F55/F56 turbo
Old Aug 26, 2014 | 02:39 PM
2014blackroof's Avatar
2014blackroof
turbo
Does the turbo on the F56 kick in right away? Or do you have to be going a certain speed/RPM for it to fire?
Old Aug 26, 2014 | 03:02 PM
lsmith42's Avatar
lsmith42
it is always spinning, but this engine develops boost quickly and holds quite well (8 psi... no spikes)
Old Aug 26, 2014 | 03:46 PM
yardstick57's Avatar
yardstick57
You can't tell it is a turbo as there is no lag. The car pulls from off idle to redline.
Old Aug 26, 2014 | 05:19 PM
tripleTurbo's Avatar
tripleTurbo
The base boosts to 8psi? Will be interesting to raise it to 12-15. Should be ok with 93 octane.
Old Aug 26, 2014 | 06:09 PM
Chazman's Avatar
Chazman
Sounds like from 80's!
I remember test drivng a brand new 1988 MX-6 Turbo with a huge turbo lag. I step on the gas pedal to minimum 3-4000 rpm to spool up the turbo and then the boost kicked in (and then a huge torque steer would follow - hold onto the steering wheel tight!). No such thing on this B48 twin-scroll turbo setup - it's (almost) instant, smooth and very sweet!
Old Aug 26, 2014 | 08:27 PM
2014blackroof
Yeah that's why I ask, because it has absolutely no lag whatsoever. The thing just takes off. Happy to say this is my first turbo car ever and man am I loving it! always good explanations on here. thanks fellas.
Old Aug 27, 2014 | 07:01 AM
r33's Avatar
r33
You can do that with BMS JB4 Stage 1 already.
It gives you an additional 2-3psi. But with the power to weight ratio, that much gain is very noticeable.
Old Aug 27, 2014 | 08:32 AM
Danger Dan's Avatar
Danger Dan
Kinda crazy they are only running 8psi stock in these turbos. Shows how downtuned the motors really are. I remember my chipped mkv gti was hitting peak boost levels around 22psi...
I'll be curious to see some numbers when bms makes a more aggressive tune for these cars or a stage 2. I would think with an intake, decatted or high flow cat exhaust, and the right tune this thing should be in the mid to upper 200hp range.
Old Aug 27, 2014 | 01:02 PM
Chazman's Avatar
Chazman
Yes, 2014 MCS B48 is a detuned 2.0 turbo motor in today's standard. It even makes less peak hp than 1.6 turbos like Fiesta or Veloster which makes around (claimed) 200 hp. Even so, all knowing that, I would still buy 2014 MCS all over again. Think about it, how often do you hit the peak hp of your car in your everyday driving?
Look at the B48's 0-60 mph time which is not too shabby at all. It's got a pretty thick low end torque that pulls quite nicely barely from the idle rpm to all the way to the redline. I really want to see the dyno graph showing hp/tq vs rpm of this motor.
Old Aug 27, 2014 | 02:27 PM
F56 I believe its quick, like no lag, but the boost numbers are low, I also believe so the engine as to last longer and less problematic. Also might be for fuel efficiency ? That means there is room for more boost in one way you look at it.
The revised Aisin Auto trans and the current set up make shifting pretty smooth even under hard engine loads.
NYMADMINI
Dec 14, 2016 02:33 PM
GAT
Oct 4, 2015 07:27 PM
Oct 1, 2015 12:13 PM
M7Speed
Oct 1, 2015 07:05 AM
EVMini
Sep 28, 2015 10:20 AM
