Interior/Exterior Depo housing help! ( fog lights )
Old Jun 19, 2017 | 06:41 PM
Yupoong's Avatar
Yupoong
Hey guys! Been doing a lot of night time driving lately, and want to give my Depo housings a bit of a kick in the butt with how they work.
I've seen threads previously about the housings. I love them, they look great, and put out ENOUGH light with halogen bulbs. But due to my recent increase in night time driving, and with the amount of wildlife in my area, I was hoping to get some more info on retrofitting better (HID) projectors into them.
My main concern is that people said you will burn out the projectors with an HID kit due to them being made for halogen bulbs. This is where things got a bit confusing for me.
Does anyone have any write ups, or videos on swapping new projectors into these housings? I've been told you just unscrew the old ones, replace with new ones, and make a bracket, but without having anything to go off of, it seems to be a bit of a hassle to do.
Thanks for any help anyone can provide!
Old Jun 19, 2017 | 09:01 PM
X757XVeritas's Avatar
X757XVeritas
https://www.northamericanmotoring.co...-question.html
I gave you a write up already, as well as links to every thinh to buy, different price points, premade brackets, everything necessary for this to just be a screwdriver only job just about.
Old Jun 20, 2017 | 09:27 AM
Yupoong's Avatar
Yupoong
Do the brackets work with the acme projectors?
Old Jun 20, 2017 | 09:41 AM
X757XVeritas
As long as its h1 projectors yes
Old Jun 20, 2017 | 09:43 AM
Yupoong's Avatar
Yupoong
And how would you wire up the projectors to allow usage with factory high beams?
Old Jun 20, 2017 | 10:00 AM
X757XVeritas
Its all in that other thread already, im not typing all that again.
The projector does both the low and the high beam with a magnetically controlled shield. The other highbeam bulb in the depo lights is useless. Its just cosmetic at that point. But i did explain how to wire them as well as adapters linked in that other thread.
Old Jun 20, 2017 | 11:03 AM
Yupoong's Avatar
Yupoong
So what should I be expecting when removing the original projector? I'll unscrew the existing plate, and will it just slide out? Or is it put in a certain way?
How will putting the new one in go about? I understand you gave a list of parts. But not what actually happens.
Old Jun 20, 2017 | 12:40 PM
X757XVeritas
Old Jun 20, 2017 | 12:44 PM
X757XVeritas
Buy housings, projectors, and adapter plates.
Flip housing
take off bulb access
take 4 screws holding halogen projector in.
Take out halogen projector
Bolt adapter plate to hid projector
Stick hid projector into
put screws back.
Done!
Literally just 4 screws as long as its depo projectors.
Old Jun 20, 2017 | 01:02 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Do you have factory fogs ?
If so, I put a set of Xenon's (HID) inside the lower factory fog light housings and made huge difference....work awesome No dash lights either....
Old Jun 20, 2017 | 02:16 PM
X757XVeritas
No dash lights from an hid retrofit either, and i dont reccomend the fog light hid because hid have a warm up time, and its not healthy for them to cut on and off as often as it will since power is cut to the fogs when the hugh beams are turned on.
Old Jun 20, 2017 | 02:45 PM
Yupoong's Avatar
Yupoong
Yeah I have factory fogs, what set did you go with? Sounds interesting.
Old Jun 21, 2017 | 04:41 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Moving this to the Mod section, has some very good discussions that will help others in the future.
Old Jun 21, 2017 | 07:17 AM
Yupoong's Avatar
Yupoong
Flip housing
put screws back.
Done!
Just to double check before ordering, do the lightwerk brackets work with the acme projectors?
Old Jun 22, 2017 | 11:49 AM
X757XVeritas
Yep!
Old Jul 1, 2017 | 02:47 PM
Yupoong's Avatar
Yupoong
Yep!
What projectors did you use? Did you make your own mounting plate? I have the acme projectors, and the mounting plate you linked, and am unable to get the projector in with the plate on it
Old Jul 1, 2017 | 03:14 PM
X757XVeritas
You may have to slide everything into the housing loose then bolt the plate to the projector, then bolt that to housing.
pnwR53S
Apr 18, 2025 02:16 PM
K bye
May 24, 2018 10:38 PM
BoringR53
Oct 16, 2017 06:20 AM
embiggenedmini
Aug 27, 2017 05:58 AM
pizzaman09
Jun 19, 2017 10:31 AM
