Eastern Iowa MINIs Eastern Iowa MINI enthusiasts group
EIM Warm Weather Babble
Old Sep 4, 2012 | 10:13 AM
  #501
05MINI's Avatar
05MINI
Under the MINI are 4 big rubber bumper things that I use to put the jack stands under when I rotate tires or whatever. My MINI now only has 3 of them. I am missing the driver's side rear one. I need to order one of these but I have no clue what they are called. Using the keywords "rubber bumper" at minimania.com isn't very helpful I am feeling stupidly clueless and would appreciate some help, please. Thanks!
Old Sep 4, 2012 | 11:13 AM
  #502
smieska's Avatar
smieska
I think there called a lifting block. About $20
Old Sep 4, 2012 | 11:25 AM
  #503
05MINI's Avatar
05MINI
Yes! That is it. Thank you. I knew I could count on my MINI community.
Old Sep 4, 2012 | 11:28 AM
  #504
Gil-galad's Avatar
Gil-galad
...or you can go with the heavy duty metal jack points:
http://www.waymotorworks.com/billet-jack-points.html
Probably overkill unless you're autocrossing or constantly putting your MINI up on a jack...but they're sure nice.
Here's a source for the OEM ones -
http://www.ecstuning.com/Mini-2005-C...Jack/ES128680/
  #505
smieska's Avatar
smieska
I found a couple of puddles of black goop under the right side front of my car. Not oil but thicker and black. After investigating what I thought was a small oil leak from the filter area I noticed the top motor mount was leaking hydraulic fluid. A few clicks later on NAM I found out it is not uncommon for the top motor mount to fail and leak the goop and then allow the motor to move around when accelerating. WMW saw my order yesterday for a TSW engine mount upper and Power Flex lower mount. It looks to be pretty straight forward installation but yet another specialty tool required to remove the lower bolt (E12 socket). Hopefully it shows up this week and can be installed Saturday.
Old Sep 4, 2012 | 11:33 AM
  #506
Gil-galad's Avatar
Gil-galad
Pretty common issue. My '05 had this happen to it. There's a picture of it posted in the bowels of NAM somewhere...
Make sure you don't procrastinate in cleaning up the fluid. Once it congeals it's a bear to remove, and since the pepper white paint in the engine compartment isn't clear coated it's easy to scrub right down through paint. (The voice of experience speaking here.)
Old Sep 4, 2012 | 11:54 AM
  #507
05MINI's Avatar
05MINI
Thanks! I think I will stick to the $20.00 ones
Old Sep 4, 2012 | 12:44 PM
  #508
smieska's Avatar
smieska
I have most of the goop cleaned up until I remove the mount and Im sure it will leak a little more. Do you remember how the install went? The DIY said to use a floor jack to take the weight off the mounts but not to lift the motor any more than necessary. Once you get the bolts out top and bottom along with the brace bolt does it slide right out? On the bottom one it says to raise the motor enough to get the old bushings out and slide the new lowers in. Seems simple enough until I start.
Old Sep 4, 2012 | 05:10 PM
  #509
Gil-galad's Avatar
Gil-galad
When mine blew I was getting ready to take it in for a regular check-up anyway, so I must confess that I took the lazy man's approach and just had the service department do the swap.
I think your description is correct, and if you get the weight off of the mount it's pretty straightforward. I think the head of the long bolt that goes through the length of the urethane mount has a funky head on it (male torx perhaps?) that demands a tool that is not found in your average toolbox. Way could probably give you some insight on this.
Old Sep 4, 2012 | 05:19 PM
  #510
MeenieMom's Avatar
MeenieMom
Thanks for the bug shield info. Think I'll just really wax it up like you suggested, Gary.
Now I'm trying to decide if I want to take a detour over to the Dragon on my way to Florida. It will only add 80 miles onto the total mileage, but it is already going to be two long driving days as it is.
Or, I can bypass the dragon this time and make a trip to the Smokies at a later time when I can spend some time exploring the miles of curvy roads around the area. It looks like there is also quite a bit of things to see and do, as well.
Sitting on the fence...anyone want to push me one way or the other?
Old Sep 5, 2012 | 05:33 AM
  #511
Gil-galad's Avatar
Gil-galad
Why not do both?
Old Sep 5, 2012 | 07:29 PM
  #512
MeenieMom's Avatar
MeenieMom
Not as much fun by myself, but maybe I will...
Old Sep 5, 2012 | 08:14 PM
  #513
old81's Avatar
old81
M6
Any chance to drive the Dragon by yourself or with a screaming passenger, DO IT!
Old Sep 6, 2012 | 01:58 PM
  #514
Gil-galad's Avatar
Gil-galad
Seeing if I can post here from my iPhone using the new NAMotoring app...
Edit (from laptop): It works!
Old Sep 6, 2012 | 07:22 PM
  #515
deanman's Avatar
deanman
It works from an iPad, too.
Old Sep 7, 2012 | 01:17 PM
  #516
05MINI's Avatar
05MINI
Yes, it works from my droid
Old Sep 25, 2012 | 12:10 PM
  #517
05MINI's Avatar
05MINI
My hubby & I are going to Door County this weekend. Looking forward to those wonderful Wisconsin twisties! Also looking forward to this store I found whilst researching our trip:
http://www.madeinbritainltd.com/index.html
I ought to be able to get some cool Union Jack stuff there!
Old Sep 25, 2012 | 01:03 PM
  #518
Gil-galad's Avatar
Gil-galad
Can't wait to hear about your trip when you return. I've never been up there before, though I understand there are some mighty fine and scenic motoring roads in the area.
That's one cool store.
Old Sep 25, 2012 | 07:34 PM
  #519
deanman's Avatar
deanman
I thought I commented on this already but I don't see it. I wonder where it went Maybe the spiders got it.
I'm very jealous about your trip! We love Door County but don't get there often enough
Old Sep 26, 2012 | 04:45 AM
  #520
Gil-galad's Avatar
Gil-galad
Originally Posted by deanman
...Maybe the spiders got it.
Obviously a man who has done his online research!
Old Sep 26, 2012 | 06:56 AM
  #521
05MINI's Avatar
05MINI
We have never been to Door County so I am looking forward to it.
And spiders are evil!
Old Sep 26, 2012 | 09:21 AM
  #522
densan57's Avatar
densan57
Have a great time! The shopping looks like fun. You'll probably fill up Gozer's boot.
S & D
Old Sep 27, 2012 | 10:16 AM
  #523
Gil-galad's Avatar
Gil-galad
Any of you local 1st Gen owners (R50, R52, R53) interested in a used skid plate to protect the underside of your precious MINI engine this winter?
I realized that I still have the Cobalt Aluminum Skid Plate from SHADOWFAX sitting in the corner of my garage, in perfectly fine condition. I also have high-quality stainless steel hex mounting bolts (to replace the inferior (subject to corrosion) Allen-head bolts supplied by Cobalt). If your MINI is a daily driver and sees wintertime roads, a skid plate is great insurance against ice chunks flying up and damaging your oil pan, PS pump fan, and other underside components.
A new Cobalt Skid Plate from Moss MINI (<-link) will run you $144.95 plus shipping.
I'd let mine go for $50 -- hand-delivered, and I can show you how to install it too if desired.
Edit: Sorry folks, it's already spoken for...and headed to its new home in Council Bluffs
Old Sep 27, 2012 | 02:57 PM
  #524
smieska's Avatar
smieska
Is that delivered anywhere and installed? I have been contemplating getting one but couldnt justify the $150 to do it. For $50 I am interested and could probably install it myself. Did you leave it on year round?
Old Sep 27, 2012 | 05:53 PM
  #525
Gil-galad's Avatar
Gil-galad
Hmmm... when I postulated "hand delivery" I hadn't even considered CB. Maybe we could meet somewhere in the middle.
Some folks leave them on year-round but I always took mine off in late spring, figuring I'd optimize the air flow through the engine compartment and to the PS Pump during the warmer months. Always put it back on the same day I'd mount my winter wheels/tires, usually the weekend after Thanksgiving.
