Electrical Countryman-Specific Coding - R60 Guide
Old Aug 9, 2014 | 11:00 AM
  #1051
wheresaldo's Avatar
wheresaldo
So i enabled the one touch sunroof codes on my 11. I get one touch opening but while closing it stops every 4" . Any ideas?
Old Aug 9, 2014 | 11:37 AM
  #1052
Steve Kay's Avatar
Steve Kay
Try recalibrating your sunroof: https://www.northamericanmotoring.co...975-post7.html
Old Aug 9, 2014 | 11:55 AM
  #1053
wheresaldo's Avatar
wheresaldo
Originally Posted by Steve Kay
That was it! Thanks
Old Aug 9, 2014 | 12:45 PM
  #1054
wheresaldo's Avatar
wheresaldo
delete post
Old Aug 10, 2014 | 07:18 AM
  #1055
Koopah's Avatar
Koopah
Thanks, bmrguy03! I'm back to coding again.
I wiped the (corrupt) code/files out and started fresh with a new NCSExpert package install. I also went back to the original MINI Coding Manual (Part I) by GTECKO and Theta to review the daten update procedure. I believe I may have made either or both of the following mistakes:
1. I did not have a "\R56" folder in the DATEN folder;
2. I should have copied over the contents of the update's "daten", "sgdat" and "edu" folders and not the actual folders themselves.
couper1:
I did not copy over the contents of the "cfgdat" folder in the 51.2 daten update and NCSExpert and INPA seem to be working properly. However, I'm not sure about the other programs (e.g.; Tool32, etc.).
Thanks to all!
Theo
Old Aug 24, 2014 | 03:10 PM
  #1056
Theta's Avatar
Theta
Hey all! Sorry for the lack of updates - between my health issues and the amount of time I spend working on the Corvette Forums, I don't have a lot of time to spend here these days.
Anyway, here are a few nice surprises for anyone that is stuck with a new re-program and can't code successfully!
New R56/R60/R61 Datens - 52.0.4 and 53.0.5
52.0.4: http://www.mediafire.com/download/rn...ns_v52.0.4.zip
53.0.5: http://www.mediafire.com/download/so...ns_v53.0.5.zip
Old Aug 25, 2014 | 05:02 AM
  #1057
Koopah's Avatar
Koopah
Originally Posted by Theta
{snip}
Excellent! Thanks ϴ.
Can I go directly from 51.2 to 53.0.5 or do I have to apply 52.0.4 first?
Theo
Old Aug 26, 2014 | 04:09 PM
  #1058
Rudeman422's Avatar
Rudeman422
I have a question that I don't know that it has been directly answered. If the dealer updates my computer, I know I have to load new datens for the coding to work, but can I use the same files as I used the last time I coded the car, or do I need to pull new files and edit those? Could I pull the new file and load it back with my previously coded file is what I'm asking? Thanks for any help!
Old Aug 27, 2014 | 03:03 PM
  #1059
Koopah's Avatar
Koopah
Originally Posted by Rudeman422
{snip}...can I use the same files as I used the last time I coded the car, or do I need to pull new files and edit those?...{snip}
In my opinion, you should always pull the current TRC file and then modify it for writing. I am very OCD about making changes so I always want to modify what is already being used by the control modules. I even archive earlier versions of the MAN files and categorize them by datens version. I wasn't kidding about the OCD thing!
Also, chances are that you will make multiple changes to the settings files over time. The FRM module file is a good example of this. By pulling the latest version, you ensure that your previous changes will remain intact after your TRC file is modified and written.
FWIW,
Theo
Old Aug 29, 2014 | 12:45 PM
  #1060
Rudeman422's Avatar
Rudeman422
That makes sense. I just hope I can figure out what I actually changed before to get my TPMS system to turn off so it would stop giving me an error.
Has anyone tried to figure out if there is something that can be changed so that the auto wipers come on when you turn on the car? I just feel like it should be like that anyways, I've had other cars with auto wipers and they usually come on with the car.
Old Aug 30, 2014 | 12:03 PM
  #1061
Rudeman422's Avatar
Rudeman422
Originally Posted by Hoydi Cheng
Hey guys.. this guide worked perfectly for me - 2012 Canadian R60. Any chance we have a way of disabling the TPMS warnings? That was the main purposes for coding.. although the rest was pretty cool =)
I have figured out how to turn off or disable the TPMS warnings. In the KOMBI module change RDC_ALIVE from aktiv to nicht_aktiv.
KOMBI MODULE
RDC_ALIVE
nicht_aktiv
I have also found that when you are getting a TPMS system malfunction warning, it takes a small amount of power away from the car. As soon as I changed this, the car woke back up and had full power again. Also, if you go into the TPMS screen, is will still show that there is a malfunction, but it will no longer give an error because of it. The warning triangle will go away in your tach and the tire warning will go away on your speedometer.
Old Aug 31, 2014 | 10:50 AM
  #1062
TVPostSound's Avatar
TVPostSound
Originally Posted by cerenkov
FYI, I also have no CHAMP module. (2013 R56).
Did this disappearing of the voice activation happen after a trip to the dealer?
I have no CHAMP, nor HAMP module.
Is this due to the fact, I only have the MINI Boost, not visual boost?
Old Sep 17, 2014 | 08:29 PM
  #1063
Rudeman422's Avatar
Rudeman422
Not all coding works after most recent software update
Originally Posted by TRIPLE_O
It is possible on BMW's with the FRM3 module.
See if you guys have SL_FKT_MIT_NSW in your FRM modules.
Fogs Come On With Parking Lights / Headlights ** Console Fog Light Switch Is Disabled ** - Thanks, TRIPLE_O!
SL_FKT_MIT_NSW
aktiv
This no longer works with the most current software upgrade from MINI. I've tried it many different ways and it just doesn't work.
This one doesn't work now either...
FRONT FOG LIGHTS ON WHEN WELCOME LIGHT ACTIVATED
WL_NSW
soft_einschalten
all the other programming went fine, just couldn't get those 2 to work...
Any suggestions??
Old Sep 18, 2014 | 08:35 PM
  #1064
Rudeman422's Avatar
Rudeman422
SL_FKT_MIT_NSW
aktiv
WL_NSW
soft_einschalten
Any suggestions??
I figured it out! I had to change PWM_NSW_FKT_PARKL from wert_01 to wert_02
So this is what I ended up with and it all worked. Fogs on automatically and on with welcome lighting.
SL_FKT_MIT_NSW
aktiv
WL_NSW
soft_einschalten
PWM_NSW_FKT_PARKL
wert_02
Old Sep 18, 2014 | 10:16 PM
  #1065
bmrguy03's Avatar
bmrguy03
SL_FKT_MIT_NSW
aktiv
WL_NSW
soft_einschalten
PWM_NSW_FKT_PARKL
wert_02
Nice find!
Old Nov 22, 2014 | 11:19 AM
  #1066
TheMike's Avatar
TheMike
Has anyone coded a 2015 R60 yet?
Old Nov 22, 2014 | 11:32 AM
  #1067
TheMike's Avatar
TheMike
Theta, sorry to hear of your health issues. What you have provided is truly invaluable and I for one appreciate your involvement.
Since we should always use the latest datems, why post 2 different sets? 52.0.4 AND 53.0.5
Old Nov 23, 2014 | 01:26 PM
  #1068
miniwpbear's Avatar
miniwpbear
This cable works....FINALLY!!
Amazon.com : INPA K+CAN K+DCAN Car Diagnostic tool Cable OBD USB Interface for BMW R56 E87 E93 E70 : Vehicle Electronics : Car Electronics Amazon.com : INPA K+CAN K+DCAN Car Diagnostic tool Cable OBD USB Interface for BMW R56 E87 E93 E70 : Vehicle Electronics : Car Electronics
Sold by FOTGA and shipped by Amazon Prime
Old Nov 25, 2014 | 08:34 PM
  #1069
miniwpbear's Avatar
miniwpbear
Two questions:
If I am coding a Paceman and a R57 do I need to load different datens?
On my Paceman this code works with the engine on but not after I turn the car off. Is there another code that will do the same after I stop the engine, start window auto up, open the door and the window continues to close.
"Windows DO NOT Stop Rolling Up When Door Opened
FH_TUERAUF_STOP_MAUT_3R
nicht_aktiv"
Old Dec 29, 2014 | 09:01 PM
  #1070
AlphaQuad's Avatar
AlphaQuad
I have noticed that since enabling this function the cabin lights will dim slightly when the ambient lights cycle ? Maybe it's drawing additional voltage?
Originally Posted by AlphaQuad
Special thanks to Kevdog for this one!
Setting WELCOME_SCENARIO_ACTIVE to aktiv in FRM makes the ambient lighting color come on when you unlock the car and cycle once, then stop at the original color when the door is opened. With WELCOME_SCENARIO_ACTIVE set to nicht_aktiv, ambient lighting is off until the start button is pressed and does not cycle.
Old Jan 11, 2015 | 10:37 PM
  #1071
shdwkeeper's Avatar
shdwkeeper
Originally Posted by miniwpbear
What car do you have? Will this work on a 2012 R60?
Old Jan 11, 2015 | 11:38 PM
  #1072
shdwkeeper's Avatar
shdwkeeper
Has anyone here added the 25W Xenon Retrofit headlights replacing halogens to their car, if so have you coded using NCS Expert to get them added? I read this post: https://www.northamericanmotoring.co...rofit-kit.html and I'm just trying to get a step by step for really easy DIY for the R60.
Old Jan 15, 2015 | 01:45 AM
  #1073
shdwkeeper's Avatar
shdwkeeper
Does this look like the working cable everyone is talking about? I don't see pin 7&8 soldered together unless I'm looking in wrong spot.
Attached Thumbnails Countryman-Specific Coding - R60 Guide-fullsizerender.jpg   Countryman-Specific Coding - R60 Guide-fullsizerender-1-.jpg
Old Jan 15, 2015 | 03:37 PM
  #1074
miniwpbear's Avatar
miniwpbear
I have a 2013 R57S and 2013 R61S
Old Jan 15, 2015 | 09:57 PM
  #1075
shdwkeeper's Avatar
shdwkeeper
Ok I have a 2012 CMS, I will try this.
