F55/F56 Shift boot and knob came off
Old Jul 31, 2014 | 01:04 PM
David Cottrell's Avatar
David Cottrell
Shift boot and **** came off
I finally got enough miles on my car to start some very spirited driving. I was giving a friend a ride when I wound it up in first and slammed second gear. Mind you, I am a very small person 125lb soaking wet and I didn't even slam it that hard. Upon slamming the gear, off comes the **** and boot exactly like indicated in consumer reports article. I was shocked when it happened and needless to say, very embarrassed.
Has anybody else experienced this yet?
I am thinking of going with a Whalen because it actually gets mounted instead of a ball basically just sitting on the end of the shaft.
Old Jul 31, 2014 | 04:12 PM
MINIwuff's Avatar
MINIwuff
There is a service bulletin for that. Please see your dealer.
Old Aug 2, 2014 | 05:36 PM
zwazoo's Avatar
zwazoo
Pulled mine off on purpose while sitting in my driveway. Not really as hard as I would have expected. Would be interested in what the service bulletin does to stop it. Personally as I'm updating to a Whalen **** soon, the relatively easy removal is appreciated. Maybe it is my shifting pattern, but I can't really see it happening to me while shifting. I have tried by the way, 300lb dry
Old Aug 2, 2014 | 11:08 PM
David Cottrell
I guess I am a hard shifter. My old 89 mustang that I built from scratch ended up having a bent shift fork from going into third way to hard. Some short throw kit solved that problem (and a new transmission.)
Old Aug 3, 2014 | 02:54 AM
deovolens's Avatar
deovolens
Always threat a car gently like a lovely wife. I had never such a problem with dozens of cars and my weight is "dry" 240 lb with a BMI of 24.
Just glue it back with epoxy.
Old Aug 3, 2014 | 03:02 AM
D.D.'s Avatar
D.D.
Keep "slamming" the gears cowboy.....Your transmission problems are yet to come...
Old Aug 3, 2014 | 08:53 AM
David Cottrell
I agree "slamming" gears is definitely going to cause issues long term, but I have done it once since I got the car... The time the boot flew off. And I use the term "slamming" very loosely.
However... A shift **** that simply slides off with very little force is definitely a problem.
Old Aug 3, 2014 | 10:25 AM
zwazoo's Avatar
zwazoo
Agreed, when I pulled mine off it really wasn't hard. It is all a leverage thing with it coming off easily, the pressure I applied is different than my shifting pattern, but I can see where a different shifting pressure could very easily cause the thing to come off.
PsychoRallye
21
Feb 17, 2019 06:08 AM
gar56
Nov 15, 2016 06:41 AM
HK_MCS
R58 :: Coupé Talk (2012+)
Oct 4, 2015 08:03 PM
MINI Stupor
Oct 1, 2015 11:36 AM
kevinlhr310
Sep 27, 2015 02:31 PM
