F55/F56 Mini coding/programming
Old Apr 9, 2018 | 06:37 AM
  #901
vetsvette's Avatar
vetsvette
Moderator
If you have the app, there's no reason not to try it. On the new cars it is no longer on the shifter "ring". I believe it is now a toggle switch in the row with the ignition switch.
Old Apr 9, 2018 | 06:43 AM
  #902
AJT13N's Avatar
AJT13N
Thanks it doesn't have the toggle either it's a MY17 so would be a dial one ..... it doesn't have the driving modes and now the Mrs knows it can pop n bang in Sport but can't switch modes she's sent me on a mission to see if we can access it.
might just have to have a play with Bindfire and see what's in there.
Andy
Old Apr 9, 2018 | 10:13 AM
  #903
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
Yeah I say give it a shot. If anything, if it doesnt work it wont do anything. You always have a backup to fall back on too
(disclaimer .... dont blame me if you screw anything up )
Old Apr 10, 2018 | 05:34 AM
  #904
DarkMiniCooperS's Avatar
DarkMiniCooperS
Is it possible to enable paddle shifters and sport transmission with new Bimmercode update?
Old Apr 10, 2018 | 06:30 AM
  #905
xentar's Avatar
xentar
I sent an email to BimmerCode support last week about the sports transmission and Stephan replied that "transmission ECU is not supported at the moment".
I think I read it here somewhere that you can use BimmerCode to activate the paddles.
Old Apr 10, 2018 | 04:04 PM
  #906
NBCGLX's Avatar
NBCGLX
Originally Posted by kfmuller
Mine have the separate functions like the video right out of the box. The only coding I did was to remove the warning messages in the car for the brake and indicators since they are now LED. I coded each to LED and to not check either when cold or warm. So, I don't get any warnings that I have bulb failures, and the lights don't flicker since the car no longer checks those lights.
Interesting. There's someone else who retrofitted the UJ tails to his U.S. car and they function very oddly. Did your car already have the LED tails (although, the pre-LCI tails were really only partial LED)? I'm wondering if that's the difference.
Old Apr 11, 2018 | 08:09 AM
  #907
boki's Avatar
boki
^Yes, as previously mentioned in this thread, there are two different part numbers for UJ tail lights, kfmuller got the EU version of UJ tail lights and fitted them to his US car and they function fine, same as in EU. I got the US version of UJ tail lights and fitted them to my US car and they require some coding to make them work as intended. When you activate a turn signal and then apply brakes the turn signal turns solid red instead of blinking - that's the only thing that needs to be fixed.
Old Apr 11, 2018 | 08:19 AM
  #908
vetsvette's Avatar
vetsvette
Moderator
Okay folks. This is becoming more about parts compatibility and function than coding. I suggest you start a dedicated thread for the subject rather than continuing in this thread.
Old Apr 11, 2018 | 08:36 AM
  #909
boki's Avatar
boki
I'm sorry but I'd have to respectfully disagree, there's no physical difference in the connector - both part numbers have the same connector so it must be a coding that's different to make them work. Us with US spec UJ tail lights need help with the coding and that's why I came to this forum and this thread - to ask for help with the coding. I didn't want to start a whole new thread about it since we have so much explained in this thread already but if you want me to I'll open up a new thread just for this?
Old Apr 11, 2018 | 09:39 AM
  #910
8Balls's Avatar
8Balls
Never done any coding / programming on a 2014 F56 Cooper S so am looking for advice on how to permanently disable the Dynamic Damper Control, I was hoping it was possible
Any advice much appreciated
Old Apr 21, 2018 | 09:02 AM
  #911
Minims's Avatar
Minims
Hello,
Does anyone have tried to code VO 6NT (mini connected xl) in a HU_ENTRYNAV with 6UM (Naviguation) and 6NM (Mini Connected) ?
Thanks.
Old Apr 21, 2018 | 01:09 PM
  #912
TVPostSound's Avatar
TVPostSound
Why would you do that, other than getting non DDC struts.
In which case its a hardware bypass.
Old Apr 27, 2018 | 06:43 PM
  #913
grh372's Avatar
grh372
Union Jack lights are now coded and working properly
I got ahold of Okee from codemycar.com. He tapped into mine over the internet and worked till he got it right. It now operates as it should here in the United States. If anyone needs help he can get it done for a great price. Contact Okee and let him know I sent ya.
Old Apr 27, 2018 | 06:48 PM
  #914
grh372's Avatar
grh372
Old Apr 28, 2018 | 08:18 AM
  #915
DunkM's Avatar
DunkM
Question for esys. What happens when you code fdl from the right click menu instead of read coding data. It seemed to reset all my programmed changes, does it do anything else?
Old Apr 29, 2018 | 05:13 AM
  #916
NBCGLX's Avatar
NBCGLX
That's great! So presumably he knows how to separate the brake/turn functions for the US, like they are in Europe/UK from the factory?
Old Apr 29, 2018 | 06:43 AM
  #917
grh372's Avatar
grh372
Yes as you can see they now work great.
Old Apr 30, 2018 | 02:36 PM
  #918
JosephM635's Avatar
JosephM635
JCW Tach and Gear Selection in HUD
I can confirm that this coding works for the:
HU_NBT > EXPERT MODE > HUD_SPORTANZEIGE_ENABLE, HUD_SPORTANZEIGE_FES_ENABLE, and HUD_SPORTANZEIGE_MS_GASSE_ENABLE to AKTIV.
Code
Then
KOMBI > EXPERT MODE > FZG_Aussttang,HUD _SPORTANZEIGE_ENABLE, HUD_SPORTANZEIGE_FES_ENABLE, and HUD_SPORTANZEIGE_MS_GASSE_ENABLE to AKTIV.
Code
So Cool!
I had to cycle the ignition twice to get rid of the error message.
Old Apr 30, 2018 | 02:41 PM
  #919
DunkM's Avatar
DunkM
Updates for everyone interested in UJ taillights.
https://www.northamericanmotoring.co...ml#post4386748
Old Aug 23, 2018 | 12:50 PM
  #920
Loccusst's Avatar
Loccusst
Is the only way to know what the different splash screens are is to just enable them one by one? I was wondering which one is for the John Cooper Works.
Old Aug 30, 2018 | 09:36 AM
  #921
minicooperjp's Avatar
minicooperjp
On my Mini variant 7 is the JCW splash screen
Old Sep 28, 2018 | 01:17 AM
  #922
clue's Avatar
clue
Anyone know if it's possible to get the JCW tach and gear HUD display on a F55S. Reason I ask is because there is no F55 JCW...
Old Nov 6, 2018 | 04:01 PM
  #923
MovieBoy's Avatar
MovieBoy
For retrofit of UK UJ Tail Lights on my 2015 US Mini Cooper S, I needed to code the following:
Rear left and right LED turn signals:
BDC_BODY / 3061 / FRA_H_L_KALTUEBERWACHUNG change to nicht_aktiv
BDC_BODY / 3061 / FRA_H_L_WARMUEBERWACHUNG change to nicht_aktiv
BDC_BODY / 3061 / FRA_H_L_IS_LED change to aktiv
BDC_BODY / 3061 / FRA_H_R_KALTUEBERWACHUNG change to nicht_aktiv
BDC_BODY / 3061 / FRA_H_R_WARMUEBERWACHUNG change to nicht_aktiv
BDC_BODY / 3061 / FRA_H_R_IS_LED change to aktiv
Rear Lights:
BDC_BODY / 3061 / BL_L_KALTUEBERWACHUNG change to nicht_aktiv
BDC_BODY / 3061 / BL_L_WARMUEBERWACHUNG change to nicht_aktiv
BDC_BODY / 3061 / BL_L_IS_LED change to aktiv
BDC_BODY / 3061 / BL_R_KALTUEBERWACHUNG change to nicht_aktiv
BDC_BODY / 3061 / BL_R_WARMUEBERWACHUNG change to nicht_aktiv
BDC_BODY / 3061 / BL_R_IS_LED change to aktiv
Rear Brake Lights:
BDC_BODY / 3061 / BFD_L_KALTUEBERWACHUNG change to nicht_aktiv
BDC_BODY / 3061 / BFD_L_WARMUEBERWACHUNG change to nicht_aktiv
BDC_BODY / 3061 / BFD_L_IS_LED change to aktiv
BDC_BODY / 3061 / BFD_R_KALTUEBERWACHUNG change to nicht_aktiv
BDC_BODY / 3061 / BFD_R_WARMUEBERWACHUNG change to nicht_aktiv
BDC_BODY / 3061 / BFD_R_IS_LED change to aktiv
This removed the warning message in the dash and the flicker on the lights at startup. The UK version of the UJ lights function without additional programming.
Old Nov 6, 2018 | 04:13 PM
  #924
DunkM's Avatar
DunkM
If you installed the amber turn signal UK lights your emergency brake force display is now incorrect, and possibly dangerous.
Old Nov 14, 2018 | 05:05 PM
  #925
mouh60's Avatar
mouh60
I just installed the UK version of the UJ taillights on my 2017 US F56 MCS. They work as advertised. The only thing that needed coding was the brake light malfunction warning that came on. I had to code out the voltage monitoring for the L & R rear twilight brakes. I did it with Carly and everything is perfect now. Also coded the BFD to activate at 30 miles and got rid of that stupid disclaimer. Works like a charm.
Been looking for a method to code the turn signals to work "sequentially" for lack of a better word. I saw a video (which I can't find any more) on youtube of a guy in Japan that did this. It looked wicked.
