune involving a car with lots of bolt-ons, but not having header/cam/intake manifold. Don't know if that graph is floating around, but it'd be cool to see.
Old Oct 23, 2007 | 03:34 PM
  #10995
1nf3rn0's Avatar
1nf3rn0
Give Jan a call. Heres a link to the thread where jan talks about his ecu flash....
http://www.michiganmini.org/forum/in...p?topic=2635.0
Old Oct 23, 2007 | 06:18 PM
  #10996
JIMINNI's Avatar
JIMINNI
Thanks for that link . Very informative.
Old Oct 23, 2007 | 09:10 PM
  #10997
1nf3rn0's Avatar
1nf3rn0
Welcome
Old Oct 24, 2007 | 11:09 AM
  #10998
Fracky's Avatar
Fracky
Blake,
You've done some super-cool things with your car lately. Do you have any other neat mods slated for the next couple months? Jim's wife & my wife are playing the role of "financial flow restrictor", so we need to live vicariously.
Old Oct 24, 2007 | 12:46 PM
  #10999
1nf3rn0's Avatar
1nf3rn0
Heh. There are a couple things in the works. First I want to get to 200 whp on motor, then later on this year is a special design rotex supercharger from jan....
Blake,
Old Oct 24, 2007 | 01:09 PM
  #11000
ChrisW's Avatar
ChrisW
11000
