Interior/Exterior R56 Pulsar Brake Light Flasher - Install
Old Nov 3, 2011 | 10:05 PM
89AKurt's Avatar
89AKurt
I installed the GoMINIGo Pulsar on my 2003 MCS. I just searched for an install for my 2007, and didn't find one.
I e-mailed them to verify it works on the R56. If it's a go, and I pull the trigger, will post pictures.
Old Nov 3, 2011 | 10:19 PM
MINIxB's Avatar
MINIxB
I'm pretty sure I saw a few R56 with this done at MTTS. I think it's neat I'm just not good with electrical stuff.
Old Nov 3, 2011 | 10:24 PM
89AKurt's Avatar
89AKurt
Thanks, can't imagine why it wouldn't work.
Old Nov 4, 2011 | 05:36 AM
yetti96's Avatar
yetti96
It just goes in-line of the two wires going to the 3rd brakelight. Will work on any light that I can think of.
Old Nov 4, 2011 | 06:21 AM
drsimmons's Avatar
drsimmons
I installed it on my 07 and it works. Be sure to verify where the unit will fit on the plastic housing (attaches with two faced tape supplied). I cut my wires too close to the light itself and the pulsar unit gets in the way of the mounting hole on the plastic. Should have cut closer to where the existing wires come out of the car body and spliced in there. Hope this makes sense. Basically, lay it out where you will attach the pulsar unit to the plasic before cutting.
Old Nov 6, 2011 | 08:57 AM
89AKurt's Avatar
89AKurt
Thanks!
Old Nov 23, 2011 | 12:26 PM
89AKurt's Avatar
89AKurt
Pulsar Installation For Dummies
I don't do this sort of thing for a living, so hope this helps others like myself.
The instructions that come with the Pulsar need clarification.
Another tool to have is small scissors (or an Xacto knife) to cut back the cloth tape on the wires. Also, a tool designed for wiring that crimps the straight connectors.
Taking off the trim, start in the middle and work towards the ends, there are four snap-ins. Just grab under the edges, don't need any tools.
http://www.flickr.com/photos/53074154@N00/6390659217/ http://www.flickr.com/photos/53074154@N00/6390659217/
Cut wires at least 1/2" past the snap-in.
Since I'm going to the effort to install this, I changed the Jumper J3 to "L" for maximum effect.
In my case, the yellow wire is the power (brown is ground).
I was concerned about clearance space, so stuck it as shown. If anyone successfully placed it between the 2 left snap-ins, let us know!
Old Nov 26, 2011 | 07:16 AM
valk009's Avatar
valk009
On the same topic, got the GoMINIGo Pulsar installed on my R56 but I cut the wire too short to the plug inserted into the 3rd breaklight. I managed a way to fix it but was wondering whether anyone know if you can get the plug? A link to a website or part number would be greatful!
Old Nov 27, 2011 | 03:00 PM
minirab's Avatar
minirab
I have one on my R53, it does get everybody's attention. Will also put
one on a R58 I will be ordering shortly.
Old Nov 27, 2011 | 10:19 PM
89AKurt's Avatar
89AKurt
Been there, done that (on so many projects).
I called the dealer about something else, parts department dude did a screenshot of the parts "book" and e-mailed me while on the phone. If your dealer won't/can't, tell them Scottsdale did.
Old Nov 29, 2011 | 05:03 AM
ice877's Avatar
ice877
do you happen to have that part number on the receipt if scottsdale was able to get it? Just trying to streamline the process when I order some parts from Sewell.
Old Nov 30, 2011 | 08:58 PM
89AKurt's Avatar
89AKurt
You asking about this, Can I convert rear fog lights into clear backup??
Otherwise, any dealer wouldn't carry the Pulsar, go to link on my first post.
Old Mar 17, 2012 | 01:13 AM
Peters Dad's Avatar
Peters Dad
Third Brake Light Pulsar
Pulsar
I successfully installed the Pulsar in my '06 JCW and it works. However, I too would like to maximize the pulsing as it's very short right now- maybe 4 blinks. I've read the directions over and over and looked at the unit over and over and still can't figure out how to "jump" or change the J3 Jumper to "L". Is there a simple explanation or directions that explain how to do this? Or do I need to call GominiGo?
Old Mar 17, 2012 | 05:49 AM
drsimmons's Avatar
drsimmons
^^Mine is only set at the 4 blinks and I to cant' figure out the
jump part. Instructions suck for us non-mechanical folks.
I'd like to increase my blinks also.
On the other hand, I was just happy I installed it and it worked.
Old Mar 17, 2012 | 12:00 PM
89AKurt's Avatar
89AKurt
It's been awhile since I did this........ the instructions are a bit difficult to decipher. For one, the drawing in the instructions seems to be upsidedown. The part is marked, but need a magnifying glass to see the letters. The 'jumper' is like a plug, be careful with tweezers, can break the plastic lip. There are 3 prongs on the circuit board, simply pull the 'jumper' and skip over a spot, then push back on.
Old Mar 17, 2012 | 02:59 PM
Peters Dad's Avatar
Peters Dad
It worked! I see now that the "jumper" is the little black "box". I was able to use the tweezers (good suggestion btw) like a wedge to get under the bottom edge of the little box and push it up enough I could get my fat fingers on it. The tweezers were too slick so wouldn't grab the box. But it slid off easily- I moved it over to the empty pin near the "L" along with the second pin and just slid it back on. Very easy. All works perfect now. Many thanks. The little tips sure help a lot. Now it's on to the "black plug" (sounds ominous) to make it into a running light and brake light. Not going to go the fog light route. Many thanks again.
Old Mar 18, 2012 | 03:16 PM
89AKurt's Avatar
89AKurt
You're welcome! I'm mechanically challenged myself, so glad I could help.
squawSkiBum
Oct 2, 2015 09:21 AM
skippermini
Aug 12, 2015 10:05 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
