JCW JCW Aftermarket Wheels
Old Mar 23, 2016 | 08:00 AM
  #276
Welcome.
Yes, we ship worldwide. Might want to check about " Awesome GTI " , they distribute for ECS in the UK, they might be able to help.
Old Mar 24, 2016 | 09:02 AM
  #277
1chaos52's Avatar
1chaos52
This has all been great info in this thread and very helpful.
I live in New Hampshire where the roads are crap, so am most likely going to stick to 17 inch wheels instead of going to 18's. I am still considering both options, but it just seems like the 17's are a better idea comfort-wise and in trying to avoid broken wheels due to potholes (which I am adept at avoiding, but accidents happen).
So I am thinking I will get the RSE 05 NM Engineering wheels and some Michelin PSS tires for summer, then keep the stock wheels and all season run-flats for the winter when I VERY RARELY drive the car, and only when roads are completely dry.
With that said, what else will I need? I know I can swap out the center caps between stock and NM but may get some for each set of wheels. What about TPMS stuff? Is there anything there that I need?
Old Mar 24, 2016 | 02:05 PM
  #278
mct's Avatar
mct
TPMS should be able to transfer from your OEM wheels to the NM wheels without issue.
Old Apr 8, 2016 | 07:18 AM
  #279
Kurtomouss's Avatar
Kurtomouss
This 1 Works
Originally Posted by al the mini man
Thank you for your reply unfortunatly i live in the UK,so if i ordered any wheel from the USA i would end up costing a fortune by the time i paid carriage and import duty.Just seeing what people are using.I know a couple of you guys have used Enkei and somebody tried TSW but these were in 17" not sure if they would fit in 18".
Enkei TS-10 in an 18 inch size works on the f56 JCW without a spacer. A centering ring came with wheels to fit a MINI.
Old Apr 8, 2016 | 11:32 AM
  #280
al the mini man's Avatar
al the mini man
Thanks for that info,i have just ordered a set of Oz Ultraleggera in 18x8 et 45.in matt black,cant wait to get them.
Old Apr 8, 2016 | 03:28 PM
  #281
02fanatic's Avatar
02fanatic
Hope those 8" wide wheels will clear the struts!
Old Apr 9, 2016 | 01:47 AM
  #282
al the mini man
I am running 18x8 wheels at the moment with 225 section tyres so should be ok.
Old Apr 9, 2016 | 12:57 PM
  #283
NHcountryman's Avatar
NHcountryman
Hey 1Chaos52 , have you mounted tires on wheels yet and put on JCW yet? was wondering your impression and drive feel with the NM rims? Any pictures?
Old Apr 9, 2016 | 01:00 PM
  #284
NHcountryman
Did you see the JCW Brake wheels fitment from NM ? They Have JCW in the title RSe05 and RSe12 JCW
https://www.ecstuning.com/Mini-2014-...market_Alloys/
Any feed back from any JCW owners on these wheels? Pictures?
Old Apr 11, 2016 | 10:56 AM
  #285
I know a couple people have them. Maybe they can post up. They are the same wheels as the others , just clears the big brakes
Old Apr 13, 2016 | 08:01 AM
  #286
preme123's Avatar
preme123
How many mm of space is there between the stock JCW spokes to the JCW brembo Calipers? They look like a very tight fit from factory?
What would be the minimum caliper clearance to the wheel spoke required ?
Old Apr 18, 2016 | 05:29 PM
  #287
GregoryK's Avatar
GregoryK
Just installed the RSe12's I've had sitting in the basement for the last 3 months! I'm using 12mm front and 15mm rear spacers. The tops of the wheels almost push past the top of the wheel wells. I love the look and think it really helps with the "gap". Do you guys think this is too far and should I reduce the spacers to 8mm front and 12mm rear (or some version of that). You need front spacers with these wheels.
Please feel free to comment. ;-)
Love the color of the rims with the car...
Old Apr 19, 2016 | 06:24 AM
  #288
Congrats on the NM wheels. Form that angle the fronts look to have a little more poke. But if you look straight down the side , it may be flush, cant tell at that angle, also if you lower the car it will change the looks.
Old Apr 27, 2016 | 08:17 PM
  #289
Sidewalker's Avatar
Sidewalker
Is anyone running the AC Schnitzer AC1 wheels seen here? I'm curious to see real life pics...I used to love the original BMW wheels they made, but I wonder what they look like on a MINI.
http://www.acschnitzer-us.com/en/min...56/wheels.html
Old Apr 29, 2016 | 06:52 AM
  #290
ryanschram's Avatar
ryanschram
AC literally has a banner of pics with the wheels on a F56 rotating a slideshow when you go to the link you posted.
Old Apr 29, 2016 | 11:07 AM
  #291
Sidewalker's Avatar
Sidewalker
I know, I was just wondering if anyone actually had them, and if there were different photos from the official PR shots on their website.
Old Apr 29, 2016 | 04:36 PM
  #292
toyopet's Avatar
toyopet
Does anyone know where to get the front splitter?
Old Apr 30, 2016 | 04:26 AM
  #293
mct's Avatar
mct
Would like to know too!
Old Apr 30, 2016 | 04:37 AM
  #294
02fanatic's Avatar
02fanatic
Front splitter looks nice....actually makes more sense than the optional side splitters from MINI! Looks like a direct bolt on.
Old Apr 30, 2016 | 05:00 AM
  #295
ASKtheteach's Avatar
ASKtheteach
Same here. It looks great.
Old Apr 30, 2016 | 07:27 AM
  #296
ryanschram's Avatar
ryanschram
+1 on the splitter.
Old Apr 30, 2016 | 09:36 AM
  #297
02fanatic's Avatar
02fanatic
Looks like the AC Schnitzer front splitter is $400!
http://preisliste.ac-schnitzer.de/ac...ngl_71037.html
Old Apr 30, 2016 | 12:35 PM
  #298
DunkM's Avatar
DunkM
Any chances the ACS splitter will fit non JCW front S grill!? If so this is perfect!!
Old Apr 30, 2016 | 02:03 PM
  #299
GregoryK's Avatar
GregoryK
Just scoped the instructions. There is a version for the Cooper and S.
That being said it really does not look like it fits that well. It is not a smooth transition from the from of the JCW to the splitter. It will definitely hold water and dirt in the space between the underside of the existing body and the splitter and would likely be impossible to clean. Check the instruction's and you will see what I mean. I really wanted this to work for me because I have PDC and the front sensor will not allow the JCW splitter on my car.
Old May 2, 2016 | 10:15 PM
  #300
Banner28's Avatar
Banner28
Does anyone live in Texas that would be willing to swap JCW Cross Spoke wheels with me so I have a set that will clear the BBK? I have a deep deep fear that the ones I bought from a buddy won't clear.
