Interior/Exterior Headliner DIY
Old Oct 2, 2019 | 06:16 PM
  #101
FatherG's Avatar
FatherG
Originally Posted by golden_child
Any tricks to not breaking the A-pillar?
Just be careful and don't snap too hard. I actually didn't remove the pillar completely. Just pulled the top away enough to get the headliner out.
Old Oct 2, 2019 | 08:57 PM
  #102
Husky44's Avatar
Husky44
I didn't touch mine. Headliner came out, and went back in without having to mess with them.
Old Oct 10, 2019 | 01:16 PM
  #103
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
Are there any clips on the B & C pillar covers that I need to worry about? Are those 2 easier than the A-pillar to remove or release?
Old Oct 10, 2019 | 01:25 PM
  #104
Husky44's Avatar
Husky44
I had no problem removing and replacing my headliner without removing ANY of the pillar covers.
Old Oct 11, 2019 | 01:16 PM
  #105
JAB 67's Avatar
JAB 67
Husky: sunroof or not?
Old Oct 11, 2019 | 02:29 PM
  #106
Husky44's Avatar
Husky44
Yes, sunroof.
My writeup:
https://www.northamericanmotoring.com/forums/how-to/341306-interior-headliner-replacement-for-r50-r53.html
Old Nov 11, 2019 | 08:04 AM
  #107
golden_child
Finally took the time and got the headliner out. What a pain in the a**. The hardest part was having the courage to pull the A-pillars. I ended up braking one plastic tab on the A-pillar but I think it's salvageable.
Headliner out:
A-Pillar Clips:
B-pillar:
C/D-pillar:
If you have a sunroof, don't forget to check the drainage tubes. The first pic shows mine disconnected and the reason my passenger floor would get wet when it rains.
Old Dec 24, 2019 | 08:36 AM
  #108
jcolletteiii's Avatar
jcolletteiii
Anyone ever use the grey headliner fabric from Joanne's? This stuff... https://www.joann.com/headliner-util...y/3496064.html
Can't get a sample locally and curious how it looks in car.
Old Dec 26, 2019 | 11:04 AM
  #109
jcolletteiii
Just went and picked up 2.5 yards of the gray stuff Joanne's has - using one of their easy to find 50%off coupons, it came out to $7.99 per yard. It is somewhat darker, but otherwise looks stock fabric-wise. I may have to pick up some vinyl dye/paint to match the sun visors and clock surround - we'll see how it looks when I'm done. Have to get the EWP conversion done first though.
Old Dec 26, 2019 | 03:21 PM
  #110
Blue R50's Avatar
Blue R50
I wouldn't bother dying the parts to match since it is unlikely that you will find an exact match to the headliner, and you will just have a different color mismatch! The headliner will fade a bit over time and probably come closer to the color of everything else.
For anyone doing this for the first time, my advice is to find a junkyard car and try to take it apart first. When I did that, I found that the rear quarter trim needs to be pulled back or removed to get to the B and C pillar trim retaining screws. Be very careful if you have the anthracite trim package as the trim parts in that color are hard to come by and expensive when you do. If you find a car with it in the junkyard, consider pulling the parts to have as spares. The pillar trims are a hard plastic that will crack easily if you try to bend them too much.
Old Apr 13, 2020 | 03:08 PM
  #111
RhinoEngler's Avatar
RhinoEngler
I need to do this as well. Has anyone ever used a Flag..I bough a huge British flag. Does anyone think I will run into a problem?
Old Apr 14, 2020 | 02:41 PM
  #112
Antroiny's Avatar
Antroiny
I just purchased a 2006 MCS JCW with sagging headliner, and this is one of the first things I'm going to try to address as I update the car. Quick question as you're working on this and taking everything out. I see all the airbags along the roofline, are you disconnecting the battery before you start working so that you don't accidentally deploy the airbags? Or am I being too cautious about this happening? Thanks!
Old Apr 14, 2020 | 02:48 PM
  #113
shrevemini's Avatar
shrevemini
Top Answer: 1
I did not disconnect the battery when I did mine.
Old Apr 15, 2020 | 12:38 PM
  #114
ItJustDiz's Avatar
ItJustDiz
Rhino, using Old Glory would be against the flag code, somewhat frowned upon. I also think a flag would be a bit too thin for the glue to adhere and still look good. Just my .02
Thanks everybody for your input on this thread, I'm about to tackle this while we SIP.
Old Apr 30, 2020 | 04:53 PM
  #115
RhinoEngler
finished it..thanks for all the help on here.
Old Aug 3, 2020 | 05:17 PM
  #116
r53racer's Avatar
r53racer
Has anybody tried painting directly over the yellowish cardboard with some kind of textured paint instead of wrapping it with fabric? I was thinking of doing this and if it turns out ugly, then I can always wrap it. I would first like to know if someone has done it or if someone thinks its a bad idea. Thanks,
Old Aug 4, 2020 | 03:30 AM
  #117
JAB 67's Avatar
JAB 67
I don't mean to hijack this thread, but I have a question: in a Gen1 with sunroof, with the headliner removed, are the roof rack captive nuts visible?
Old Aug 19, 2020 | 02:04 AM
  #118
thevastdifference's Avatar
thevastdifference
Went to Joann Fabrics today, found a Marine Vinyl material - no foam backing. Is that suitable to use for headliner material?
Old Sep 7, 2020 | 11:39 PM
  #119
thevastdifference
Nice job! Gonna attempt this for the first time next week.. how to remove the clock? does it rotate? pop off downwards?
Old Sep 7, 2020 | 11:53 PM
  #120
shrevemini's Avatar
shrevemini
Top Answer: 1
To remove clock you push forward the pull down. If you have a sunroof. You can reach in between to liner. You will fill the metal spring tab of the clock. Push towards the windshield an clock will release. There is 2 plastic post on the opiset side. Be careful to tilt at a angle when removing. Do not pull straight down.
Old Sep 19, 2020 | 02:45 AM
  #121
thevastdifference
Thank you! I got it off easily thanks to the sunroof!
Old Oct 6, 2020 | 09:48 PM
  #122
ItJustDiz's Avatar
ItJustDiz
I finally found the time to do this and ran into B pillar issues -
I was able to get the headliner out, but the B pillars never wanted to budge. I was able to wiggle the edges out from under with A and C pillars loose, but I'm worried about getting the headliner back IN without the B pillars loose. I have seen posts and videos claiming to never break any or the pillars loose - anyone have experience with this issue?
I tried pulling out/up, out/down, and popped the lower dark plastic piece loose first, nothing seemed to work.. I was able to snap a few of the inner "fins" off, but not break any clips loose.
Old Oct 6, 2020 | 10:13 PM
  #123
Husky44's Avatar
Husky44
I removed and replaced the headliner without removing any of the pillar trim. I was able to tuck the headliner back in without any difficulty.
Old Nov 1, 2020 | 06:29 AM
  #124
daviday's Avatar
daviday
I'd like to replace the headliner in my S soon. I recall on the r50, it felt as if I was about to break the pillar off to get them to budge. Do you have a sunroof?
Old Nov 1, 2020 | 07:22 AM
  #125
Husky44's Avatar
Husky44
Yes.
zach999
Oct 5, 2020 07:27 PM
Bubbleboy
R55 :: Clubman Talk (2008+)
45
Dec 12, 2017 11:55 AM
orangecrush
Oct 10, 2012 06:54 PM
bmwproboi05
29
Dec 12, 2009 07:43 PM
ChubbyChecker
Jan 3, 2008 12:14 PM
