F55/F56 Week 27 build -- this is your status thread!
Old Oct 14, 2014 | 11:43 AM
  #1076
TheBigNewt's Avatar
TheBigNewt
Originally Posted by Rocket_man
- Our tires are not Run Flats. We got the optional 17" wheels and the web site says they come with Performance Run-Flats. We have new Michelin Primacy 3 Green X tires. We went to Discount Tire to get a road hazard warranty but they were not in their system. I told him they were run-flats but there are no markings on them. He called Michelin Tech Support and they confirmed they are not RFT. I found them on-line. This is a special tire made for BMW. The web site says they are not RFT. The dealer is going to look into this too. Maybe they are so new they are not yet marked? The dealership tried to tell us we didn't order RFT. I told them there was nothing to order, they came with the upgraded wheels. We'll see. The Michelin's aren't bad, but RFT are more valuable and possibly helpful if my wife gets a flat somewhere.
- The car has a spare. It is tucked up under the car, held by a bolt under the jack kit. Now if you really had to change a tire with that kit good luck! The lug wrench is pretty short and we all know how much torque is on those things. But the biggest problem is that there is NO WRENCH TO LOWER THE TIRE.??? At least not that I saw. The nut is smaller than a lug nut (wouldn't it have been smart to make them the same). So I need to search this out. So if the spare tire kit is worthless it is all the better to have RFT even if they are more expensive and louder. But the 2014 we test drove back in April seemed to ride very well and I assume those were RFT (they were 17").
You are the first person I've heard of that got non RFs on 17" rims. They usually only come with 15" rims. That's weird, especially since you didn't want non-RFs in the first place. I'd make them swap the tires, but I'm not sure where that leaves you with a spare. I has to be a donut spare right? Very unusual. BTW runflats cost about double non-RFs.
Old Oct 14, 2014 | 12:14 PM
  #1077
mikeymike1985's Avatar
mikeymike1985
Originally Posted by hrdcorgrl66
I was given 10/14 as an estimated delivery date too. 10/14 is here and my car is still at the port.
Mine supposedly was already released to Waggoners trucking the day before yesterday but who knows if that is actually the case. I'm hopeful :-) I hope yours arrives quickly. Did mini USA tell you over the phone that it was still there?
Old Oct 14, 2014 | 12:17 PM
  #1078
mikeymike1985
Thank you all for your input on the dates. I'm just hopeful mine arrives this week and by Thursday :-) this way I can learn everything before its back to work on Sunday. I love the dart on a calendar comment. Lol!!! Sounds about right for this whole waiting game haha!
Old Oct 14, 2014 | 02:20 PM
  #1079
DarkBlue15MCS's Avatar
DarkBlue15MCS
- I managed to get the Homelink programmed tonight. It was not working and the problem was I was following the owners manual. We (like most modern garage door openers) have a rolling code system. Here are the basic steps... 1) hold the left and right buttons down simultaneously for some time until the light flashes quickly. This clears any old codes. 2) take your hand held remote and push the button you want to program. 3) then push the button on the mirror, it will flash briefly and change speeds. 4) go to the opener and hit the 'Learn' button. 5) go back to the car and push the same button on the mirror for a few seconds... 3 sec.. repeat... repeat... until the door moves. You have 30 sec. Repeat for other buttons. Can't put the same code in more than one button. We have 2 doors, I programmed both.
- Now here is a dumb thing. The garage door opener only works when the Engine is ON. Not the Ignition.. the Engine. So you have to start your car IN THE GARAGE to open the door. Wow this is really dumb. Same on closing it. You have to start the door closing then turn off the car. I can't imagine who though this was a good idea. I programmed the door opener while the engine was running, not just the ignition. I don't think that had anything to do with it. On my car I can use the garage opener even with out the key in the car. This is the way it should be. I hope MINI can fix this with a software update. You should never start your car in a closed garage. This is a huge safety issue. Maybe I'll try to program the mirror with the ignition only and see if this makes a difference. I don't expect it to.
When I got home today I shut the my garage door with the engine off/car on then I tried to reopen the door, I had to turn the car off then back on (engine off) to get the door open again.
Old Oct 14, 2014 | 02:36 PM
  #1080
minithis's Avatar
minithis
Hate to be a Debbie downer, mine was released to wagoners on the 4th, no clue where it is now
Old Oct 14, 2014 | 02:51 PM
  #1081
hrdcorgrl66's Avatar
hrdcorgrl66
Yes I've been calling ASK MINI everyday for updates.
Just got word that it left port this afternoon!
  #1082
mikeymike1985
Oh man! That's a bummer. I hope your mini arrives soon. Looks like I will be waiting for at least two more weeks then lol.
Old Oct 14, 2014 | 03:48 PM
  #1083
becky1711's Avatar
becky1711
Originally Posted by hammerhands
The manual says you should be able to use the garage door with the ignition on, engine off.
It doesn't work?
Just tried that and it worked. Just one push for accessory and was able to operate garage door. Never tried it because for the last 9 years I had to have the engine on. Thanks!
Old Oct 14, 2014 | 09:08 PM
  #1084
daffodildeb's Avatar
daffodildeb
Glad you got your car in time. Wow that is an awesome service bay. Our dealer is tiny by comparison.
We picked up our car today, too! I'll pass on your comment to the dealer--this is a brand new dealership in Little Rock, just opened June 9. We waited a long time for it--I moved to Arkansas on the last day of January, 2013, and it had already been rumored to be in the works for a full year before we moved! Which dealership did you use? I know all three of them in the Houston area, as I lived there 38 years. I'm going to guess Clear Lake--partly because of your name and partly because the other 2 dealerships are pretty large. I didn't have much occasion to run down that far (lived in Conroe).
Glad you got your garage door opener fixed--that's still on our agenda--but couldn't you just have the other side open? Or do you have a 2-car garage with 1 long door?
Regarding the run flats and spare--I'm guessing you have a Cooper, not an S? The S doesn't have a spare because the exhaust pipes don't allow enough room. I really wish it did, as I hate runflats, but as soon as I wear these out, I'll get Continental Extreme Contact All Seasons, and then get a donut spare, anchored behind the passenger seat. At least, I hope it fits there, like it does in the R56. I'll have to measure it tomorrow. Runflats are a false security, IMO. It's not hard to change a tire, and damage in the wrong place is just as disabling on a runflat as on a nonrunflat. Plus, they're double the cost with half the durability, and ride harder. And most companies won't fix even a simple center tread puncture, for liability reasons, so you're out a few hundred bucks for a nail. I've changed many a tire over the decades (I'm 63)--one girl to another, tell your wife it's a 10-minute job!
At any rate, we got a great start on the break-in period--went from Little Rock to Hot Springs to let the graphics shop take measurements, and right back to Little Rock for a MINI club meeting, 179 miles. Great day for a first drive--nice and sunny, and in the low 70s. Perfect sunroof weather!
Old Oct 14, 2014 | 09:49 PM
  #1085
rockets21's Avatar
rockets21
Well the wait is finally over - Picked up my 2015 Cooper S Auto Tonight "Bender" -
Old Oct 14, 2014 | 09:57 PM
  #1086
daffodildeb
Congrats!
I wish mine had a name already...I've never been too good with names. We finally figured out a name for a car we've had for 47 years!
Old Oct 14, 2014 | 10:26 PM
  #1087
aafflyer's Avatar
aafflyer
Congrats! One can only hope my care won't be too far behind...
Old Oct 14, 2014 | 11:03 PM
  #1088
mikeymike1985
Gorgeous car! Congrats!!! I can't wait for mine to arrive as well and post some pictures!!! What options did you order and how are you liking the automatic so far? Are they fully updating the software before you took delivery as well as performing the rpm fix?
Old Oct 14, 2014 | 11:22 PM
  #1089
Rocket_man's Avatar
Rocket_man
Originally Posted by becky1711
My last car garage opener worked the same way so this is the only way I know, but it would be nice if the car didn't have to be running.
Hmmm, I had forgotten about that. You're right, they are the halo on configurator and that is what I thought they would be too, but I forgot about that until you mentioned it.
Please bring this up with your dealer. I sent them some info that they are going to send up the chain.
Originally Posted by Mosco
I used Goo Gone and it worked perfect and easily. The remaining residue came right off.
Thanks, I'll try that.
Originally Posted by pagliar
Home link
My 2008 Clubman works exactly the same way. The engine must be running in order to operate the garage door. I always thought it was nuts but you get used to it. I was hoping the new one would have fixed that.
It doesn't work?
So I tried this again tonight and this time it worked on Ignition ON only, didn't have to start the engine. Odd, I tried it last night and it didn't work. This time I went to the car well after it had been sitting for a few hours and it worked. I'm glad! Sometimes it's good to be wrong.
Old Oct 14, 2014 | 11:29 PM
  #1090
Rocket_man's Avatar
Rocket_man
Compact wheel
P.197 of the manual.
1.Loosen the nut from the wheel change set using the wheel wrench.
2.Remove the retaining plate.
3.Screw the wheel wrench on the threads and loosen the lock clockwise rotation. Compact wheel releases and must be held with the wheel wrench.
4.Lower the compact wheel with the wheel wrench.
5.Unscrewing the wheel wrench
6.Pull out the well with compact wheel under the vehicle toward the rear.
7.Remove the spacer and compact wheel of the well.
8.Stow the well and spacer in the vehicle.
So I got more curious tonight and checked the situation under the boot floor and checking the second time, the lug wrench does fit but loosely. I ended up just dropping the spare and made a thread on it since there are a lot of questions on it. There is a little more to it than in the manual.
Spare Tire Thread
Old Oct 14, 2014 | 11:45 PM
  #1091
Rocket_man's Avatar
Rocket_man
Yes Mini of Clear Lake. I think they are a pretty good dealership and I'd recommend them to anyone. They helped us out as best they could during the EPA delay and got our car processed quickly when it did come in. The pick up process was easy and fast.
I did get the garage door opener programmed and it does now work in the Ignition ON without the engine ON. Not sure what the deal was last night.
I'm torn on the RFT. We haven't had a puncture in a long time and the last one I remember was a slow leak that I had been driving on for a few days before I noticed. The non RFT's will last longer and will be cheaper to replace, but this is my wife's car and she is not going to change a tire. She is 5'2" and 95 pounds. I think even if she stands on the lug wrench it will not budge the lug nut. She doesn't seem to care one way or the other and is looking to me for advice. If she gets a flat she is likely to call me or Road Side Assistance so maybe we don't need RFT. The 2014 Demo we drove certainly had RFT and the ride was pretty good. The ride on her 2015 is pretty good too but I feel like expansion joints are louder on this car. Maybe I'm just mis-remembering. If the car had come with RFT it wouldn't be a discussion. We'd have 'belts and suspenders' with the spare. I just don't want her stranded on the side of the road somewhere in Houston with a flat and all by herself.
Old Oct 14, 2014 | 11:48 PM
  #1092
Rocket_man's Avatar
Rocket_man
Congrats Rockets21. Nice name. It looks like you have the same wheels as we do. What brand of tires came on your car?
Old Oct 15, 2014 | 04:01 AM
  #1093
becky1711's Avatar
becky1711
Is keeping a slime kit in the car an option?
Old Oct 15, 2014 | 04:24 AM
  #1094
wtwien's Avatar
wtwien
Congrats to everyone who is getting their cars finally!! I have had my for 5 days and loving it more everyday. We need to form an "Get out of Jail EPA Club" because we all have a special bond together
Old Oct 15, 2014 | 05:14 AM
  #1095
D.D.'s Avatar
D.D.
Absolutly....And BLAST BMW for the travesty that it has condened. I can't wait for the survey.
Old Oct 15, 2014 | 07:50 AM
  #1096
pagliar's Avatar
pagliar
Woot. Got an email yesterday afternoon, my car is on a truck, should be in Portland today or tomorrow. I am so ready for this jail sentence to be over.
Old Oct 15, 2014 | 09:07 AM
  #1097
daffodildeb
I should have suggested that, too. My belt and suspenders approach is Slime and a compressor, plus a spare. I even have one of those puncture rubber tire repair kits. My car's been on many cross-country trips, though, so I felt it was a good idea to have all of this. In 100,000 miles and 7 1/2 years, I've never had to use them. (Knocking on wood as I type this.)
If your wife's car will be primarily in the Houston area, I'd go with Roadside Assistance, AAA, or something of that sort. If you're on a tollway, there are patrols who will come to your aid. My last flat was on the Hardy, some 10 years ago, and it was in an area that didn't have a wide enough shoulder to safely change it. The patrol truck came along while I was waiting for Roadside Assistance--maybe 10 minutes.
Old Oct 15, 2014 | 10:56 AM
  #1098
TheBigNewt's Avatar
TheBigNewt
Yep, and a pump and maybe a tire repair kit. That's what I put under the passenger seat. Funny, I got 2 nails in the runflats in 28k miles, and nothing in the nonrun flats in 43k miles. Like I've said my new runflats are pretty sweet wrt the ride. Just keep a couple lbs less pressure in 'em and no problem with the ride.
Old Oct 15, 2014 | 11:32 AM
  #1099
aafflyer's Avatar
aafflyer
Forward progress today. Email from dealer that car has been released to the carrier. Carrier has up to four days to deliver to dealer. Dealer is 170 miles from VDC, but through LA traffic. Dealer will let me know when he either has an actual expected date from carrier or the car has arrived -- he says it's been a mess this month as usually they know what's coming and when but this month it's been "we'll know what's on the truck when we see the truck".
I'm hoping to get car on Saturday.
But at least I now know that this mess is coming to a conclusion...
Old Oct 15, 2014 | 11:52 AM
  #1100
pagliar's Avatar
pagliar
My car is at the dealer. Since the dealer is 2 hours away I am going to pick it up Friday morning.
