Drivetrain The Official ALTA AccessPORT Thread
Old Jul 29, 2013 | 02:54 PM
  #3501
magoolll's Avatar
magoolll
Chris,
Thanks for the info
Magoolll
Old Aug 3, 2013 | 08:59 AM
  #3502
Dr. Spade's Avatar
Dr. Spade
Just got a used one and installed it yesterday.
I certainly like it.
However, it did not want to mate with my PC! My computer says software not successfully installed. So I can't get any more maps.
I've got an intake and wanted a stage 1 map for the intake but I'm running one for just stock parts.
Old Aug 3, 2013 | 12:33 PM
  #3503
jrettew's Avatar
jrettew
Hey Chris. I'm looking at the descriptions of a couple of my maps. Can you tell me what these terms mean?
Enable Gear Based Torque Reduction.
Load Correction Factor Set To 1.
Old Aug 3, 2013 | 12:54 PM
  #3504
Dr. Spade's Avatar
Dr. Spade
Sounds like it will limit torque in lower gears to prevent too much wheelspin.
Old Aug 3, 2013 | 07:39 PM
  #3505
Dr. Spade's Avatar
Dr. Spade
You must have more maps than me.
I went through mine and there's 12 total I think.
Guess it wasn't updated for a while. Problem is my laptop won't download whatever software the AP is supposed to install on it. So how do I get more maps now?
Old Aug 5, 2013 | 01:43 PM
  #3506
ALTA_Chris's Avatar
ALTA_Chris
Have you tried installing the AccessPORT Manager? Without it, your computer won't be able to communicate with the AP.
Those are old notes that we made a long time ago when we were still revising the maps. None really matter to you now.
Old Aug 6, 2013 | 09:37 PM
  #3507
ryanschram's Avatar
ryanschram
What map should I be running? 09 JCW Clubby: Alta FMIC, DOS Intake and Noisemaker Delete, M7 Charge Pipe, and mufflers removed (straight pipe)?
Old Aug 6, 2013 | 11:15 PM
  #3508
CarlosDMotor's Avatar
CarlosDMotor
If your catalytic converter is removed, then stage 3. If not, stage 1 + FMIC
Old Aug 6, 2013 | 11:26 PM
  #3509
ryanschram's Avatar
ryanschram
the only cat i have is in the down pipe
Old Aug 6, 2013 | 11:36 PM
  #3510
CarlosDMotor
stage 1 + FMIC then
Old Aug 7, 2013 | 10:38 AM
  #3511
ALTA_Chris's Avatar
ALTA_Chris
You'd want to run a stage 1 FMIC map for those mods.
Old Aug 7, 2013 | 10:40 AM
  #3512
ryanschram's Avatar
ryanschram
thank you, i've been running the stage 3 for 2 days now. Will switch to the stage 1 next time in the car.
Old Aug 7, 2013 | 05:14 PM
  #3513
Dr. Spade's Avatar
Dr. Spade
Derp, searched for the software and downloaded AP manager to my PC.
Where do I go however, to easily download more maps?
I currently have 8 Stage 1 maps; 4 of them for larger FMIC.
4 Stage 2 maps
4 Stage 3 maps
There must be more right? I mean there's no map for an intake but that's a common mod.
Old Aug 7, 2013 | 05:28 PM
  #3514
ra2fanatic's Avatar
ra2fanatic
Seriously...if all you have is an intake don't even bother loading a map onto your car. Not worth stressing your engine until you have a bit more engine mods to support your MINI...
Old Aug 7, 2013 | 06:00 PM
  #3515
mbwicz's Avatar
mbwicz
The AP makes a nice difference, even on a stock engine. Its worth putting it on just for the boost in torque from 2500-4500.
The stage 2 and 3 maps are for a car that has free flowing, catless exhaust. Stage 1 is for stock engines, or ones with simple bolt ons, like your intake. There is no stage 1 with intake map. Try the different ones with the TPS, which is a program change to the throttle system, for a different response. See if you like it.
Mike
Old Aug 8, 2013 | 08:02 AM
  #3516
ALTA_Chris's Avatar
ALTA_Chris
4 Stage 2 maps
4 Stage 3 maps
It sounds like you have all the maps, we never made a map for an aftermarket intake. Was there another map that you were looking for other than an intake map?
Old Aug 10, 2013 | 10:03 PM
  #3517
Elementality's Avatar
Elementality
Going to keep an eye on the marketplace but if anyone is selling their AP let me know! Thanks!
Old Aug 10, 2013 | 10:46 PM
  #3518
ryanschram's Avatar
ryanschram
mine keeps causing a p2885 and i can't find the problem to any avail. I may be getting rid of mine soon.
Old Aug 11, 2013 | 07:19 PM
  #3519
Carey P's Avatar
Carey P
Did you check your turbo diverter valve to see if it's leaking. You may have stressed it out and blew the membrane. I'm selling a perfectly good spare in the marketplace if you need one.
Old Aug 11, 2013 | 10:55 PM
  #3520
Ch28Kid's Avatar
Ch28Kid
I had P2885 for 4 months. After I changed my turbo oil line, it went away.
Data log and send it to Alta.
Old Aug 20, 2013 | 07:35 PM
  #3521
Mindspin311's Avatar
Mindspin311
Alta.. I have installed a FMIC and high-flow cat downpipe. Currently running the Stg 1 + FMIC map. Would there be any adverse effects to running the standard Stg 1 map?
I ask because prior to install of those parts, the Stg 1 map felt stronger than the Stg 1 + FMIC map after parts install. Just curious if there is risk at all.
Old Aug 21, 2013 | 08:29 AM
  #3522
ALTA_Chris's Avatar
ALTA_Chris
Mindspin, you can run a regular stage 1 map with the mods that you have.
The stage 1 FMIC map should feel better though, since it's programmed to be more aggressive. Just make sure you're doing a reflash when you're changing the maps.
Old Aug 21, 2013 | 08:34 AM
  #3523
Mindspin311
Thanks, Ill switch around and see how things go.
Old Aug 21, 2013 | 11:37 AM
  #3524
fastNugly's Avatar
fastNugly
What would this stage 1 FMIC map do for WHP/WTQ?
Im a noob to mini and considering on grabbing a members AccessPort to get mine moving.
I got a 10 MCS Clubman too or will be picking it up this Friday
Old Aug 21, 2013 | 01:55 PM
  #3525
ALTA_Chris's Avatar
ALTA_Chris
Fasynugly, the stage 1 FMIC will give you an extra 10 WHP or so compared to the normal stage 1 tune. As long as you have a fmic installed, it'll work great.
