JCW JCW Aftermarket Wheels
Old Jul 8, 2017 | 01:47 PM
  #426
kfmuller's Avatar
kfmuller
Ok - so, I went to NM, and it looks like those are the NM Eng. RSe12 18" wheel. What size tire did you go with - 215 40 18s?
Old Jul 8, 2017 | 02:20 PM
  #427
mgflyfish's Avatar
mgflyfish
yes they are the nm's: RSe12 18 and th tries re the OEM pirelli cinturatos--18' 205/40/18
Old Jul 8, 2017 | 02:44 PM
  #428
kfmuller's Avatar
kfmuller
Did you just swap over your OEM tires? Mine only have 3500 miles on them so I might be able to just do that instead of replacing the tires, too. I've got to say, your pics make them look so much better than on the NM site, and I like the pics there. I was leaning towards black, but yours are amazing, and would look great on my Rebel Green JCW.
Old Jul 8, 2017 | 05:46 PM
  #429
02fanatic's Avatar
02fanatic
If I ever go with aftermarket wheels those are what I have had my eye on except I'm leaning toward the silver. The 7.5" width will allow a slightly wider tire too. I admit to really loving my two tone cup spokes though on my JCW...I know they are heavy but look great imo. NM is one of the only companies who make wheels specifically to clear the Brembos without spacers and they get my vote!
Old Jul 8, 2017 | 09:20 PM
  #430
mgflyfish's Avatar
mgflyfish
not sure i am understanding how you mean swap--did you mean did I put the OEM tires on the Nm wheels? Then, yes I did. I put my winter tires on the OEM wheels--
Old Jul 9, 2017 | 05:37 AM
  #431
kfmuller's Avatar
kfmuller
Yes, I meant - use the OEM tires that came with the car and put them on the new wheels.
Any chance you can take some more pics of the whole car so I can see the total package? Thanks
Old Jul 9, 2017 | 07:29 AM
  #432
mgflyfish's Avatar
mgflyfish
Old Jul 9, 2017 | 09:18 PM
  #433
Brazen's Avatar
Brazen
Hi All
I am about to become an owner of a 2017 F56 JCW and have been reading this thread in detail, very helpful info so far.
First on the list of mods will be coilovers & wheels and would appreciate advice on whether this setup will work with fitment etc;
OZ Superturismo GT 18x8 ET45 (Preferably no spacers, but will if required)
225-35-18 rubber
KW V1 coilovers or;
JCW Pro coilovers @ lowest setting
I would only use JCW coilovers for warranty and ride quality which has been spoken about in this thread already, however I would prefer a little more height adjustment than the JCW Pro's provide.
I don't love the idea of spacers but understand it may be needed and if so was thinking ECS 8mm front & 10mm rear.
If anyone can chime in with some advice would be great.
Old Jul 10, 2017 | 02:46 AM
  #434
kfmuller's Avatar
kfmuller
Thanks for the additional picture. I really think the NM wheels look great. If I replace my 18" Cup Spokes, it will be with these NM wheels.
Old Jul 19, 2017 | 09:22 AM
  #435
nismo's Avatar
nismo
Some Japanese wheels 18/8J et43 all around.
Old Jul 23, 2017 | 07:25 AM
  #436
Pathy01's Avatar
Pathy01
Enkei TS-10 & Michelin PSS 215/40R18
Ordered through TireRack and installed them on the car. 18x8 ET45 Storm Gray wheels. Very happy with the fitment, appearance and the performance/comfort. Going from the stock 17" runflats to 18" non-runflats has still improved the ride comfort. Probably a combination of lighter wheels (sub 20 lbs) and having a regular sidewall. Slightly larger overall diameter than stock, but if anything that'll made the speedo/odo more accurate. There is about 4mm of clearance to the front calipers.
Old Jul 23, 2017 | 07:21 PM
  #437
vetsvette's Avatar
vetsvette
Moderator
Lookin' good.
Old Jul 24, 2017 | 09:28 AM
  #438
TheGeekGuy's Avatar
TheGeekGuy
Careful with curbs.... The paint is REALLY soft and there isn’t much protection from the tyre sidewall.
Old Jul 24, 2017 | 09:33 AM
  #439
vetsvette's Avatar
vetsvette
Moderator
That's one thing I like about my Goodyear Eagle F1 tires. They have a rim protector.
Old Jul 24, 2017 | 02:40 PM
  #440
Pathy01's Avatar
Pathy01
No worries on the curbs. If I can't get a MINI parked without hitting the curb, I'll hand over my license. Ideally I would've liked a 7.5" wide wheel, but with the limited selection to fit JCW brakes and not be very expensive, I went with these which are 8" wide. The 215 on a 7.5" would've given me my preferred setup, but I had to balance out appearance, weight, cost, etc and these came out on top. I actually think I may have been able to get away with a wider tread width as there's a bit of room between the tread and strut.
Old Jul 25, 2017 | 08:31 AM
  #441
nismo's Avatar
nismo
18x8 et43
Attached Thumbnails JCW Aftermarket Wheels-img_2975.jpg   JCW Aftermarket Wheels-img_2970.jpg
Old Oct 7, 2017 | 01:58 PM
  #442
djtomy's Avatar
djtomy
18x8 et48
going on Monday after Nate passes
Old Oct 7, 2017 | 11:00 PM
  #443
ryanschram's Avatar
ryanschram
Originally Posted by mattkosem
Maybe. Looking at rimstock's fitment tool, it looks like they recommend ET45 for a 17x8, but tires might make that implausible.
A few posts back on this page, someone indicated them fitting with 215s. https://www.northamericanmotoring.co...ml#post4287384
If you use just about any tire besides the Michelin PSS, you can use 225/45/17 on a 17x8. The PSS actually runs really wide.
Old Oct 16, 2017 | 05:03 PM
  #444
djtomy's Avatar
djtomy
Finally got it all set up, Cost $2,376
OZ Leggera HLT 18x8 ET48 215/40/18FH Indy 500 tires, 66.6 Centering rings to76mm OZ wheels, cone to ball seat adaptors, 50mm Lugs 13mm spacer rear. 9mm (spacer up front) 8mm will work on one, but to be safe go 9 or 10mm
If anyone wants to run any OZ wheels, This will help you, On Tire rack choose Audi A3, (5x112) add your BMW or MINI TPM sensors 533mhz. You can get this whole package mounted & shipped, with the correct hub rings (same as Audi) 66.6-76) Please do not tell them its for a mini, (went through this with 3 different sales reps) or they will not sell it to you! The only thing you can't use, are the lugs that come with the package for an Audi (Different thread pitch M14 1.25 vs 1.5 Audi)
The only other things you need are:
M14 x1.25 Lugs (50mm threads), $60 ebay Silver Tapered Longer Extended Wheel Bolts Lugs | MINI | 14x1.25 | 50MM Thread
spacers 5x112 (10mm front & 12mm rear) get the hub centric ones 66.6 and 5x112 pattern
Cone to Ball seat adaptors. Lug Bolt Adapter washer (6 sets) 9508
https://www.ebay.com/itm/Silver-Tape...72.m2749.l2649
https://www.ebay.com/itm/Lug-Bolt-Ad...72.m2749.l2649
Old Dec 20, 2017 | 12:27 AM
  #445
Robmaster's Avatar
Robmaster
spacers 5x112 (9mm front 12mm rear) get the hub centric ones 66.6 and 5x112 pattern
https://www.ebay.com/itm/2X-HUBCENTR...72.m2749.l2649
9mm 3+3+3
Why you don't take it in ET35 instead of using spacers??
One of my customer got the same wheels in 18x8 ET35 and it fits great.
Old Dec 20, 2017 | 06:33 AM
  #446
Looks good, cant get any closer
Old Dec 20, 2017 | 09:13 PM
  #447
GPMini's Avatar
GPMini
Looks great! I've had the same wheels for about a year and a half now. I love em.
Old Dec 21, 2017 | 10:07 AM
  #448
djtomy's Avatar
djtomy
The Black on Black does looks awesome!
I didn't see that option (et35) in the dropdown. Was that taken in at a shop?
It would be a great idea, and I would have that done if I could find a place to do custom offset.
Old Dec 21, 2017 | 10:35 AM
  #449
vetsvette's Avatar
vetsvette
Moderator
You can also try NM. They carry an even wider selection of wheels for VW that come in offsets and colors not available for Mini's. The only downside is you can't use the Mini center caps and the bore is different. I know of a couple of members that had them machine the bore to 66.6 so they could get a particular wheel/color. I spoke with Jerry at NM when I bought my wheels about this, but they had the wheels I wanted in stock for my Mini build. Plenty of clearance for the Brembo's too.
Old Jan 3, 2018 | 10:28 AM
  #450
FunToMini's Avatar
FunToMini
Thought I'd post this, as Im not getting many answers in the F56/F55 section. For you guys who know the Mini offsets well, would 17x8 et35 fit a base Cooper? Not worried about the dimensions of the wheel, nor the width, more so the offset.
