F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Retrofitting New LCI UJ Tail Lights
Old 04-14-2024, 09:52 AM
nosidept's Avatar
nosidept
nosidept is offline
Maaii your inbox is full
Originally Posted by maaii
PM’d
  #152
Old 04-25-2024, 01:53 PM
pasaporte's Avatar
pasaporte
pasaporte is offline
Originally Posted by FRPhilippe
Hello to the entire Mini F54 community
My name is Philippe.
Thanks to this topic and @maaii ’s example, I also embarked on the adventure of retrofitting tail lights. The method is indeed very simple and in addition it is reversible. Switching the pins in the pillar was the most difficult part, and still it is enough to identify the numbers. We can't go wrong. And the pins can be taken out without forcing with the right technique. The part of the cable puggling as Maaii proposes is the easiest part of the job.
However, I had to forget something with bimmercode because the brake lights do not take the full width and simply the shape of the fog lights of the LCI versions.
Could someone please help me by sending me the exact Bimmercode instructions to correct this? That would be great🙂
Best regards✌️
Hi, have you fix that?
I am also interested on activating the tail brake lights, can you please share the bimmercode thanks in advance
  #153
Old 04-25-2024, 03:27 PM
nosidept's Avatar
nosidept
nosidept is offline
The main thing for people that have halogen lights, when doing this retrofit is to first, update the modules with esys. You just need to update the BDC module. After that, you Will have an option on bimmercode to Turn on retrofited LCI tail lights
  #154
Old 04-25-2024, 03:36 PM
pasaporte's Avatar
pasaporte
thank you I have everything done my car is 2018 the rear lights was led, everything else is working now with the new UJ only bake lights inf the new rears are now activated, if there are any code I need to do in bimmercode expert mode please share.
  #155
Old 04-25-2024, 04:37 PM
nosidept's Avatar
nosidept
nosidept is offline
Did you add HWORT/HELC with esys?
  #156
Old 04-25-2024, 04:41 PM
nosidept's Avatar
nosidept
nosidept is offline
MAPPING_BREMSL_1 = bl
MAPPING_BREMSL_2 = off
MAPPING_BREMSL_m = bl_m
MAPPING_BRAKEFORCED_1 = off
MAPPING_BRAKEFORCED_2 = bfd
MAPPING_BRAKEFORCED_m = bl_m
MAPPING_BLINKER_H = fra_h
MAPPING_BLINKER_2_H = bfd
MAPPING_PARKL_H = sl
MAPPING_PARKL_H_2 = bl
MAPPING_STANDL_H1 = sl
MAPPING_STANDL_H2 = bl
  #157
Old 04-26-2024, 02:47 AM
pasaporte's Avatar
pasaporte
yes
  #158
Old 04-26-2024, 03:15 AM
pasaporte's Avatar
pasaporte
Thanks will try to compare with mine.
do you have any mapping for the universal outputs ?
  #159
Old 04-26-2024, 01:02 PM
pasaporte's Avatar
pasaporte
hi thanks for sharing,
this did not works
can anyone please share the mapping_3 and mapping_4
appreciate any help!
  #160
Old 04-26-2024, 02:57 PM
nosidept's Avatar
nosidept
nosidept is offline
this did not works
Try this
Activate Rear Fog Lights:3068 NSL_Verbaut = VerbautCode first, then cycle ignition, then restart Bimmercode for the below optionsto show upActivate Rear Fog Lights feature for lighting switch:3064 Mapping_Nebelschlussl_L_output = nsl_l3064 Mapping_Nebelschlussl_L_Function = nebelschlusslicht3064 Mapping_Nebelschlussl_R_output = nsl_r3064 Mapping_Nebelschlussl_R_Function = Nebelschlusslicht:"" 3064 Mapping_Nebelschlussl_L_output = nsl_l3064 Mapping_Nebelschlussl_L_Function = nebelschlusslicht3064 Mapping_Nebelschlussl_R_output = nsl_r3064 Mapping_Nebelschlussl_R_Function = Nebelschlusslicht 3064 Mapping_Nebelschlussl_L_output = sl_l3064 Mapping_Nebelschlussl_R_output = sl_rMapping_Nebelschlussl_L_FIXED= pwmMapping_Nebelschlussl_R_FIXED= pwmMapping_Nebelschlussl_L_PWM_1_STANDARD = 13.7VMapping_Nebelschlussl_R_PWM_1_STANDARD = 13.7 sl_l=0x14sl_r=0x15
  #161
Old 05-07-2024, 06:10 AM
ScottieJCW's Avatar
ScottieJCW
ScottieJCW is offline
Wiring schematic
Don’t suppose any of our residential experts have the wiring schematic available for the tail lights? I’m looking at retrofitting LCI UJ tail lights to my 2017 JCW. I’m more than capable of making my own loom or getting a suitable connector in place.
  #162
Old 05-10-2024, 10:52 AM
therealms's Avatar
therealms
therealms is offline
Hi, can anyone share the installation instructions, I've already managed to get the adapter cables.
Sell224
07-25-2021 01:06 PM
ca$per
05-23-2007 02:12 AM
Sell224
16
09-04-2006 10:39 AM
Quick Reply: F54 Retrofitting New LCI UJ Tail Lights
