F55/F56 Here we gooooooooooooooooooo!!!!!!!!
Old Jun 10, 2023 | 07:20 PM
Mr.Slowly's Avatar
Mr.Slowly
Hello ALL,
I replaced the spark plugs on the 2017 F55S. Afterward, on acceleration, the stuttering and sputtering started. I got the danger drivetrain warno and the scanner showed P0301, cylinder 1 misfire. I double-checked the gap and torque, all in the green. What the heck?? I put new coil packs on today and I can drive around slowly, but when trying to accelerate, more of the same. The only things that I changed were the plugs and coil packs. No issues before the change. I've not had any problems in the past with a spark plug change on any auto, so I am kinda stumped. Thank you for any advice/help.
Edit: I did get a P0456 code 2 weeks before I changed the plugs.
Old Jun 11, 2023 | 08:34 AM
thefarside's Avatar
thefarside
P0456 is the fuel tank purge test failure code (tank has an air leak - google it). Most likely fault is the gas cap. Resolution: Remove cap, replace, run car, some number of restarts later (don't know how many), code should self reset. If code continues buy new cap. P0456 code is likely not related to the misfire.
Misfire: Quick and dirty takeaway from your description is that you M'ed something up during the sparkplug replace.
Go back: remove all "new" plugs, reinstall the old ones. Does misfire problem return? If Yes -> see mechanic; If No -> post pictures here of the new plugs that misfire.
Additional diagnostics: swap #1 & #2 coils and or plugs (I don't expect that to produce a useful finding) but you need to do it anyway to rule out the obvious. If misfire moves from #1 to #2 then coil or plug is bad.
More likely cause: You messed up or disconnected or did not properly reconnect something in the vicinity of the coils.
Hope that helps!
Old Jun 11, 2023 | 08:35 AM
Mr.Slowly's Avatar
Mr.Slowly
You helped very much. THANK YOU!
Update: switched the coil for cylinders 1&2, still the same. Then switched spark plug 1&2 and now the #2 cylinder misfires. I've never had a new, bad spark plug before. If this is happening to anyone else, try those steps and see if you have a bad, new spark plug.
Old Jun 12, 2023 | 03:27 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Where do is you buy the spark plugs? Whether new plugs have been faulty in the past or not, it’s happening now. Get a new set of plugs from a reliable shop and try again.
Old Jun 12, 2023 | 06:55 AM
thefarside's Avatar
thefarside
New one for me, I cannot recall ever having a new-out-of-the-box plug defective, ever.
Suggest everyone do this search!: NGK counterfeit plugs
Best guess is the OP has a set of counterfeit plugs.
Old Jun 12, 2023 | 07:23 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Yes. I would not purchase car parts on Amazon, unless it is a non-critical part, link sway bar end link or something like that. (even then, I would be wary) You can get genuine NGK spark plugs here - https://www.ngk.com/ Considering cost is relatively low, it's not worth it to me to save by shopping around for spark plugs.
Old Jun 12, 2023 | 08:01 AM
thefarside's Avatar
thefarside
OP, please let us know what your source for the plugs was.
Old Jun 12, 2023 | 11:31 AM
Mr.Slowly's Avatar
Mr.Slowly
I bought them from Rock Auto. Bought many parts for various cars from there never any problems.
Old Jun 12, 2023 | 11:51 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
RockAuto is generally pretty good, but not flawless. I've received completely wrong parts from them in the past. I would still give consideration to a new set of spark plugs, especially since your troubleshooting narrowed it down to a faulty one..
Old Jun 12, 2023 | 12:42 PM
Yep, check the fitment, I see overlap on those general parts sites, You pick an F56 and they show you r56 parts as they get data from Aies and Pies and its not right for MINI sometimes.
I know the newest part manufacture on MINI spark plugs is now Champion france. So they have gone to those as Genuine MINI branded parts.
https://www.northamericanmotoring.co...uine-mini.html
Old Jun 13, 2023 | 03:15 PM
Mr.Slowly's Avatar
Mr.Slowly
One bad spark plug replaced and we are back to 100%.
Old Jun 13, 2023 | 03:58 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Excellent!
bq966R56
Jul 28, 2021 04:19 PM
seamusnh
Mar 14, 2016 07:43 AM
blakeslee_a
Dec 26, 2012 04:56 PM
FUBSZ
Dec 14, 2011 06:36 AM
Johan
Feb 16, 2006 12:51 PM
