F54 Retrofitting New LCI UJ Tail Lights
#51
We have a set of the lights in stock again. Genuine MINI Black line F54 Clubman https://www.ecstuning.com/Search/Sit...CI_Black_Line/
We also have retrofit kits for aftermarket ones in Ziza lighting in Union jack
https://www.ecstuning.com/b-ziza-par...g-tail_lights/
Clubmvn (04-07-2023)
#52
We have a set of the lights in stock again. https://www.ecstuning.com/Search/Sit...CI_Black_Line/
#53
I finally got around to doing this conversion.
Thanks maaii for the harness.
It was my first time using Bimmercode so it did take me while to find where the commands where located.
So I figured I would list the numbers of the menus here just in case anyone else is an inept as I an in looking for things
3064, 3065 for the light mapping
3061 for all the others
The following 2 users liked this post by insanitize:
Kukiwakame (12-19-2023),
SiF54 (11-06-2023)
#54
#57
isthisjohn (03-16-2022)
#58
#62
#64
Looking for assistance in retrofit UJ in 2017 clubman
New to all this... but I can find the lights and understand the footwell swap...
does anyone have the adapter harness and a list of instructions?
In addition to all this... can one then enable fog lamps to come on with front fog lights?
too many distracted drivers out there and I’m looking for more light hence the retrofit.
any help is appreciated.
Samuelscholey (03-14-2022)
#65
---->I have adapter harness, PM me if you need.
-----> No, In US version car. You need to change the headlight switch to enabled rear fog lamps.
#68
#70
#72
I'm new here and need a little advice about UJ tail lights retrofitting project.
I have already new tail lights at home and the target is EU model of 2017 F54 with LED lights.
I got a harness kit for this pre LCI model as well when I ordered this set and official Mini installation document.
But this harness kit looks much more different than pictures what Maaii sent to this thread earlier.
The question is should I order new harness kit from Maaii or do I really need to dismount lot's of car parts to get this original set installed?
For example the longest cables goes to the connector what is located near co-drivers legroom.
The version what Maaii has done is much shorter and does it work in European version as well?
I tried to PM to Maaii as well but that didn't worked for some reason
Best regards,
Mika
Best regards,
Mika
#73
Best regards,
Mika
Best regards,
Mika
in short:
maaiis adapters dont require cutting and soldering. Fog will be in the bumper tho
official requires allot work including opening allot plastic and cutting the wires and stuff. No way back. You will have fog in the units...
#74
if you read the topic you will have an answer to all your questions.
in short:
in short:
Maaii, if you see this message please PM to me (I will just get some PHP error when trying to send message). Thank you.
