Drivetrain Megan Header experiences
Old Feb 21, 2007 | 10:23 AM
  #76
fj0's Avatar
fj0
Test pipe included is tempting or else I've only done research on the OBX, what are the big differences?
Old Feb 21, 2007 | 10:30 AM
  #77
MSFITOY's Avatar
MSFITOY
Sorry I don't have any closeups but if you look carefully at the lower picture, the bung on the test pipe comes out the driver's side near the end flange...
Old Feb 21, 2007 | 10:38 AM
  #78
pobsey's Avatar
pobsey
Sid when did you fit the 12 cyclinder in the MINI?
3 Headers!
Old Feb 21, 2007 | 10:44 AM
  #79
MSFITOY's Avatar
MSFITOY
3 Headers!
If you count all the headers I've put on, I have a 16 cylinder MINI
Old Feb 21, 2007 | 10:45 AM
  #80
fj0's Avatar
fj0
So, Megan or OBX?
Old Feb 21, 2007 | 01:34 PM
  #81
Bahamabart's Avatar
Bahamabart
Originally Posted by fj0
So, Megan or OBX?
While we all pursue the "best" - I haven't seen that one is superior to the other in anyway. I think the decision on which one tp buy is driven by these two components -
1) theory of 4-2-1 desin compared to 4-1 design.
2) the different flex joint designs.
I don't think either is a regret, the regret would be not to header up for 200 bucks
Old Feb 21, 2007 | 06:53 PM
  #82
cartar452's Avatar
cartar452
well today i fixed everything and it all seems to be working well...i have just one more question...i noticed that the check engine light came on which im told is normal due to no cat but the traction control light is now also always on and i can't turn it off...any reason for this??
Old Feb 22, 2007 | 07:00 PM
  #83
cartar452's Avatar
cartar452
anyone know why the traction control light would be on???
Old Feb 22, 2007 | 08:16 PM
  #84
MSFITOY's Avatar
MSFITOY
Please let us know if you find out what's going on...this is strange...
Old Feb 22, 2007 | 08:33 PM
  #85
cartar452's Avatar
cartar452
yeah my whole experience with this header has been strange...nothing really ligned up, took about 4 hours to get it all on and still fits weird, sounds good but doesnt seem any faster, and now that light is on...im considering puting the stock back on and ordering an obx
Old Feb 22, 2007 | 10:01 PM
  #86
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
... sounds good but doesnt seem any faster, and now that light is on...
And you're surprised? There are literally hundreds of posts that would lead you to conclude that the lack of measurable HP is not surprising at all. Without head mods, or properly designed headers, which OBX or Megan or many others for that matter are not, you will be lucky to get a pleasant increase or improvement in sound (which is personal preference, I'll admit--a guy with a Celica GT next to me last week declared my MINI with Megan to "... sound like *****".)
A header on a MINI is rarely a HP maker...
Old Feb 23, 2007 | 03:36 AM
  #87
norm03s's Avatar
norm03s
why not
cartar452, read this;
https://www.northamericanmotoring.co...ad.php?t=66035
Repacing both MAP sensors fixed mine. First thing to do is pull the codes.
DrPhil, with the same brush your painting SuperSprint.
As for the 4-2-1 OBX and mid range, there is a + difference.
Old Feb 23, 2007 | 04:47 AM
  #88
Bahamabart's Avatar
Bahamabart
My opinion differs -
For this size engine, I do not expect ANY header to be a major contributor to HP.
While I did not independently measure the effect of adding a OBX header, others have and while the HP gains were minimal the TQ gains were more noteable. I gain noticeable SOP TQ gains when I addded the OBX header - the car pulled stronger/earlier on in the power band.
Having said that I differ that the OBX/SS is not "properly designed" (I am not saying it's the best design). I would like to know what brand you consider to be a properly designed header for the Mini?
Old Feb 23, 2007 | 04:48 AM
  #89
Bahamabart's Avatar
Bahamabart
I very much concur
Old Feb 23, 2007 | 06:19 AM
  #90
norm03s's Avatar
norm03s
Here you go
This thread may help you out;
https://www.northamericanmotoring.co...ad.php?t=63335
Old Mar 9, 2007 | 08:59 PM
  #91
cartar452's Avatar
cartar452
Traction controll light is still...I have no idea what to do! Any suggestions???
Old Feb 21, 2008 | 05:00 PM
  #92
blkkouki's Avatar
blkkouki
i havent posted alot but there is a $4-5 fix for the o2 sensor problem, been doing it for years starting with my spec-v, then my 240, and if i go catless ill do in my mini wich i probobly wont for fear of sounding like a civic
1. go to your local parts store get some sparkplug non-foulers, usually the 18mm version
2. 1/2 drill one of them so the o2 sensor will fit
3. put the undrill one in the bung, the drilled one behind that, then the o2 sensor in the drilled one,
yeah it makes it stand out, but i drove for 2 years on each car this way, it pulls the o2 sensor out enough that it "tricks" the ecu into thinking there is a cat there, and it wont even mess up the a/f's either
Old Feb 25, 2008 | 01:19 PM
  #93
zmanrz's Avatar
zmanrz
i am on my 2nd meagan header now..... blown flex pipe 2 times. new motor mounts after the first time. i have ALTA 2.5 exhaust, sounds awsome. but i'm not very happy with the same problem happening twice
Old Feb 25, 2008 | 01:58 PM
  #94
Luys's Avatar
Luys
I installed before 1 month ago Megan Header. I am angry about the sound it is very loud.
Old Feb 25, 2008 | 02:02 PM
  #95
checkmate2006's Avatar
checkmate2006
Certain mods come with certain sacrifices.
Old Dec 7, 2008 | 07:11 AM
  #96
nickbmw's Avatar
nickbmw
From all you guys using the Megan 4-1 header, i am looking for a photo of the flange! Could someone pls help me with this?
Old Dec 7, 2008 | 08:44 AM
  #97
AutoXCooper.com's Avatar
AutoXCooper.com
I'm working on getting a pic of the flange, but will be 24 hrs at best before I can get it and post it.
Old Dec 7, 2008 | 09:03 AM
  #98
nickbmw's Avatar
nickbmw
Ok, thanks a lot, i also sent you an email , hope u read it
I like the design of the Megan, the only thing that scares me is that i read so many bad things! (fitment and cracks)
Old Dec 9, 2008 | 11:44 PM
  #99
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
Don't put the Megan on unless you check the port alignment, trust me.
Old Nov 15, 2013 | 02:22 AM
  #100
PaulWalliDumali's Avatar
PaulWalliDumali
Hello!! I just got my Megan headers and im wondering, how do you guys know when he flex joint is going bad or when your headers are in general cracking or breaking?
