Electrical Front fogs retrofit struggling - help needed
Old May 11, 2014 | 12:46 PM
heiker's Avatar
heiker
Lightbulb Front fogs retrofit struggling - solved
As written in the thread of AHL Xenon retrofitting, I have retrofitted front fog lights. I have guide wires to footwell module, added plugs on the lights side and codded the 'fog' VO option (to FRM and CAS). I have default all modules (except ABG, RAD2 and DCS). When I pull the fog switch, the front fog indicator light up on the speedometer, but fogs does not lights up (these are LED fogs from the official Mini LED DRL retrofit set). I have checked the output signal from the FRM module and it seams, that FRM does not switches on the light (do not know why).
What might be a reason? Do I need to upgrade FRM to other HW version?
Old May 14, 2014 | 03:14 PM
heiker's Avatar
heiker
OK, here is the final solution.
I appears that I had low-end FRM module, which does not supports front fog lights. After upgrading to High FRM version, fogs started to work.
iggi
18
Feb 9, 2026 01:00 AM
wkp1219
Nov 13, 2015 07:52 AM
Zettinger
Aug 25, 2015 04:04 PM
