Drivetrain Installing Fireballed Head and Schrick cam this month.
Old Oct 27, 2006 | 03:26 AM
  #276
Paul Webster's Avatar
Paul Webster
Originally Posted by markldriskill
I guess the idea isn't totally crazy if at least two other people have considered it.
If it got well-publicized and the governance got set up so that people felt more like they were testing rather than racing, you might get broader participation (while those who want to race could certainly bust their humps, no extra charge) AND if the event had other stuff to do besides run and watch others running, (good eats? performance vendor exhibition wares?) then it might make for a fun time.
Long Beach MINI did annual poker rallies for a few years until this year I guess they stopped maybe because last year it got too big for them to handle, I guess. It did get kinda messed up last year.
The right venue might be difficult to find? I don't know where one would do such a thing.
Other things to do might be make it "all hatch-back" or something else to include more prospective owners if the concern was whether attendance would be sufficient to support it. Or maybe "all-BMW"? Whatever. Invite enough to make SURE the first time. Make it "first-come-first-served" and do it again if it goes well. Or maybe test the water somehow with the clubs and sponsors? Vendors should have lists of their customers. If they cooperated, and did a joint mailer to publicize? Use a publication like MC2? How many participants would be needed to make it work?
HELP!! Somebody with some expertise in -- whatever this is!
I've paid for private track days anywhere between $108 to $234, the more there are the less you pay.
The big advantage is you can get 15-20 runs in on a private test day and the track is spot on.
Everybody who's intrested should pay $100 up front then you know its going to happen, you probably need 30-40 cars.
Old Oct 27, 2006 | 07:06 AM
  #277
camelpilot's Avatar
camelpilot
Originally Posted by MarioKart
Do you know when and where the O.C. meet is? I think its this Sunday.
M
All the info here:
https://www.northamericanmotoring.co...ad.php?t=81358
I'm still not sure whether I'm going or not. Sounds like fun though. Good cause too.
Old Oct 27, 2006 | 03:41 PM
  #278
Johan's Avatar
Johan
Originally Posted by Fireballed Tuls
well just got back....
original #s were 167 WHP 17%, intake, header, exhaust
post head/cam and untuned...208 whp
I'm not sure what "untuned" means. My car already had the FBT software about 3 weeks ago so maybe it was good enough for the Head and Cam no to be adjusted. Maybe there is more HP to be made, but I do need the car to be reliable.
So far there is no Ping or Knocking. I know they put 380 injectors and colder plugs. I have a feeling Zero timming was pulled since the car is running on the same software download I got a few weeks ago.
I'm a little confused, like normal , where the injectors and plugs installed before the first run, after the first run or after the last run? In other words was it a head/cam and injectors for the 208hp? What was the before and after TQ?
Can you please post the dyno sheet with the before run and after run on one sheet with A/F? I am interested to see the TQ curves before and after and where you were making peak numbers. I'm not asking to discredit anything, I would love to compare it with my data.
What does untuned mean? Is there more tuning that has to be done? While on that note how does FBT software compare to MTH? Thanks! -- Johan
Old Oct 27, 2006 | 04:35 PM
  #279
MarioKart's Avatar
MarioKart
Vendor
The pre dyno was done at 167whp, the post dyno was 208whp with Head, cam, and added 380 injectors and colder plugs.
I forgot what the tq was and I don't have it on a PDF or anything. I think I gained like 25wtq.
I have heard many horror stories from real in person owners on MTH. Some had no problems but also had no HP gains. The Fireballed software was a huge improvement on my car and the 10 other cars that got it the same day I did.
Well, I think I'm over the whole Head and cam thing, there seems to much hair spilting over the pre and post dyno and he said she said crap. Over all I'm very happy with my results and the butt dyno is huge, I guess thats all that matters to me. I really want a twincharge set up, I should have done it the first time around. Time so save my pennies.
M
Old Oct 27, 2006 | 04:48 PM
  #280
Johan's Avatar
Johan
M
Thank you for the reply. I'm not doubting your numbers, It's just that I have stacks of data and it would be nice to have something to compare them too. Thanks!
Old Oct 27, 2006 | 06:22 PM
  #281
MarioKart's Avatar
MarioKart
Vendor
I know, it wasn't pointed toward you in any way. What do you have for mods and what kind of data? Do you have a similar set up as me?
M
Old Nov 13, 2006 | 02:54 AM
  #282
BFG9000's Avatar
BFG9000
Now at 208whp after $10k and you already want more! And you've only owned your car 9 weeks!
Mario, do you have a qtr mile trap speed recorded yet? MPH tells all and is not dependent on traction or launch.
BTW valve float is actually very violent and the resonance heats the springs up something fierce, usually resulting in the springs losing their temper for a lower rpm until floating the next time, each time. You would NOT just notice a slight torque drop off at one rpm (say 6000) while sailing up to redline because by definition the valves are off their seats (usually the intakes because they're heavier) so you cannot rev higher. That and the power loss would occur at a lower rpm each time.
Old Nov 13, 2006 | 08:00 AM
  #283
MarioKart's Avatar
MarioKart
Vendor
not yet since my car had 167whp in AZ, I think it was 91mph. Maybe next month I will take the Mini back to see what I can do, but I really wanted to take the my 500hp Benz there.
TURBO, TURBO, TURBO is what I want next.
Teh
Aug 22, 2022 04:37 AM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
MIminiclubman
Aug 5, 2015 09:14 PM
