JCW JCW Aftermarket Wheels
Old Jul 27, 2018 | 11:11 AM
  #501
baytires's Avatar
baytires
its a 2018 design from rotiform
Old Jul 27, 2018 | 11:12 AM
  #502
That's why, so new.
Old Aug 19, 2018 | 08:23 PM
  #503
R53hyperblue's Avatar
R53hyperblue
Hi guys,
I just received my F56 JCW and I already have a Rotiform BLQ Wheels 19" 8.5 5x112 45 Offset, that I really want to install it in my new baby, Do u know if they will fit?, also I need wheel spacers but I dont know the size.
Tires are 215/35/19
What do u think???, any help will be awesome!!!
Mario
Old Oct 20, 2018 | 11:33 AM
  #504
Masada's Avatar
Masada
Just got Work vs-xx wheels installed...18x8, et 45. R-Disk up front to handle the BBK and O-disk in the rear for some lip. I am glad they are hubcentric so I don't have to mess with rings either.
Old Oct 20, 2018 | 01:30 PM
  #505
THISJCW16's Avatar
THISJCW16
those wheels are sexy
Old Oct 23, 2018 | 10:28 AM
  #506
elsnaibs's Avatar
elsnaibs
I got a second set of wheels to be my show and/or around town wheels, so I could use the Team Dynamics as dedicated track wheels with Federal 595 RRs.The new wheels are Sparco Podio in bronze, 17x7.5/+45.
Attached Thumbnails JCW Aftermarket Wheels-sparco2.jpg   JCW Aftermarket Wheels-sparco1.jpg
Old Oct 24, 2018 | 06:31 AM
  #507
kostasgreece's Avatar
kostasgreece
guys i have a jcw f56 with r18x7 54 ET and i ordered a r18x8 ET35 sparco asseto gara with 225/40 tyre... do you think i made a mistake ? i am gonna have any problem ? i can change my order and dont lose any money.
PS : not lowered
Old Oct 24, 2018 | 08:29 AM
  #508
CarFreak427's Avatar
CarFreak427
PS : not lowered
That setup will poke out about 32mm more than stock, but since you're not lowered, you should be fine.
Old Oct 30, 2018 | 10:28 AM
  #509
J_L's Avatar
J_L
https://www.willtheyfit.com
Old Nov 1, 2018 | 04:13 AM
  #510
Ferretdancer's Avatar
Ferretdancer
Does anyone know if the 2019 Clubman JCW has the same wheel fitments as the 2018 Clubman JCW? I want to get winter wheels and would like to drop down to 17" wheels, but I can't get a reliable
Old Nov 1, 2018 | 11:26 AM
  #511
elsnaibs's Avatar
elsnaibs
No changes as far as I know from the 2018 Clubman and the 2019 Clubman, the 2018 to 2019 changes are for the hatch, four door, and convertible, the clubman will probably get the refresh later.
Old Nov 6, 2018 | 08:35 PM
  #512
Clutch Wotan's Avatar
Clutch Wotan
Braid Wheels 8x17 ET40
Old Nov 7, 2018 | 01:26 PM
  #513
CarFreak427
Clutch Wotan can you share what tire size you have on your 17x8 setup?
Old Nov 7, 2018 | 11:03 PM
  #514
Clutch Wotan
I recommend Michelin Pilot Sport Cup 225/45
- first price 120 Euro, while the Cup tires for Porsche costs a fortune its in this size surprisingly moderate.
- Performance (at 87 Degree) they glue to the track
- with the bigger tire section you can use air pressure more precise to reach temperature via flex.
Old Nov 8, 2018 | 06:20 AM
  #515
jcwmarv's Avatar
jcwmarv
Wheels and tires on for Winter! 17 inch down from 18 and non run flats: Motegi MR118 and Continental Extreme Contact DWS06. Tight Squeeze with the Brembo brakes
Old Nov 21, 2018 | 03:37 AM
  #516
cmt52663's Avatar
cmt52663
Originally Posted by Clutch Wotan
Braid wheels Photo
Signore Wotan, did you go through a Braid dealer to find those pretty wheels? Which one dare I ask?
I too am headed for 17x8 next year, relegating the OEM wheels to winter use.
I'm as nervous as a long tailed cat in a room full of rocking chairs about the fitment...
Cheers,
Charlie
Old Nov 21, 2018 | 10:51 AM
  #517
Clutch Wotan
I don't know if BRAID US offer them. They rather sell 2o inch wheels cromed in the US for the drive to the ice coffee shop.
However I ordered them from Spain direct, via a Motorsport specialist in Germany you can choose any offset.
FULLRACE GT
Offset 40mm
The 3D milling and. polishing we did ourselves. They come painted white, I can only recommend 40 Offset as perfect, don't listen to others that the imperative offset !
Old Nov 21, 2018 | 11:28 AM
  #518
Dont forget that have to have spinners lol
Old Jan 4, 2019 | 10:57 AM
  #519
Carrera2RS's Avatar
Carrera2RS
FULLRACE GT
Offset 40mm
They look great, assume they clear JCW brakes okay ?
I am thinking of a set of these to replace the 7.5x17 on my JCW challenge. I'll probably paint satin or gloss black
Old Jan 24, 2019 | 02:09 PM
  #520
RLM's Avatar
RLM
Which Offset did you get? I just bought some used sight unseen (except by my brother) 17X8 +32 MR118's
Old Jan 25, 2019 | 08:36 AM
  #521
jcwmarv's Avatar
jcwmarv
Old Sep 18, 2019 | 05:05 PM
  #522
Pnice1p's Avatar
Pnice1p
2015 MCS with JCW Big Brake kit. Wheels are Advanti HY Hybris 18x8 ET45 with 3mm spacer. 225/40/18 all around.
I may switch to 215/40/18, adding the spacer meant raising the car up a bit. Check the original height before the JCW's
Original height with non JCW brakes.
Old Sep 20, 2019 | 07:06 AM
  #523
Darbys2019MiniJCW's Avatar
Darbys2019MiniJCW
NM RSe05 17x7.5s … Great Rim and Built for JCW Brake Clearance
Old Sep 20, 2019 | 09:42 AM
  #524
Banner28's Avatar
Banner28
Has anyone fitted a 3-piece wheel that clears the BBK without spacers?
Old Sep 27, 2019 | 07:51 PM
  #525
Clutch Wotan
