Electrical Need help on reverse light wire color on 08 R56 MCS
Old Nov 19, 2014 | 12:05 AM
minigen's Avatar
minigen
Hi guys, I may have double posted on other section, but I really need the help.I need a little help on installing my wireless backup camera on my MCS 08 R56. I need to find out which wire is the reverse light power that I need to tap into in the trunk, and also which is the ground wire. Attached is my wires picture. Thanks a lot.
Attached Thumbnails Need help on reverse light wire color on 08 R56 MCS-08r56trunk-wiring.jpg
Old Dec 8, 2014 | 07:21 AM
boostednorm's Avatar
boostednorm
Power = Blue/Gray
Ground = Brown
Old Dec 8, 2014 | 11:28 AM
minigen's Avatar
minigen
Thanks for the help. So for the ground wire, are there multiple brown wires in the picture?? If you can download the picture and circle the ground wire for me that would be great. Thanks again.
Originally Posted by boostednorm
Power = Blue/Gray
Ground = Brown
Old Dec 9, 2014 | 07:54 AM
boostednorm
Btw the brown wire is bigger a round.
Forgive my crude editing but here's a picture of the wires in question:
Old Dec 9, 2014 | 12:06 PM
minigen's Avatar
minigen
ahhh. this's great. Thank you, I think i can get it done pretty soon. : )
Old Dec 31, 2014 | 11:47 PM
mvt888's Avatar
mvt888
Hello minigen,
Would you mind sharing a picture of the finished product? What sort of bracket did you use to mount the display and power it? I'm looking into having dealer install this: http://www.outmotoring.com/click-dri...ion-gen-3.html, but would have to replace their Garmin model with one that has backup camera.
Old Jan 1, 2015 | 04:52 PM
minigen's Avatar
minigen
What car do u have? Gen3 or Gen2? I don't have a finished product because I need help on mounting the backup camera which I'm waiting for a friend's garage to do so. As for the gps itself, it's easy get a cravenspeed gps mount, they have one for every model of mini. Hope it helps.
Originally Posted by mvt888
Hello minigen,
Old Jan 2, 2015 | 08:18 PM
mvt888's Avatar
mvt888
I just bought the Gen 3 couple days ago and had the Click & Drive Navi system installed today. I thought about the cravenspeed mount, but thought it'd be a hassle to get power from the mount down to the fusebox, so I just had the dealer installed it (only an hour). Looks real nice and tidy and turns on when car is on. Now I can just swap out the dealer Navi (a Mini-modified 2497) for the one with backup camera (Garmin model 2798 to be purchased) and complete the camera wiring in the boot.
Old Oct 31, 2021 | 10:36 AM
Tar22345's Avatar
Tar22345
It work thanks
I have a 2005 mini Cooper. Works thanks. Reversing camera now installed!
Old Jan 28, 2022 | 01:31 PM
grunte's Avatar
grunte
I just installed a camera as well - mounted to my license plate.
My screen is washed out (white) when I go in reverse...almost like the reverse light is causing the image to be washed out....but it also happens during the day so it's not that.
did you have this issue?
Old Feb 4, 2022 | 03:49 PM
minigen's Avatar
minigen
I think you don't have a relay install between the rear cam and the power wiring , if not then you should.
ryGuyMCS
Oct 20, 2015 02:24 PM
Mini'mon
Aug 16, 2015 04:15 PM
massmini03
Aug 12, 2015 11:19 AM
