Drivetrain Operation Hot Air Intake
Old Aug 13, 2004 | 12:20 PM
  #226
USAMINICOOPER's Avatar
USAMINICOOPER
FYI, I'll have something really cool to show everyone with this mod by the end of next week. I just need to work a couple kinks out
Tell us all.....
Old Aug 14, 2004 | 08:24 AM
  #227
kapps's Avatar
kapps
Do tell
Old Aug 14, 2004 | 11:17 AM
  #228
Bisch's Avatar
Bisch
...soon enough.
Old Aug 17, 2004 | 09:50 AM
  #229
Revolver's Avatar
Revolver
Well my RU-1550 has arrived. FYI, Partsource got it for me in about 3 days (I'm in Canada). Before I install the HAI, I have a few questions:
1. Andy/andyone: Probably a stupid question, but...Would the greater efficiency of the HAI depend at all on having a 15% pulley? That is, will it also be a worthwhile mod for an MCS with stock pulley?
2. Andy: Got any more numbers or results...? Then again my intake is stock, and the HAI seems to have bettered the Alta in terms of air flow, so the HAI seems like a no-brainer for me. Which leads to my next question...
3. Andy/anyone: Does anyone have a graph/chart showing Alta intake vs. stock intake? Or, HAI vs. stock?
4. Bisch: Should I hold off on installing the HAI until we hear about your idea?
Thanks all!
Old Aug 17, 2004 | 09:58 AM
  #230
Bisch's Avatar
Bisch
Thanks all!
Nope. Do it. What I am working on has only a little to do with the HAI, but it could not be done without it. I hope to have it working by tonight...I'm taking it to the dragstrip Wednesday night for "testing".
Old Aug 17, 2004 | 09:59 AM
  #231
Bisch's Avatar
Bisch
...BRAIN FART.
Old Aug 17, 2004 | 10:41 AM
  #232
jinubob81's Avatar
jinubob81
they have a airflow and temp chart on the first few pages of the thread. check it out.
pretty impressive for a $35 mod.
Old Aug 17, 2004 | 10:47 AM
  #233
macncheese's Avatar
macncheese
Stock is stock, K&N is the filter discussed earlier, and foam is foam filter similar to the alta but MUCH smaller mounted directly to the TB. This was the biggest foam filter I could fit on the TB because the foam guys dont make oval filters like the K&N.
Old Aug 17, 2004 | 10:53 AM
  #234
CoryB
HOLY BIG CHART BATMAN!!!
Old Aug 17, 2004 | 10:55 AM
  #235
meanboy's Avatar
meanboy
Design..
Does fabricating your own pipe to the TB and using a smaller filter yield any results? Has anyone constructed any ram air type of system using the cowling and inline filter? Just curious, because it seems that the stock piping is producing bottlenecks with the wind flow.
Old Aug 17, 2004 | 03:55 PM
  #236
Revolver's Avatar
Revolver
Thanks Bisch. Good to hear we will have comprehensive pics and data by Wednesday night. Just jivin' ya.
Thanks Macncheese, exactly what I was asking about. HAI with RU-1550 it is then. Apologies if your chart was already in the thread...I have read it and couldn't recall seeing such a chart.
Old Aug 17, 2004 | 04:17 PM
  #237
jinubob81's Avatar
jinubob81
wow. i'm surprised at how well that dinky little foam filter did.
i went to the uni filter site, and they had a couple filters that may work pretty well.
But really, if the foam filter was bigger, i wonder how much better it would do... hmmmm....
Old Aug 18, 2004 | 08:13 AM
  #238
macncheese's Avatar
macncheese
I have two boxes of unifilters from when i was developing the intake. and the problem is that thats the biggest filter that will fit there! They do have slanted foam ones that may be bigger and work better but the K&N is cheap and readily available. I waited weeks for the filters from Australia. I'll dig them out and see what I have available.
Cheese
Old Aug 20, 2004 | 07:05 PM
  #239
kapps's Avatar
kapps
C'mon Bisch we're patiently waiting for these tests. I want to see some results.
Old Aug 21, 2004 | 06:38 AM
  #240
Bisch's Avatar
Bisch
I posted a couple days ago..."Operation Intercooler Kooler".
here: https://www.northamericanmotoring.co...ad.php?t=29666
Old Aug 21, 2004 | 06:57 AM
  #241
kapps's Avatar
kapps
Oh man, sorry I didn't notice that that was you. Looks promising.
Old Aug 22, 2004 | 07:50 AM
  #242
andy@ross-tech.com's Avatar
andy@ross-tech.com
My HAI is now Emissions-Legal
Yesterday, I installed an elbow on my K&N filter and plumbed a section of 1/2" ID heater hose from the driver's side valve cover into the elbow. Here's a quick pic:
This does away with the breather filter that I had and allows the crankcase vapors to enter the intake system, as they do stock. The elbow and the hose were about $3 each at the local Pep Boys.
Old Aug 22, 2004 | 08:08 AM
  #243
RLmini's Avatar
RLmini
I was thinking of doing the same thing, but am wondering if it could be done from the under side? I think there might be enough room. has anyone tried this?
Old Aug 22, 2004 | 08:48 AM
  #244
jlm's Avatar
jlm
Andy: looks like you cut that tube by chewing it off
By the way, I cleaned up my wiring...added the oil temp gauge and did a proper sensor mount for that and the oil pressure. Of course access was easier since I also had the subframe off to replace the steering rack. Even cleaned and re-olied my air filter. Went hog wild and built a new 4 gauge bracket and discretely mounted my intercooler temp gauge. Found the exhaust rattle was a loose exterior sheild on the cat.
Old Aug 22, 2004 | 09:58 AM
  #245
kapps's Avatar
kapps
Andy, for people with oil catch cans installed, would you use that tube to provide suction for the catch can?
Old Aug 22, 2004 | 11:18 AM
  #246
TonyB's Avatar
TonyB
jlm, got a photo of the 4 gauge bracket to share??? Would love to see! Oh, where did you eventually decide to tap from to get oil temp? The top of the oil filter and drain plug seem to be most popular, but each have their draw backs...
Say something about the HAI, besides the hose mauling, so Andy doesn't get angry .
Old Aug 22, 2004 | 12:12 PM
  #247
jlm's Avatar
jlm
removed the entire filter housing; tapped into the boss on the D side for the oil temp sensor; Tee-d into the existing oil pressure outlet, ran an -4 Aeroquip line to the new sensor, mounted on the firewall. this leaves the oil filter can stock.
the gages are close to the levers, but don't interfere. the steering wheel is still, barely, fully adjustable, I can just barely see all the gages from the sitting positon. oil press/temp on the left; boost, water temp on the right.
just noticed the gage layout is almost exactly the same as my Dodge truck!
Old Aug 22, 2004 | 12:47 PM
  #248
Teampajn's Avatar
Teampajn
First, Very nice job, I like the idea of all the guages in a place easy to read. My only question is does it feel crowded now?
Old Aug 22, 2004 | 01:33 PM
  #249
TonyB's Avatar
TonyB
I seem to recall you saying that you were going to try the boss side, and you did! Sounds like an ideal place. Does your boost gauge always rest at 0 when the engine is off? I'm always well into vacuum...
Old Aug 22, 2004 | 01:55 PM
  #250
jlm's Avatar
jlm
I have the electronic boost gauge, which rests at zero with the key on or off and engine off. at initial key on, before the engine starts, it re-calibrates itself to ambient=zero.
I don't recommend fiddling with the oil filter housing unless you have access due to header removal or dropped subframe. it is very hard to get at. I'd be happy to mod one for you, anticpating access at some later date.
