Electrical HOW TO: Reset ELV counter. Steering lock RED warning
Old Jun 29, 2014 | 03:44 PM
ragedet's Avatar
ragedet
First of all, sorry about my bad english, i'm spanish native.
Second, 1 year ago i received a RED warning on my dashboard after using my car for some days with a bad battery (ultra low voltage). The RED warning indicate that my ELV (Steering lock) was working bad, but my ELV was working well without problems.
Size:  2.7 KB Name:  24dsxJus.jpg
So, what is going on? The CAS module has a counter, when this counter exceed the max, a RED warning light come up. When you use a bad battery (low voltage) the ELV works but indicate an error to the CAS module.
Then, my ELV works fine but i have a RED %(#))$ light every time on my dashboard, every day, every morning. Yesterday i found the solution and works fine on my car, a R56 non-s 2008. Credits to: "korell" on e90post.com (http://www.e90post.com/forums/showth...=483387&page=4)
To reset the ELV you have to use the "EDIABAS ToolSet 32", connected to the car via OBDII with the same cable of INPA and NCS Expert.
Connect the cable to the OBDII Port, insert the key and press start button (don't start the car, only ignition ON). Open the software EDIABAS ToolSet 32.
HOW TO: Reset ELV counter. Steering lock RED warning-0dxawoa.jpg
On the menu, select File -> "Load SGBD, Group File F3"
HOW TO: Reset ELV counter. Steering lock RED warning-bceen9z.jpg
Look for "Cas.prg" on the file list.
HOW TO: Reset ELV counter. Steering lock RED warning-ca1kmle.jpg
Look on the Job list the name: "steuern_elvcounter_cas_loeschen" and "steuern_elvcounter_elv_loeschen". Double click on each one, and wait for a window, it says "Job Done" on the bottom.
HOW TO: Reset ELV counter. Steering lock RED warning-j2haw02.jpg
DONE!, no more RED Light Steering lock issue.
Note: only works if your ELV works fine, and you have this issue because you didn't replace your baterry on time and wait some months for it, like me =(.
Greetings from Chile
Old Jul 17, 2014 | 03:49 PM
Leemcky's Avatar
Leemcky
Mine just popped up today
Red light every time, but lock disengages and works fine as normal
Old Jul 17, 2014 | 06:45 PM
ragedet's Avatar
ragedet
Follow the instructions and solve it. I was trying solve this issue for 1 year without success, asked to the dealer and he said that i have to change the lock USD500, change the CAS3 said other, use the second key, change the battery key, etc.
If your lock works fine, you only have to follow my instructions.
Old Dec 10, 2014 | 09:06 AM
e90reprmn's Avatar
e90reprmn
just wanted to say thanks to ragedet you saved me with this tip. Car was locked up tight until I followed your instructions now everything OK.
Old Oct 25, 2015 | 02:52 AM
Tymm's Avatar
Tymm
Thanks for sharing this I followed it to the letter, everything was as above easy to follow easy to do, worked first time! Now no more warning light or annoying "PLOING!!"
Tymm
Old Dec 22, 2016 | 09:11 PM
Rodolfox's Avatar
Rodolfox
Help resetting ELV
Hi, I am also from Chile and need help resetting my ELV counter. Are you from Santiago? Please contact me at rbermudezn@gmail.com
thanks!
Old Feb 26, 2017 | 05:04 PM
oldcracker's Avatar
oldcracker
Can the Schwaben BMW/MINI scan tool reset and clear the Car Access System (CAS) module counter as described in the How-To? The Schwaben scan tool is pictured in the How-To.
https://www.ecstuning.com/b-schwaben...020sch01a~scf/
https://www.northamericanmotoring.co...ight-on-431666
Old Apr 18, 2017 | 02:02 AM
lajya's Avatar
lajya
i wanna know schwaben tool same as foxwell nt510?
Old Apr 18, 2017 | 02:03 AM
lajya's Avatar
lajya
i'm considering Foxwell nt510 hxxp://www.eobdtool.co.uk/wholesale/foxwell-nt510-multi-system-scanner.html
can you tell me the difference
Old Jul 1, 2018 | 06:38 AM
attila14-88's Avatar
attila14-88
ELV Yellow warning, Car does not start :S
Hi,
could someone help me, please? My car does not start (E87). I have got a yellow elv fault. I tried to reset it with ispa, but it does not work. Please check the pictures.
Does anyone have any idea what is the problem?
Attached Thumbnails HOW TO: Reset ELV counter. Steering lock RED warning-1.jpg   HOW TO: Reset ELV counter. Steering lock RED warning-12.jpg   HOW TO: Reset ELV counter. Steering lock RED warning-13.jpg   HOW TO: Reset ELV counter. Steering lock RED warning-14.jpg   HOW TO: Reset ELV counter. Steering lock RED warning-15.jpg
Old Aug 26, 2021 | 04:59 AM
Wey_Thailand's Avatar
Wey_Thailand
I has an issued a red warning and I has to fixed it with follow your instruction. Thanks alot
Old Feb 3, 2022 | 05:58 AM
alpha2bravo's Avatar
alpha2bravo
Thank you !!! on the back of this found a YouTube video as well that shows the steps :
Going to follow this and see if it will fix the issue (came after a battery drain)
Old Feb 3, 2022 | 08:03 AM
alpha2bravo
It worked like a charm, and thank you so much for saving !!!!
JamJam43087
Aug 16, 2015 02:02 PM
minipopkart
Aug 13, 2015 05:22 AM
Aug 12, 2015 01:24 PM
