Drivetrain Megan Header experiences
Old Nov 21, 2006 | 07:57 PM
  #51
polizei's Avatar
polizei
Where did you buy the magnaflow cat from? Is it loud? Like I said, I don't want a stupid loud exhaust, but I sure as hell don't want a quiet exhaust!
-Cody
Old Nov 21, 2006 | 09:00 PM
  #52
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
-Cody
See post #40. The link is for a Magnaflow that fits for $55.
Old Nov 22, 2006 | 08:46 AM
  #53
polizei's Avatar
polizei
Ah thanks! I skipped right over it.
-Cody
Old Nov 22, 2006 | 10:18 AM
  #54
spillman's Avatar
spillman
Originally Posted by DrPhilGandini
Spillman: I have about 5000 miles since installing the o2 simulator. It has never thrown a light.
Wesport: It is quite quiet with the Magnaflow cat (https://2527312909.monstercommercesites.com/index.asp -- comes with a bung and is about 1" longer than the pipe it ships with--which gives your Muffler guy some room to cut it to the right angles for a proper fit with flanges. It is pretty loud with the race pipe, much quieter with the cat. Still louder than stock. I don't have db measurements, sorry. I too have a Milltek catback.
I like the sound, quite low, with an angry bark at WOT. Never sounds ricey. I have a few sympathetic vibrations and rattles in the car, but I'm running an engine damper and the Milltek hits the shielding every now and then.
cheers,
Are you saying that you are using the O2 simulator with a cat and not throwing codes? This is not relevant. I am asking how many miles with your "race" pipe installed (no cat). This is when the car should throw codes. It takes a good bit of miles and several key cycles to throw a code.
Old Nov 22, 2006 | 11:27 AM
  #55
nypepper's Avatar
nypepper
-Cody
it's still loud just a little more civilized
Old Nov 22, 2006 | 02:26 PM
  #56
MSFITOY's Avatar
MSFITOY
Before selling my Megan header, I put on several hundred miles and at least 20 key cycles and the O2sim did it's job
Old Nov 27, 2006 | 06:25 PM
  #57
TampaMCS's Avatar
TampaMCS
My Megan is coming apart at the flex joint...less than 10K miles and 6 months...
Old Nov 27, 2006 | 06:30 PM
  #58
MSFITOY's Avatar
MSFITOY
Do you have your motor damped?
Old Feb 19, 2007 | 07:00 PM
  #59
cartar452's Avatar
cartar452
so i put my megan header on today and everything went smooth except one of the bolts wouldnt line up at all...so for now its off...also the O2 sensors wouldnt reach the bungs so i just tucked em up under the car and left the caps on the header...will this cause any problems or will the check engine light just come on?
Old Feb 19, 2007 | 09:33 PM
  #60
TampaMCS's Avatar
TampaMCS
The one up by the motor must be connected!!!! do not drive your car without that connected!!!!
Old Feb 20, 2007 | 04:42 AM
  #61
DrPhilGandini
And both must be connected (or a simulator must be used with the after-cat sensor, but it's easier and legal to use a cat and the second sensor in place). There are many threads on this--a search will reveal them.
Old Feb 20, 2007 | 05:51 AM
  #62
cartar452's Avatar
cartar452
I haven't yet but I'm curoius why not...what would happen? And what about the one bolt missing? Will that cause any problems?
Old Feb 20, 2007 | 05:59 AM
  #63
MSFITOY's Avatar
MSFITOY
Because it regulates your AF by sampling the exhaust...
I hate to tell you but take the header off and remount...try starting bolts from center loosely untill all are started...if you still can't get them all in, then you'll need to determine which one is the problem and grind out the bolt flange hole...all bolts MUST be torqued in properly or you'll experience exhaust leak...
Old Feb 20, 2007 | 07:18 AM
  #64
Bahamabart's Avatar
Bahamabart
And you consider this a "everything went smooth" installation .
On the bolt - you run the risk of warpping and exhaust leak.
On the O2 - you are denying your car's ecu of information - expect an engine light. Since it didn't reach - should we assume that bung is open?
Old Feb 20, 2007 | 07:27 AM
  #65
DrPhilGandini
The thing is, many of us have installed Megan headers and never experienced the "short sensor wire" problem. I wonder why yours is so short (drum roll)? Try removing the sensor wire from all the clips that hold it to the firewall, etc. mount it then reinstall the clips.
The first sensor is very important, the second one will throw lights if not installed after a cat, also.
Old Feb 20, 2007 | 07:39 AM
  #66
Bahamabart's Avatar
Bahamabart
Could he have mounted the fake cat backwards like one of the EBAY pictures depicts?
Old Feb 20, 2007 | 08:26 AM
  #67
cartar452's Avatar
cartar452
Thanks for the info...I will try that later this evening. I'll prolly disconnect everything again to get the bolts to all lign up then try to attach the o2 sensor. If the bolts don't lign up at all should i remove the header completely and try to bore the hole out? Thanks
Old Feb 20, 2007 | 12:13 PM
  #68
badhogan's Avatar
badhogan
Converters
If you guys are still looking for converter solutions I have a good source(especially in Atlanta) they are 200 cell spun units and can be had with O2 bungs for about 225.00
Old Feb 20, 2007 | 01:16 PM
  #69
MSFITOY's Avatar
MSFITOY
BTW...my O2 Sim is still working like a charm. Even though I have a cat, the sensor has been bypassed by the sim and still no CEL
Old Feb 20, 2007 | 03:46 PM
  #70
cartar452's Avatar
cartar452
Alright so tomorrow I will take the header back off and install both o2 sensors and try to get the last bolt in; I think I can I just ran out of time yesterday. Should any lock-tite be used with these bolts and if so what kind? Also, have any of you put the top heat shield back on by adjusting it or did you just take it off? And does anyone have a picture of how the "test pipe" mounts from the header to the cat-back? Thanks
Old Feb 20, 2007 | 08:09 PM
  #71
cartar452's Avatar
cartar452
Anyone?
Old Feb 21, 2007 | 06:33 AM
  #72
DrPhilGandini
Missed the questions, sorry:
don't use locktite. Maybe some anti-seize. I cut the top shield sides to fit over the Megan and reinstalled as there's a lot of heat rising from the header at idle/stop. The test pipe (race only!) mounts with the o2 bung furthest from the engine.
cheers,
Old Feb 21, 2007 | 07:55 AM
  #73
cartar452's Avatar
cartar452
cheers,
Thanks for the help. But with the test pipe, does the bung go on the top or bottom. It makes sense that it would go on the bottom but when mounted that way it doesnt line up with the exhaust at all. Am I doing something wrong here??
Old Feb 21, 2007 | 08:24 AM
  #74
Bahamabart's Avatar
Bahamabart
From my readings the flex joint on the Megan is one of the great attracting features over the OBX header.
When you say coming apart is it leaking? what steps are you taking?
Old Feb 21, 2007 | 10:19 AM
  #75
DrPhilGandini
Mmm...odd for sure. Yes, the bung goes toward the botton so you can screw the sensor in. I don't think you can put the sensor in the other way as there is no space in the tunnel. Given that, I dont' know why your pipes aren't lining up...Mine fitted perfectly, and pushed the Milltek back about 1/2" which was well within tolerances.
What catback are you using? Still, you took the stock header off, and the Megan should be pretty close to that. The flex joint changes shape over time, but mine does not leak after 6k miles (touch wood!)
