JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Is this a JCW Mini or not?
Old Jul 28, 2018 | 04:55 PM
  #101
ItsmeWayne's Avatar
ItsmeWayne
Congrats on your starting option! It is always good to have one that actually starts!
Now, how does it run and drive?
Old Jul 28, 2018 | 05:13 PM
  #102
A383Wing's Avatar
A383Wing
It's not drivable yet.....right now it's sitting on 4 jack stands in my garage with the 4 tires & rims and the entire front end off the car in front end service mode. I need to test the radiator fan resistor to see if it's good, if it isn't, now is the time to replace it....already had to replace the resistor in my R53 when I got it
I need to do a supercharger service, replace the water pump, the rear brakes are frozen, could be bad e-brake cables or calipers, or both....
The radio does not make tune noise from the speakers, possible bad Harmon Kardon amp
And the convertible top stopped working when I disconnected the battery to install the EWS & engine computers back in the car......(sigh....it was working, but not now)
Bryan
Old Jul 28, 2018 | 05:23 PM
  #103
twokbolt's Avatar
twokbolt
Originally Posted by A383Wing
Just for everyone's information......
IT'S ALIVE....IT'S ALIVE!!!!
A big thank you to RPM Motorsports.......
Now I gotta fix the other items that are bad......
Bryan
That's awesome! Congrats! So what was the issue?
Old Jul 28, 2018 | 05:24 PM
  #104
A383Wing's Avatar
A383Wing
RPM Motorsports said that the EWS4.3 module was out of sync......the engine computer was OK......
Old Jul 28, 2018 | 05:37 PM
  #105
Cornfed82's Avatar
Cornfed82
Congrats! So, what's the plan? Just get it driving or is this a light restoration for undoing the previous owner's. . . efforts?
Old Jul 28, 2018 | 05:47 PM
  #106
A383Wing's Avatar
A383Wing
So far the plan is to fix everything that is wrong with it....and just make it a good daily driver......the body is perfect....so is the convertible top.....interior is perfect except the drivers seat has one of the seat bottom stitching's come undone
I need to get the supercharger serviced and put the radiator assembly back in and then let the engine run to see if it's OK or not.....I have some noise from under the valve cover or timing cover, probably due to sitting for so long and being cranked over a lot and not starting.....
Bryan
Old Jul 28, 2018 | 06:14 PM
  #107
vetsvette's Avatar
vetsvette
Moderator
Old Jul 29, 2018 | 12:40 PM
  #108
A383Wing's Avatar
A383Wing
Originally Posted by MrBlah
perform a ews sync with ista+/ista D
if you do not have the cable/software ask local mini facebook groups, or local bmw facebook groups someone near you will have it working
if ews is out of sync, you will get a crank with no start.
You were correct, the EWS4.3 module was out of sync......RPM Motorsports did a repair or re-sync on the module......car now starts and engine runs....
Bryan
Old Jul 29, 2018 | 01:17 PM
  #109
ItsmeWayne's Avatar
ItsmeWayne
You can take it to an upholsterer and thet can restitch it for you,
Keep us posted!
I am happy that you have it running and hope it is roadworthy soon!
Old Jul 29, 2018 | 02:07 PM
  #110
cristo's Avatar
cristo
Alliance Member
Old Jul 29, 2018 | 02:37 PM
  #111
AzBluesman1962's Avatar
AzBluesman1962
On the top, try this....cycle the windows up and down 3 times, then try the top. Also I am not sure on this but the key might operate the top too, in the door handle lock. Unsure about this one as yours being an first gen. When the battery is disconnected for a prolonged period, one needs to reboot the system.
Old Jul 29, 2018 | 05:59 PM
  #112
A383Wing's Avatar
A383Wing
I tried that, plus all the other reset procedures.....even held the unlock toggle switch in the "up" position for the recommended time.....the top still doesn't work at all.....
I taped the package shelf limit switch down, made sure the convertible top lever tripped the other limit switch back there, also made sure the trunk light goes out when the boot lid is closed.....still the top is up
I don't get any red light flash, or any noise or movement at all when I try to open the top.....the windows work just fine, and I can roll them up with the key in the drivers door as well.
I have the battery disconnected for the night....I'll start over tomorrow......all this started when I disconnected the battery to install the engine and EWS computers back into the car after I got them from RPM Motorsports.......at least the engine runs now, but I don't know why the top would stop working
I checked the low speed fan resistor today also, it's bad....got another coming next week
Old Jul 30, 2018 | 07:21 PM
  #113
A383Wing's Avatar
A383Wing
Quick update on the "convertible top no workie" after I disconnected the battery to install the EWS & engine control computers from RPM Motorsports......
Before I connected the battery back up this morning, I decided to test the top motor in the crossbar in the center of the top, no power to the connector, I did use a battery and supply power to jump the slider motor and it works. So then I decided I would test both limit switches at the rear of the car in the trunk. Removed both switches, tested them with OHM meter and both test OK, reinstalled limit switches.
Next task was to reconnect the battery and continue trying to figure out why top will not budge at all......
Connected battery, turned key on, radio says "disable", the navigation screen just stares at me with the "MINI" logo on the screen....I cycled the windows a few times, then tried the "top down" button, nothing....no noise, no red light blinking......it's getting close to 90* in my garage at 10am and I'm back to being frustrated with the "Mini from hell" now.....thinking to myself what did I get myself into here with this car.........
Then I had an idea.....I remember from my many years of being an auto tech that some "high end" cars have to "relearn or re-boot" some of the modules after battery disconnect......so what I did was just leave the key in the ignition in the "run" position for about an hour or so while I did other things in the garage.......after a while, I went and looked inside the car, the radio was on a station, and the Nav system was showing my location on the map screen........so I thought, Hmmmmm......could it be this easy? Got inside the car and pushed the "top down" button.....and it worked.....top goes up & down perfectly now.....guess I should have remembered the "reboot" issue earlier.......so now if I ever have to disconnect the battery for any reason, I'll be sure to put my "memory saver" cable into the ALDL computer diagnostic connector under the dash to prevent this from happening again.......so that issue is solved.
Now I can concentrate on the other issues to fix, the supercharger service, water pump, cooling fan resistor, e-brake cables, and getting the radio to produce noise out of the speakers.......and tires, car needs tires....and brake pads
I'm tired.....and relieved......it's been a busy hot day up here.....
Good night.......Bryan
Old Jul 31, 2018 | 08:37 AM
  #114
ItsmeWayne's Avatar
ItsmeWayne
Hi Bryan,
Glad you dxed and got the top working along with the other electronics! About a year ago, I replaced the fan speed switch with the oem and it only lasted a little over a year. I just did it again and this time trying a non oem one, in hopes it will last a bit longer! (in first gen JCW area) These seem o be a constant problem across the board of gen 1s.
Old Jul 31, 2018 | 12:57 PM
  #115
A383Wing's Avatar
A383Wing
Hi Bryan,
Wayne...I assume you are talking about the radiator cooling fan resistor in the radiator mounting assembly.....I had to replace the one in my '04 R53 after I got the car a few years ago. Found some on eBay for under $20.....it's been over 2 years now and the fan still works on both speeds......
Old Jul 31, 2018 | 01:48 PM
  #116
ItsmeWayne's Avatar
ItsmeWayne
To me it shows that not all the time, oem is the best! I am hoping I don't have to do this in another year! You give me hope!
Old Jul 31, 2018 | 02:15 PM
  #117
A383Wing's Avatar
A383Wing
Well, the '06 R52 MCS JCW "Mini from hell" has reared it's ugly head again.....another set-back today.
I decided to drain & fill the engine oil, I was not sure of what oil type was in the engine when I got the car, the oil was new & clean, but I was not sure if the previous owner knew that the engine requires synthetic oil or not.....so I just drained the crank case (didn't put a new filter in), and filled it up with new oil. Put the radiator back in, connected the hoses & cooling fan connector, and filled up with anti-freeze and water. I started the engine, I knew I had some sort of rattle under the hood....but when I didn't have the radiator in, I could not let it run very long without coolant. Well, the rattle is still there....I thought maybe, just maybe it would clear up & go away, nope.....the death rattle is still there even after completely warmed up and running for about an hour in the garage. I put my stethoscope on the engine and it sounds like it's coming from behind the timing cover, which is brand new....and I do mean "brand new" ......it's really shiny and no dirt at all on it at all.
So, what do I do now?
Replace just the tensioner and see if the noise goes away?
Can I tell anything if I pull the valve cover and try to look inside the timing cover?
Put a stop to the $$ bleeding and sell the car the way it is? (how much is the other question)
Part the car out and take my losses?
The car still needs e-brake cables, and maybe rear calipers, it does need rear pads for sure
The Harmon Kardon radio system does not make noise out the speakers, possible bad amp under the seat
Needs supercharger service & water pump (I have the oil, & water pump here now)
Needs wheels & tires (I'm keeping the black Motegi wheels that were on the car, and the front & rear tires were 2 different sizes)
The AC system needs to be topped off, it blows cold, but not as cold as it should be (the low speed resistor is burned out, I have a new resistor coming)
The drivers seat bottom stitching has come undone
I'm about done with this car.....I guess I expected too much from this little Mini.....
I need a nap.....(and maybe a drink first)
Bryan
Old Jul 31, 2018 | 03:46 PM
  #118
ItsmeWayne's Avatar
ItsmeWayne
Bryan
Hi Bryan,
It is critical to buy a tested chain tensioner, as many are garbage. So make sure to replace it with a tested one. Lots of bad new ones out there! Do this before anything else and don't let it run that long with a rattle! I do not think there is much if any value in taking the cam chain cover off.
Don't lose patience! You will get it worked out soon. These cars like to frustrate us, but when we win the battle, the rewards are there! Tust me, been there and done that!
On another note, the rear calipers are the wind back type and require a tool to wind the puck back in.
You can take the seat to an auto upholster and get the stitching fixed. Bring just the seat, to keep costs low.
Again, don't give up, as you are almost at the finish line!
Old Jul 31, 2018 | 05:42 PM
  #119
vetsvette's Avatar
vetsvette
Moderator
First thing I would do is replace the oil filter, then the tensioner. I posted links for brake cables and rear calipers in an earlier post. When you get frustrated with the car, just remember what you paid for it. You got it for a good price. I imagine you could get your money back if you list it.
Old Jul 31, 2018 | 06:58 PM
  #120
A383Wing's Avatar
A383Wing
I've got the disc brake wind back tools here. Have a tensioner coming from Pelican this week. Will install that and see if it makes the engine running quieter, then decide what to do
Bryan
Old Jul 31, 2018 | 07:17 PM
  #121
ItsmeWayne's Avatar
ItsmeWayne
It is important to know if the drain off valve at the bottom of the oil filter casing has not popped out, or is gone. If either of these are the case, oil pressure will be very low and usually throw a code, for low oil pressure. But if it is just leaking by, the pressure may not be low enough to throw a code. You should check it to have piece of mind. I still think it is crap and stuck cam chain tensioner!
Old Jul 31, 2018 | 07:44 PM
  #122
A383Wing's Avatar
A383Wing
Yea, I hear what you are saying, before I actually started it up today after draining the oil from the crankcase and putting new oil in, I disabled the coil and cranked it over until the oil light went out, then waited for it to come back on, took about 10 seconds, maybe a little more. I'll get an oil filter tomorrow and check that valve inside the housing.
From what I've read today, I'm pretty sure it's a stuck tensioner from sitting so long and not being able to start
Bryan
Old Jul 31, 2018 | 07:51 PM
  #123
ItsmeWayne's Avatar
ItsmeWayne
The tensioner is done from the outside, next to the oil filter and a little lower. It is not too hard to do, but requires a little contortion to get the socket and ratchet in there. I have done many though, so it is doable!
Note: oil it before installing it. You need the shaft to be slippery, before the oil gets to it,
Old Jul 31, 2018 | 08:20 PM
  #124
A383Wing's Avatar
A383Wing
Yea, I found a few videos and info on tensioner replacement, I already have the wheels off, and the header heat shield is off as well, I've also got a complete mechanic tool set since 1974, it's what I did for a living.
I hope this tensioner replacement cures the noise, I'm not in the mood to tear the front of the engine off at all.
Will keep you posted, and thanks
Bryan
Old Aug 1, 2018 | 01:07 PM
  #125
A383Wing's Avatar
A383Wing
Yes, I saw the links for the calipers & cables......and I do appreciate the time for looking & posting the links......but as a retired auto tech after 45 years in the field....I will not buy used calipers to put on a car.....too much liability and I would not know if they are in the same shape as the ones I got on the car already
So, to continue with the story on the "chain rattle" noise I have now.....I went to the local part store and picked up an oil filter so I have that to put back in when I check the drain valve in the filter adapter....and I need to get the tensioner pulled to see if it's collapsed, stuck, or not......the filter and the pulling of the tensioner is on my list for tomorrow
Bryan
