F54 Retrofitting New LCI UJ Tail Lights
#76
Hi Maaii, I could use one of your Harnesses If you have the time, just managed to dodge Covid 19,it very nearly got me though, I am OLD, I normally drive a Triumph Stag...daily driver but have just bought a 2016 F54 Clubman Cooper
40 years old..Fires up every morning and lives outside...20mpg though...sulk
#77
Love the Triumph Stag! Looks like its in great shape too
#78
Hello sir
Yes, please give me your email or PM me. I will contact with you.
#79
I received adapters really fast from Maaii and made the installation today.
It was quite easy to do, even this was my first mod to any car ever
One tricky part was to figure out connectors and make changes there. Changing tail lights was quite easy step and using Bimmercode took for a while.
But finally everything works fine!
Next step is to replace Clubman logo with piano black version.
#80
can I ask if you use the bimmercode code app on a phone? Or you need a laptop?
#81
hi Maaii,
I actually bought a set of a clubman owner from fb with your loop.
can I just ask if I can use the vgate i car pro dongle and iPhone bimmercode to code the car?
should I code the car before installing the light? Or install the light first?
thanks!
thanks!
#83
#84
As Maaii mentioned earlier, there are quite many settings what need to be changed. But if you have that information, it's quite easy to do with this application.
#85
thanks! I do have those instructions printed out. But thinking if I should code the car than fit the light or fit the light then code it 😂
#86
1) wiring modifications (to the connectors what can be found from A-pillar)
2) change tail lights
3) tested that lights works correctly (I got of course couple of warnings)
4) coding the car with bimmercode
5) tested that lights still works and there is no warnings anymore
#87
I did my installation about this order:
#88
Settings can be found from menus:
3064, 3065 for the light mapping
3061 for all the others
Information above was found earlier from this thread, thanks for that information to the sender.
#89
#90
Hello sir
Yes, please open your PM or give me your email, I will send purchase link to you.
hi regarding the adapter cables to retrofit UJ Tail Lights you made for the mini.. is that something an average person can do or i need to be techky? and where would you recommend getting the the new style headlights to fit on the F54? i found some on aliexpress but don't know how well it work and what codes might pop up.. any suggestions?
#94
Hello
I wrote a install guide to retrofit UJ taillight, it's very easy to install. You need to know not only how to code your car by using esys or bimmercode but also
need to swap ECU pins on BDC ECU side.
For LED headlight, you can check the thread
https://www.minif56.com/threads/f56-...93/post-832511
#95
Hello
I want to retrofit the F54 new LCI UJ taillights.
I want the installation guide and code list you wrote.
What should i do?
#96
Can anyone tell me which mapping i need to change to turn on rear fog lights with door opened? Because they are at bumper now...
They are not coming on after Union Jack retrofit :(
Thanks!!
#98
#100
Up near the top, on the right, you should see "Edward Jeong" with down arrow immediately after it. Click on the arrow, and select Private Messages.
Or, also up near the top, on the right, you should see "Welcome, Edward Jeong". Two lines below that, you should see the link Private Messages (in blue, underlined).
Edward Jeong (03-01-2021)
