JCW Power Up!!!
Old Oct 6, 2016 | 10:07 PM
  #201
BadakVT's Avatar
BadakVT
Dragon, what's your "lean" AFR? I'm suspecting something is amiss because even without the tuning box you're running lean.
The decat pipe will free-up some restriction so you might see a momentary overboost but the DME should be able to handle that. The F56 DME runs on constant closed loop continuously monitoring the primary wideband O2 sensor (located before the catalytic converter), hence as long as there's no fueling shortage, you shouldn't be running lean with or without a decat.
Even on Map 2 JB4 which probably is close to the "Race" map on the Dinan box, I have not experience any fueling shortage. Fueling trims are always well below max, even on AKI91 gas.
Stock map @ WOT I'm seeing low 13s AFR on AKI91.
Map 2 (+6psi) @ WOT I'm seeing mid 12s to low 13s AFR on AKI91 + MTBE
I believe Marcopolo has done some logging with a Decat before. Let's see if he could share his AFR logs to compare.
Old Oct 7, 2016 | 01:04 AM
  #202
#Dragon#'s Avatar
#Dragon#
hi BadakVt
it was my mates car the only afr i saw was 14.2 the dyno operator said the reason he stopped was because he could see fuel starvation .
Old Oct 7, 2016 | 03:01 AM
  #203
BadakVT's Avatar
BadakVT
Might be normal depending on where at the RPM range you saw 14.2. My car on stock map is also running at low 14s up to around 4000rpm. Then it tapers down to the low 13s at close to redline. AFR should range from 1:15 at light load and tapers down up to 12.5:1 ish
at heavy load and high rpm.
These newer DI engines do run leaner than older tech turbo cars.
Any actual dyno sheet with afr readings to review? Dinan would be able to tell you what's going on providing you have data to share.
Old Oct 7, 2016 | 03:46 AM
  #204
sootyvrs's Avatar
sootyvrs
Here are some logs I posted up for BMS to check which has AFR
http://www.n54tech.com/forums/showthread.php?t=41813
Similar to what BadakVT has mentioned above (Mine has std. CAT)
Old Oct 7, 2016 | 04:34 AM
  #205
#Dragon#'s Avatar
#Dragon#
cheers sootyvrs
Old Oct 7, 2016 | 04:55 AM
  #206
#Dragon#'s Avatar
#Dragon#
fao sootyrs
i have just looked into your logs so these cars only get into the 13s at about 5000 revs ?
my mates car started off at 14.2 and then started to rise . i see terry said your logs were fine i did not no the car stayed in that range till around 5000 revs.
he is going to take the car to lohen and put it on there dyno as all they do is mini and see what they say.
Old Oct 7, 2016 | 06:26 AM
  #207
sootyvrs's Avatar
sootyvrs
Can't say I'm an expert myself which is why I sent logs to BMS (Terry) and if he says that is expected behaviour then I can only assume it is working as intended.
I read that the JB4 will always keep things safe and trim back on boost if it feels things are not working to some parameters. Not sure if other piggyback boxes do the same though?
I had a BMW M135 before with JB4 (sports cat and perf exhaust) and that also run similar AFR so I believe the modern BMW engines are designed like this (my own non expert assumption and from some reading on the net)
Old Oct 7, 2016 | 08:23 AM
  #208
#Dragon#'s Avatar
#Dragon#
thanks for the reply
Old Oct 13, 2016 | 08:46 PM
  #209
Sidewalker's Avatar
Sidewalker
Originally Posted by Dinan Engineering
I'm getting an error message with this link and can't seem to find this product available anywhere. Can anyone shed any light on this? I just hit 3400 miles on the car and feel like I'm ready to pull the trigger.
Old Oct 13, 2016 | 09:05 PM
  #210
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
http://www.dinancars.com/products/?category=dpt-sport
Old Oct 14, 2016 | 12:09 AM
  #211
MiniF55's Avatar
MiniF55
Sidewalker, I believe Ecstuning also started carrying Dinan products.
Old Oct 14, 2016 | 04:57 AM
  #212
Yea, we carry it.
https://www.ecstuning.com/News/MINI_F55_F56_Dinantronics_Sport_Performance_Tuner_ 21766/
Old Oct 14, 2016 | 09:20 PM
  #213
Sidewalker's Avatar
Sidewalker
There it is...thanks all.
Old Oct 15, 2016 | 07:06 AM
  #214
bratling's Avatar
bratling
Super Moderator
iOS app is still with Apple in there seemingly endless approval process so your guess is as good as mine at this point.
App review times are currently averaging about a day. Any idea why Apple is holding up your app? I hope they aren't expecting you to furnish a car for them to test the app...
Old Oct 17, 2016 | 09:00 AM
  #215
Welcome, it will work on the F57 / F54 also. We just have not updated the ad yet.
Old Oct 18, 2016 | 06:43 AM
  #216
chknlil's Avatar
chknlil
Installed my Dinan controller yesterday on my F56 JCW! Works great. Comes in Sport+ mode by default. I have an iOS phone and am waiting for the app to really play with it. Very fun and noticeable difference for a little bit of money!
Old Oct 18, 2016 | 08:12 AM
  #217
MiniF55's Avatar
MiniF55
Chknlil JCW has more than enough power. I'm sure the extra bump is amazing! Minis are so much fun to drive!!!
Old Oct 18, 2016 | 08:39 AM
  #218
#Dragon#'s Avatar
#Dragon#
You will enjoy race mode
Old Oct 18, 2016 | 11:25 AM
  #219
MiniF55's Avatar
MiniF55
Race mode!!!
Old Oct 18, 2016 | 07:58 PM
  #220
chknlil's Avatar
chknlil
Can't wait to try race mode. Need the iOS app!!!
Old Oct 20, 2016 | 09:35 AM
  #221
Boothy's Avatar
Boothy
Dinan Decat logs sport plus
any advice on these logs
Do they look ok
thanks
File Type: pdf
File Type: pdf
Old Oct 21, 2016 | 04:33 PM
  #222
pppdxx's Avatar
pppdxx
I just got back from running my F55 B36 engine on Race mode on 91 octane gas. Generated a max of ~17.5 PSI of boost and my butt dyno is very happy
Old Oct 31, 2016 | 10:12 AM
  #223
chipfiev's Avatar
chipfiev
Good news - the iOS app was released yesterday.
I found it when searching for Dinantronics; this one is called "D-SPORT" and has the red S on the icon.
Now I just need my tuner to show up so I can try it out...
Old Oct 31, 2016 | 11:55 AM
  #224
MiniF55's Avatar
MiniF55
Thanks for the heads up! App downloaded.....
Old Oct 31, 2016 | 12:10 PM
  #225
#Dragon#'s Avatar
#Dragon#
Is it working OK ?
