MidCal MINIs MidCal MINIs...filling the MINI void between Northern and Southern California. Visit the club site at midcalminis.com
A Big Thanks
Old Oct 29, 2007 | 02:59 PM
  #11076
Fracky's Avatar
Fracky
Transwarp - Warp 10.0
Ok, different topic. After these Saturday morning canyon runs I've realized I'm in need of two things: 1. harnesses & 2. proper suspension (ie. camber plates, etc.). Because I have the crazy stereo system to work around & have already "been there/done that" with an Autopower cage, I think I'm going to go the harness bar route since I'll never track the car. Has anyone ever seen this unit in-person: http://www.bkauto.com/mini/r1305.php. Also, what kind of harnesses could I run with this bar?
Old Oct 29, 2007 | 03:02 PM
  #11077
1nf3rn0's Avatar
1nf3rn0
You could run any harness designed to work with a cage...
Old Oct 29, 2007 | 03:33 PM
  #11078
Fracky's Avatar
Fracky
Correct. I knew that part though. I meant is there a particular setup like Sparco/Momo/etc. 4-point which anybody'd recommend? If you can post some links to that'd be sweet!
Old Oct 29, 2007 | 03:38 PM
  #11079
1nf3rn0's Avatar
1nf3rn0
Well, I prefer sparco, but there are plenty of great brands depending on how much you want to spend.... Scrotch, which is the same harness as the sparco, just with a different label is a bit cheeper than sparco, but just as good.
Old Oct 29, 2007 | 04:11 PM
  #11080
Fracky's Avatar
Fracky
Thanks bud!
Do know where I can find pictures of Mini's with an install setup like I'm looking for?
Old Oct 29, 2007 | 04:23 PM
  #11081
1nf3rn0's Avatar
1nf3rn0
I haven't found any threads on it... its fairly straight foreward though....
Originally Posted by Fracky
Thanks bud!
Old Oct 30, 2007 | 08:31 AM
  #11082
Fracky's Avatar
Fracky
Okey doke, I found what I'm looking for. I know Helix used to carry the Brey-Krause harness bar. Brad (& Dr.Steve), can you check into this item for me/us? Cost, etc.?
Old Oct 30, 2007 | 10:21 AM
  #11083
1nf3rn0's Avatar
1nf3rn0
Just get an autopower bar... Its probably not much more expensive and looks great....
Old Oct 30, 2007 | 01:57 PM
  #11084
03Eeyore's Avatar
03Eeyore
Steve & Brad,
I don't know what is up with the car. But now somtimes the driver door opens on one pull. Am I lossing my mind??? Did not have time to bring by today but is there someting I sould or should not be doing?
Oh ya I did not know how to post with out replying so sorry if this is not how it is done!!!!
Tina
Old Oct 30, 2007 | 02:38 PM
  #11085
1nf3rn0's Avatar
1nf3rn0
It sounds to me like your car doesn't have the autolocking on.....
Originally Posted by 03Eeyore
Steve & Brad,
Tina
Old Oct 30, 2007 | 03:53 PM
  #11086
03Eeyore's Avatar
03Eeyore
If autolock is when the car automaticly locks when you get above I think it's 10 - 15 mph, then it is on. But I just got the door cable replaced last Wednesday and don't want someting to be wrong or find out that I am doing soething wrong.
Tina
Old Oct 30, 2007 | 04:06 PM
  #11087
1nf3rn0's Avatar
1nf3rn0
Hmm... Are you removing the key from the ignition before you open the door? In that case, you only need one pull because the doors automaticly unlock....
Tina
Old Oct 30, 2007 | 07:39 PM
  #11088
MINICHEF's Avatar
MINICHEF
on my '05 it does not seem to matter what the situation is it takes two pulls to open, key in or key out, unless I hit the unlock switch.
Old Oct 30, 2007 | 08:35 PM
  #11089
1nf3rn0's Avatar
1nf3rn0
That means you haven't activated the autounlock feature....
Old Oct 30, 2007 | 09:23 PM
  #11090
Fracky's Avatar
Fracky
Yep, mine's the same as your's Minichef.
Old Oct 31, 2007 | 01:05 PM
  #11091
JIMINNI's Avatar
JIMINNI
So where in the heck are Brad and Steve today? Haven't seen them online? Hey Steve thought you might like to see this: https://www.northamericanmotoring.co...2&postcount=20
Jim
Old Oct 31, 2007 | 01:29 PM
  #11092
ChrisW's Avatar
ChrisW
Jim
They are at SEMA.
Old Oct 31, 2007 | 02:07 PM
  #11093
03Eeyore's Avatar
03Eeyore
I did not know that it would do that, I will try it and see. Thanks For the help!
Tina
Old Oct 31, 2007 | 02:33 PM
  #11094
JIMINNI's Avatar
JIMINNI
Originally Posted by ChrisW
They are at SEMA.
Thanks for telling me, I was going to go over there this afternoon. Do you know when they are getting back?
Old Oct 31, 2007 | 02:43 PM
  #11095
ChrisW's Avatar
ChrisW
Saturday sometime.
Old Nov 1, 2007 | 08:15 AM
  #11096
checkmate2006's Avatar
checkmate2006
I am buying Blakes M7 M-Wing. Now I need to get the STB and then I will be good because I need to save up for the drive and the stuff I am getting at AMVIV5
Old Nov 1, 2007 | 08:48 AM
  #11097
1nf3rn0's Avatar
1nf3rn0
I'm going to take it off this afternoon...
Old Nov 1, 2007 | 08:49 AM
  #11098
1nf3rn0's Avatar
1nf3rn0
Anytime
Tina
Old Nov 1, 2007 | 01:23 PM
  #11099
03Eeyore's Avatar
03Eeyore
Yep, that was it! It only works every now and again, but at least I am not lossing my mind or doing something worng. I just never noticed that it did that since my door has been broken since I got the car, "that is until Steve fixed it last week"! Thanks again!
Tina
Anytime
Old Nov 1, 2007 | 02:44 PM
  #11100
1nf3rn0's Avatar
1nf3rn0
OK, question... Should I leave my car wingless or revert to the OEM wing?
