F55/F56 Coding parameters that actually work using Bimmercode Expert Mode
Old Jan 14, 2020 | 02:58 PM
  #101
R53hyperblue's Avatar
R53hyperblue
Hi anyone have luck to see video in a Mini F56 JCW 2020 ?, I cant see it, please help!!
Old Feb 22, 2020 | 10:55 AM
  #102
HugoSnel's Avatar
HugoSnel
Coding start mode
Originally Posted by trentiles
Have you tried the coding so that the "mode", sport, normal, green is retained when you turn off/on the car?
works perfectly.
Old Aug 22, 2020 | 12:58 PM
  #103
Fra881's Avatar
Fra881
Does anybody know how to disable coasting/sailing in mid mode?
I guess expert mode is needed but I don't know which options to look for
Old Aug 23, 2020 | 02:31 AM
  #104
HugoSnel's Avatar
HugoSnel
Please explain what you mean by coastal/sailing mode???
We are talking about cars not sailboats HIHi
Old Aug 23, 2020 | 02:36 AM
  #105
HugoSnel's Avatar
HugoSnel
Hello,
Is there a COMPLTE list of ALL coding options normal and expert mode somewhere to be found??
Old Aug 30, 2020 | 12:36 PM
  #106
TVPostSound's Avatar
TVPostSound
Originally Posted by HammerM
Confused why you used "Expert" mode as all your coding, except the rear fogs, is in the standard selection group with no need for "expert" section. That is unless your ECU options are much more limiting than on my 2016 F26 X4M40i #1. Which ecu was the rear fogs in?
Because when I wrote this, Stephan had not included these in his shortcuts.
Old Sep 2, 2020 | 08:33 AM
  #107
c5driver2's Avatar
c5driver2
I have a 2019 F55 MCS and unlike what was on the website, bimmercode didn't display the video option, when I went into the app. I sent them an email requesting clarification and this was their reply:
"the headunit in the car is not able to play videos at all if the coding option is not showing up."
I have to check and see if the headunit isn't capable of playing video...
Old Sep 2, 2020 | 08:34 AM
  #108
c5driver2's Avatar
c5driver2
Originally Posted by co0p3r
I ordered a VeePEAK from Amazon as it was on the suggested list from the App maker - I want to give this whole coding thing a try.
Anyone else use the VeePeak Bluetooth with an iOS device?
I run this same setup. No worries.
Old Sep 12, 2020 | 01:15 PM
  #109
EmedpaDHSc's Avatar
EmedpaDHSc
I have a 2017 Clubman S all 4. Any way to code the extra rear lights to come on when the front fog light button is pushed? I don't need a second button. If one set is on I want them both on. Kinda silly that the lights are installed, but inactive,
Old Sep 25, 2020 | 08:23 AM
  #110
Eric_Rowland's Avatar
Eric_Rowland
Not that I know of. The coding just tells the BCM what you want it to do. Your change would require a change to the BCM, vs. just letting it 'know' the switch is there.
Old Dec 14, 2020 | 04:19 PM
  #111
Mini.Wrench's Avatar
Mini.Wrench
Originally Posted by orangedrink888
Anyone know the coding to disable the front parking lamps?
The ones within the fog light housing. Has anyone figured this one out?
Old Dec 14, 2020 | 04:54 PM
  #112
Walt's Avatar
Walt
The Daytime Running Lights? To turn those on/off (enabled/disabled), its in the Settings menu and then Lights.
Old Dec 15, 2020 | 02:28 PM
  #113
Mini.Wrench
Thank you Walt! I'm not sure how that one slipped by me. The DRL setting is in the exact location you mentioned above. However it doesn't quite solve what I'd hope to achieve. I only want to disable the front DRL's (the ones housed with the fog lights). I would like the front DRL's always off and the rear DRL's always on regardless of if the headlights are on or off. I was hoping I could figure out how to do this in expert mode. I believe only the rear DRL settings are in basic mode. I've been meaning to poke around in expert mode but I haven't had a chance yet.
Old Jul 22, 2021 | 12:08 PM
  #114
hndle's Avatar
hndle
Lamp error
Can anyone tell me how to disable warm front fog lamp check? My lamps appear to work fine, but I get a bulb error on the computer display whenever I switch on the fogs.
2011 S R56
Old Jul 26, 2021 | 09:53 AM
  #115
ASKtheteach's Avatar
ASKtheteach
My 2015 came with halogen headlights and I replaced them with LCI style LED units I got from AliExpress. All other exterior bulbs were replaced with LEDs. I coded the fog lights to work as cornering lights and the fog light for the particular side comes on when turn signal is activated. The coolest part is that they become adaptive as well. Turning the steering wheel a few degrees in each direction causes the fog light on that side to come on, allowing better vision around curves and corners.
Old Jul 27, 2021 | 06:37 AM
  #116
hndle's Avatar
hndle
Thanks ASKtheteach.
Old Jul 27, 2021 | 11:19 PM
  #117
mwayne5's Avatar
mwayne5
Edit: nevermind, found it on a different forum.
First, please tell me how you did this as this sounds amazing. Secondly, do the fog lights work as normal when turned on with the normal button?
Old Apr 17, 2022 | 04:41 PM
  #118
VelvetFoot's Avatar
VelvetFoot
I got my 2022 F56 4 door a couple days ago. It replaced a similar 2017. On my 2017 I remember downloading something or other to my laptop and hooking up a cable and sweating bullets that nothing would go wrong. Today I downloaded Bimmercode for 45 bucks, hooked up my bluetooth OBDC and it was off to the races. Only did basic stuff, but very easy. Some of the OEM stuff was quite annoying. Everything worked except tire temperature, which I guess the sensors don't do. It hasn't been that long, so I guess a setting could revert-we'll see.
I did:
-Auto start stop disable for eco mode, what is ecopro and ecopro+; I chose ecopro
-Auto start stop remember last setting
-Driving Mode-remember last mode
-Startup warning-disabled
-Convenient closing-close windows with remote
-Disable window closing when a door is opened[
-Display full text messages
Any other suggestions?
Old Apr 18, 2022 | 09:38 AM
  #119
Fra881's Avatar
Fra881
Can you please share how?
vetsvette
3rd Gen FAQs
433
Oct 12, 2025 04:42 PM
jimboraver
F54 :: Clubman Talk (2015+)
Dec 2, 2018 08:09 PM
Detail40
May 16, 2018 05:32 AM
heiker
Electrical
May 14, 2014 03:14 PM
burley
Electrical
16
Sep 11, 2007 10:51 AM
