JCW JCW Aftermarket Wheels
Old Mar 14, 2017 | 09:22 AM
  #376
elsnaibs's Avatar
elsnaibs
According to the Rimstock site, the PRO RACE 1.2 17X7.5 et+45 5X112 with a 205/45R17 tire will fit without spacers on the 2017 JCW. Anyone runing this setup? I was considering bumping the tire up to a 215/45R17, but notsure about clearance.
Old Mar 14, 2017 | 10:13 AM
  #377
NellyRod's Avatar
NellyRod
I'm running 18x8 ET45 215/40/18 Michelin PSS, lowered on JCW Pro coilovers (KW V1) and have not rubbing or clearance issues on my JCW. I know my wheels aren't exact to the Pro Race 1.2, but this should give you an idea that you'll be fine.
Old Mar 14, 2017 | 10:17 AM
  #378
elsnaibs's Avatar
elsnaibs
Thank you so much! I like to have some meat on my tires, and am adding the Eibach springs which only bring it down about an inch or less.
Old Mar 14, 2017 | 10:25 AM
  #379
jobexo's Avatar
jobexo
I have the Pro Race wheels in 17X8 with 215 tires and they fit. Clearance bet the rim and the shock tube is a hair but I haven't had problems. That 17x7.5 would be perfect!
Old Mar 14, 2017 | 10:36 AM
  #380
elsnaibs's Avatar
elsnaibs
Thank you! I was going to get the 17x8, but when I checked the rimstock fitment page (I guess they manufacture the Pro Race wheels), they listed a 17x7.5 that fits with no warnings about the fender. I'd rather play it a little safer (and lighter) with the wheel if possible, but finding that specific size has been tough.
Old Mar 15, 2017 | 07:40 PM
  #381
golferji's Avatar
golferji
Originally Posted by 02fanatic
Thanks...I was going to ask that again. Well, that setup appears to be the largest wheel & tire combo for the F56 JCW, unless you jump to the ACS 19" wheels.
I started a wheel & tire thread in early 2015 on the f56mini forum about how to make larger wheels & wider tires fit these cars. It's certainly not been easy getting answers has it? Thankfully, NM & TD stepped up to the plate! As I recall, a 235/35/18 tire size is a match for the original 205/40/18 tire OD, but that's just too much rubber!
I assume your clearance from the strut is very close but adequate right?
I remember you working on a proper fitmentnt for a long time, so congrats for leading the way for those of us following along!
Happy Motoring,
John
Hi John, reading your post, is there a 225 wide tire I can do on my F55 (non lowered)
I am looking to get new tires and wheels.
Old Mar 16, 2017 | 01:35 AM
  #382
al the mini man's Avatar
al the mini man
I run 18x8 et 45 with 225/40 tyres on my JCW,close but no rubbing.Car is on coilovers and had to adjust height as outside edge on tyre was catching,lifted it slightley-no rubbing.
Old Mar 16, 2017 | 09:43 AM
  #383
02fanatic's Avatar
02fanatic
My best advice would be to review this thread:
https://www.northamericanmotoring.co...nt-thread.html
Tons of information on here, along with other threads on this forum.
Generally though, I am of the opinion that 225's are pushing it a bit too far. If I change from my stock setup I will likely not go wider that 215's. The offset of the wheel is important, but generally ET40 to 45 seems to fit without issue.
Coilovers also help with clearance since they are narrower than stock springs.
Old Mar 16, 2017 | 01:55 PM
  #384
TheGeekGuy's Avatar
TheGeekGuy
Just as an aside - When upgrading to 18" wheels and tyres from 17" you must remember to do the math. The stock tyre size on 17" wheels is 205/40. Increasing the diameter to 18" requires reducing the shoulder height to 35 in order for the speedo to read correctly.
NOTE - This only affects the 18" from 17" upgrade.
And by the by I am running 225/35 on 18" with JCW Pro Coilovers and no rubbing.
Old Mar 16, 2017 | 02:45 PM
  #385
02fanatic's Avatar
02fanatic
The stock tire size for 17" wheels is 205/45 as I recall, not 205/40
Old Mar 17, 2017 | 08:37 AM
  #386
toyopet's Avatar
toyopet
That is correct. 205/40 for the 18" wheel.
Old Mar 17, 2017 | 08:40 AM
  #387
MiniF55's Avatar
MiniF55
35 is for 19 inches.
Old Mar 17, 2017 | 08:53 AM
  #388
TheGeekGuy's Avatar
TheGeekGuy
No, 35 for 18 if you want the speedo to be correct.
And I don't have access to my old 17" wheels as I am away on business. I guessed, and guessed wrong. I stand corrected.
Old Mar 17, 2017 | 10:52 AM
  #389
FDR's Avatar
FDR
Only if if you went with a 225 tire. Otherwise, 40 is correct.
Old Mar 22, 2017 | 06:31 AM
  #390
flyinlow's Avatar
flyinlow
(from tirerack.com)
Plus sizing your wheels and tires is the best way to improve both the performance and appearance of your vehicle. By using a larger diameter wheel with a lower profile tire it's possible to properly maintain the overall diameter of the tire, keeping odometer and speedometer changes negligible. By using a tire with a shorter sidewall, you gain quickness in steering response and better lateral stability. The visual appeal is obvious, most wheels look better than the sidewall of the tire, so the more wheel and less sidewall there is, the better it looks. Please contact our sales team for assistance in the proper sizing for your vehicle.
Old Mar 22, 2017 | 03:31 PM
  #391
02fanatic's Avatar
02fanatic
Originally Posted by flyinlow
(from tirerack.com)
Good info, but most enthusiasts know that already. If you want to really impress this group how about providing some details on wheels that fit the F56 JCW without spacers!? Not many options out there, so that kind of info from "the Rack" would be appreciated for sure!
Old Mar 22, 2017 | 03:53 PM
  #392
02fanatic's Avatar
02fanatic
Correct! 205/40/18 & 235/35/18 have the same O.D.
Old Mar 23, 2017 | 09:44 AM
  #393
docross42's Avatar
docross42
Did your JCW caps fit on your new wheels? Just curious, the car looks great
Last edited by docross42; Mar 23, 2017 at 09:45 AM. Reason: didn't attach relevant information from previous post
Old Mar 23, 2017 | 09:46 AM
  #394
docross42's Avatar
docross42
Did your JCW caps fit your new wheels (car looks absolutely stunning)?
Hi everyone,
i finally got my dreams wheels :
BBS SR 8x18 ET 45
YOKOHAMA Advan Fleva V701 205/40 R18
10mm spacer front
12mm spacer rear
Here in Italy is virtually impossible to use a different tire size, but fortunally in real is 215...
FAb
JCW Aftermarket Wheels-bbs-sr1.jpg JCW Aftermarket Wheels-bbs-sr2.jpg JCW Aftermarket Wheels-bbs-sr3.jpg JCW Aftermarket Wheels-bbs-sr4.jpg
Old Apr 18, 2017 | 04:55 PM
  #395
reRESERVEDMD's Avatar
reRESERVEDMD
Hey,
I just bent three of my JCW 17" wheels and need to replace them all.
I was thinking of running Team Racing 17x8 on 225/45 tires with ET45.... would that fit or would I be going too wide with the tire?
stock JCW with DDC, but want to get springs to lower it a little.
Old Apr 18, 2017 | 06:56 PM
  #396
mattkosem's Avatar
mattkosem
Assuming you mean Team Dynamics, that size should fit. 17x7.5 ET45 fits (http://www.minif56.com/forum/showthread.php?p=663138), so 17x8 should fit with more clearance.
--Matt
Old Apr 19, 2017 | 02:28 PM
  #397
reRESERVEDMD
--Matt
Wouldn't it start hitting the shock with 8" width and 225 tire?
Old Apr 19, 2017 | 04:21 PM
  #398
mattkosem's Avatar
mattkosem
Maybe. Looking at rimstock's fitment tool, it looks like they recommend ET45 for a 17x8, but tires might make that implausible.
A few posts back on this page, someone indicated them fitting with 215s. https://www.northamericanmotoring.co...ml#post4287384
Old Apr 22, 2017 | 04:24 AM
  #399
LormaD's Avatar
LormaD
Car my 18" on... looks lowered, but its not..
Old Apr 22, 2017 | 04:42 AM
  #400
docross42's Avatar
docross42
Looks awesome
Originally Posted by LormaD
Those wheels look awesome. What size, brand, etc tire did you use with them? I have the black cup spoke on mine and will be switching them out soon.
