Drivetrain Megan Header experiences
Old Nov 15, 2013 | 08:13 AM
  #101
vietnameeh's Avatar
vietnameeh
itll get significantly louder... and you could possibly hear a hissing when revving
btw: does anyoen from this old thread have updates.. .how their megan is holding up
Old Nov 15, 2013 | 09:15 AM
  #102
PaulWalliDumali's Avatar
PaulWalliDumali
I see. Do you have these headers as we'll? It would be great if people can give an update on how they are holding up.
Old Nov 16, 2013 | 11:40 PM
  #103
PaulWalliDumali
Hello guys! I was wondering if anyone ran into this problem with the Megan headers. My 02 sensor that are on the headers is so close to the heat shield that I cannot plug my 02 sensor in. What can I do? Is it bad to run my car without it and only the 02 sensor on the cat? Thanks!!
*The pictures are on this thread: https://www.northamericanmotoring.co...n-headers.html
-Paul
Old Nov 16, 2013 | 11:57 PM
  #104
vietnameeh's Avatar
vietnameeh
You can't bend the heat shield ?
You def need the first o2 sensor in its what the ecu
Reads for fuel trim
Old Nov 16, 2013 | 11:59 PM
  #105
PaulWalliDumali
It seems like it is still too close. With the heat shield off, it just gives a little more space. I just took my heat shield off and I'll see if I can fit it tomorrow. I doubt it though. Do you have Megan headers?
Old Nov 17, 2013 | 10:59 AM
  #106
vietnameeh's Avatar
vietnameeh
i dont have a megan, it looksl ike you already ran the car?....
Old Nov 17, 2013 | 05:57 PM
  #107
PaulWalliDumali
I ran the car for about 10 blocks. So, I took the shield off, and it fits now, but I don't have a long enough 02 sensor since the sensor is placed way lower than the original place. Is is possible to buy a longer one? I just need a little more length. Also, is it bad to drive it a little bit? No freeway, just little city blocks.
Old Dec 19, 2013 | 09:36 PM
  #108
summit56's Avatar
summit56
I
Old Dec 19, 2013 | 10:10 PM
  #109
summit56's Avatar
summit56
I just welded another bung on the other side, then cut and extended the wires about a foot.
Old Dec 20, 2013 | 11:34 AM
  #110
PaulWalliDumali
Nice!! How is it running now? Is any codes throwing?
Old Dec 20, 2013 | 03:37 PM
  #111
summit56's Avatar
summit56
I installed a 17% pulley, header, one ball exhaust, and DIY cold air intake all at once. Now I just need a tune. It is noisier than expected (coming from a supercharged e46). Seems to run good but here in Anchorage Alaska we have finally been getting are snow so it is a bit hard to really tell at the moment. The usual P0420 code came.
Old Jan 24, 2014 | 08:01 PM
  #112
GreekDrifter91's Avatar
GreekDrifter91
as pointed out by another member, to me becasue i just got a megan/M2 header from outmotoring. any one have this issue?
Originally Posted by SniperDetailing
Make sure you bolt that header up to your head before you do any coating. I ordered one off ebay that looks exactly the same down to the o2 plug-bolt and there were 2 or 3 manifold bolts that just wouldn't line-up at all
also anyone have issues passing emissions at all? i got one one those o2 spacers with the catalytic material in side if it so hopefully it wont through a code.
edit: also when did they update there headers? the test pipe section looks different from everyone else. you think they fixed the crappy resonator?
Old Feb 12, 2014 | 09:50 AM
  #113
Frozone's Avatar
Frozone
Old Feb 12, 2014 | 09:53 AM
  #114
Frozone's Avatar
Frozone
Originally Posted by GreekDrifter91
Finally, some nice pics. It's difficult sorting through hundreds of posts especially since there's so much conflicting/old information.
I've been trying to decide between OBX and Megan headers. I want to use an OEM cat, and I'll definitely have solid motor and transmission mounts are installed.
After all the reading, I still have these questions:
1) Do the current Megan headers still have poor port-alignment (1/4" off)?
2) Are all the current OBX headers "not as good" anymore, as mentioned by Helix here?
Originally Posted by Helix13mini
Originally Posted by WayMotorWorks
I wish there was some more up-to-date information about these headers. I see more vendors selling the Megan headers than OBX, but that may not really mean anything.
It seems all the variables come down to:
a) head bolt alignment (Megan>OBX?)
b) header port alignment (OBX>Megan?)
c) weld quality (Megan>OBX?)
d) cat and exhaust fitment (OBX>Megan?)
e) O2 sensor fitment (OBX>Megan?)
f) flex joint quality (OBX=Megan w/solid motor mounds?)
g) ball-joint/donut gasket design (OBX=Megan w/solid motor mounts?)
Just wish the RMW header wasn't 4x the cost. The law of diminishing returns is just screaming at me on this one.
Old Feb 13, 2014 | 09:48 AM
  #115
RA082324's Avatar
RA082324
just my 2 cents...
date/time/source:
i purchased my megan 4-1 race header through wmw around 10/13. ive put at least 2k miles through it and have had no issues.
build quality:
i did not religiously inspect the build quality, but considering the ports on the header, lined up with the stock gasket, as well as the after market gasket it came with, i assume they are lined up properly. the bolt holes all lined up too.
fitment:
heres where i ran into my first issues. to start, in my opinion, it was a pita to get this thing in place... however, i did it all myself, so it is certainly not impossible to tackle alone.
on my header, unfortunately, the pre-cat/upstream bung for the o2 sensor, was further down than the one on the stock manifold. after disconnecting the sensor, and routing it every possible way, it still would not reach. to remedy this, i contacted jan from rmw, and he was able to make me a legit extension wire from factory male/female plugs and the proper resistanced wires. other than that, i had no fitmemt issues.
supplied test pipe vs cat:
i ran it with the test pipe for the the first 3-4 weeks. combined with my custom 2.5 catback piping, this is what i think most would consider "stupid loud". so i decided to go with the high flow magnaflow cat, which, took it to a nicer tone and dampened the sound to my liking.
cel:
using the test pipe, i did throw a cel. once i installed the magnaflow cat, i reset and it has since (at least 1k miles and well over 20 hot/cold cycles) stayed off.
sidenote:
for those of you interested... after clearing a cel, 3 hot/cold cycles are required for the readiness monitors to regain the info they need. so dont think you can clear the light, and then the next time turn the car on, drive 100 miles and think youre in the clear. it requires heating up to running temp, and cooling down while off 3 times.
conclusion:
i have not returned to the dyno since installing the header, but at the very least, i am happy with the sound. ive also noticed just a bit more top end power. worth the money to me. i will re-post in the future with updates if any issues arise, or if i have none in another 5k or so.
Old Feb 13, 2014 | 10:39 AM
  #116
Frozone's Avatar
Frozone
Originally Posted by jown.iv
just my 2 cents...
date/time/source:
build quality:
fitment:
cel:
sidenote:
conclusion:
Thanks for the excellent information here, especially about the header port alignment. Regarding the O2 sensor, I read some folks were re-routing their O2 sensor to reach, and some like yourself actually extended the sensor wiring. It'd be good to know what others are experiencing with this.
Old Feb 13, 2014 | 10:41 AM
  #117
Frozone's Avatar
Frozone
Your pic definitely shows why people couldn't get the O2 sensor to fit without doing something to the heat shield!
Old Feb 14, 2014 | 06:57 AM
  #118
TheBigChill's Avatar
TheBigChill
I can't comment on Megan build quality, but I think OBX had a better warranty at the time. Maybe not...
Additionally, while it's a contentious topic, your main considerations should be 1) Tri-Y vs 4-1 design, and 2) "Flex" joint style. I personally don't care for accordion or woven flex sections; when they rip or crack, you now have to cut it out and weld on a new one.
Compare that to a donut style gasket, where you can simply replace the gasket, and this style actually allows the exhaust to pivot on a transverse mounted engine instead of flex. You can only flex or bend alloys so many times before they fatigue- as many have experienced with the Megan header's flex section.
When flex sections break or crack, it's almost always at the same spot: toward where the accordion or weave sections meets the rigid pipe. That should tell us something about this design.
Old Feb 14, 2014 | 09:57 AM
  #119
Frozone's Avatar
Frozone
Spot on - I know regarding 4-1 vs. 4-2-1 header design, all things being equal (proper design, etc.)) there's a difference in where power is made (mid vs. high end) - but my understanding is that for what I'm trying to accomplish, the difference is negligible. If I was worried about it, I wouldn't even be looking at the cheapest header on the market.
When it comes to donut vs. flex, I've also heard the pros and cons of both. Either way, having a good set of motor/transmission mounts (TSW/powerflex) vastly reduces the stress on the joint, and increasing the lifespan of either joint.
At this point I think I'm leaning to Megan because
a) It's sold by some good vendors
b) Some recent owners say the port alignment is good
c) I like the option of making a "swappable" cat
The biggest downside I see right now is pre-cat O2 sensor fitment. It looks like it can be addressed by some combination of:
a) re-routing the O2 sensor wire
b) extending the O2 sensor wire
c) welding another bung on a different location
Thanks for your input!
Old Feb 14, 2014 | 11:12 AM
  #120
TheBigChill
Agreed on all points. Just know that folks have had issues with the Megan flex-pipe, as well as the resonator's insulation breaking-up. Sounds like you've done your research though. Good luck!
I think vendors offer the Megan header because it's a complete bolt-on solution, as opposed to the OBX, which may scare folks away due it's "assembly required" approach.
Old Feb 14, 2014 | 11:19 AM
  #121
Frozone's Avatar
Frozone
Thanks for the heads-up. Yeah if I could choose, I actually like the donut joint - with my failed motor mounts the way they are, they're probably already taking a toll on my OEM manifold flex joint.
Yeah that "assembly required" part was making me nervous only because I've never gone to a welding shop before, and didn't know how easy it would be to basically say, "attach this cat to this header so it's the same length and angle as the manifold you just got the cat from".
With the Megan, I can see myself with the resonator/test pipe what the length of the flanged cat would have to be.
BushOner
Mar 12, 2022 08:51 PM
Sep 10, 2015 01:48 PM
Sep 10, 2015 10:52 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
