Drivetrain The Official ALTA AccessPORT Thread
Old Mar 19, 2013 | 08:37 PM
  #3276
Bigjoeski08's Avatar
Bigjoeski08
I get my AP tomorrow, which I bought off ebay and has been unmarried and ready to go. My question is my 07 R56 S hasn't been to the dealership in almost four years. I'm assuming i'm pretty behind on ECU updates which I don't mind, if i'm so far behind do I need to worry about updating the firmware on the AP?
Old Mar 19, 2013 | 09:09 PM
  #3277
MNIPWR's Avatar
MNIPWR
I would expect yours is covered. Ovoid updates from the dealer.
Old Mar 19, 2013 | 10:21 PM
  #3278
Minicircuit's Avatar
Minicircuit
I just had my 2007 mcs ecu updated 2 weeks ago at Mini to fix a P2188 code and Didn't have issues reinstalling my accessport map.
Old Mar 20, 2013 | 08:40 AM
  #3279
dwebber18's Avatar
dwebber18
Is this still available from Alta? I can't seem to find it on their website, if not how are you guys finding tunes and stuff like that?
Old Mar 20, 2013 | 08:57 AM
  #3280
myR56S's Avatar
myR56S
You can always unmarry it and go and have the ECU updated like I did
Or wait to install your AP until you get the update.
Old Mar 20, 2013 | 08:58 AM
  #3281
Tillos's Avatar
Tillos
It is not, you'll have to do what myself and many others have done, and find one used / stocked somwhere. I was lucky enough to find a shop that had one in stock and unused. You'll need to do some digging, but I promise you, it's possible.
Old Mar 20, 2013 | 08:59 AM
  #3282
myR56S's Avatar
myR56S
The AP is no longer available as it is no longer being produced however I believe ALTA is still providing support/maps until July of this year.
I have been working with Chris from ALTA and Jeff from Perrrin for maps and support. They have been awesome.
Old Mar 20, 2013 | 10:07 AM
  #3283
Bigjoeski08
OK got the tune load onto the car. Stage One non TPS on 92 octane, I can only run 93 octane here in RI though. Power is amazing but I'm experiencing the bouncing idle which is not terrible but noticeable.
Old Mar 20, 2013 | 10:30 AM
  #3284
IQRaceworks's Avatar
IQRaceworks
Since ALTA is no longer making the AP's, what's the next best thing out there for someone wanting to "tune" their car that doesn't have access to a chassis dyno? Does anyone else make something like this that will log your data, and then allow you to send the data off and have a custom tune made for your car?
Old Mar 20, 2013 | 10:52 AM
  #3285
DRoc7822's Avatar
DRoc7822
Try looking at the Evolve Tune. Thats what I plan on doing.
Old Mar 20, 2013 | 12:39 PM
  #3286
Bigjoeski08
I just spoke with Chris and he said he would be sending me another map to help with the idle issue. Once he emails me the map and load it, i'll report back.
Old Mar 20, 2013 | 01:16 PM
  #3287
Black Sharpie's Avatar
Black Sharpie
My idle is a little bouncy too and the initial throttle for each gear seems bouncy too. Is this something some tweaking can fix? 2012 jcw manual.
Old Mar 20, 2013 | 01:27 PM
  #3288
LarriB's Avatar
LarriB
I had an idle bounce problem and Chris and Jeff sent me a map. It cured the idle bounce, but the throttle seemed "surgy", not really progressive. Since I was going to install a FMIC and change the map, I didn't ask them to fix it. I'm sure they would have. My FMIC map has a slight idle bounce, but I'm inclined to live with it, although I just installed the FMIC this weekend and my feelings may change.
Old Mar 20, 2013 | 01:54 PM
  #3289
jrettew's Avatar
jrettew
OBD II that reads super knock codes?
The AP indicates that I am throwing super knock codes, even with stage 0. I'd like to take it to the dealer and have them look at the problem, But to ready it for the dealer, I have to uninstall the AP, which clears the codes. Since the codes are intermittent, I don't know when the code is definitely there to take it in. So I bought a generic OBD II reader and use Torque with it, but it does not pick up super knock codes. I have read that the Bavarian Technic reader will do it, but it is $275. Does anyone know of a cheaper unit that will do the job?
Old Mar 20, 2013 | 04:47 PM
  #3290
DasCooper's Avatar
DasCooper
Custom tune for $75 or RMW
Has anyone done the custom tune that Alta offers for $75? What does this involve, doing a log dump? Or is it more involved?
I have an 09 MCSa and originally had a pronounced lurching/jerky shifting issue. The map they sent: -MCSa Stage 1 FMIC 91oct H910B Rev1.ptm helped quite a lot. However under load the car still shifts jerky. Its like the torque is not matching up with when the car shifts, if that makes sense.
I know Jan also can tune MCSa's. Anyone had good sucess with RMW tuning an automatic?
Old Mar 20, 2013 | 04:51 PM
  #3291
Black Sharpie
@DasCooper
I am interested in this as well. I have the same issue where shifting is almost impossible to match up. It isn't a clutch ride, it just is smoother wihtout the tune. I noticed the difference when switcing back the the stock map. I would say surge is a good word for it
Can anyone from alta chime in perhaps with some tips or advice?
Old Mar 20, 2013 | 06:36 PM
  #3292
mbwicz's Avatar
mbwicz
I've got a tune that I am happy with, but I have 92 octane gas around here, and I am currently running without a FMIC. The point is that there is probably a map that does better than the one that you are using now. Mine is rev 6_3 from April 2012.
If you want to PM me your email, I will send you the map that I have to see if this is better for shifting.
Mike
Old Mar 20, 2013 | 06:41 PM
  #3293
CarlosDMotor's Avatar
CarlosDMotor
If other people are getting rough idle fixes, I want one too! Running 91 octane stage 1 automatic. I think ecu is H910b or something like that. If you guys could do something with the shifting too it would be great, but I don't think the AP controls that. thx
Edit: Like post a few above, it only happens when pushing hard. Also alot of cutting when you push the throttle and it downshifts in non sport mode.
Old Mar 21, 2013 | 04:55 AM
  #3294
mbwicz's Avatar
mbwicz
The AP has the ability to affect the smoothness of the shifting. The map that I am using still has idle issues (high idle when cold, some surge when at a stop light), but neither of these issues bother me. For me, it is about smooth shifts and the great boost in torque.
Chris, can you chime in here? Is it possible to release an updated/'better' tune for autos on your website? I'm happy with mine (92 oct, rev 6_3).
Mike
Old Mar 21, 2013 | 08:17 AM
  #3295
Carey P's Avatar
Carey P
It is not just Autos that have this problem. I have a 2007 MCS Manual and had the surging rpms while shifting under torque since the start of using the AP. Now I'm using MCS Stage 1 FMIC 91oct H520B and still have the problem. I've sent logs to Jeff, but no response for some time.
I use Sport mode always, and get a bounce in idle occasionaly and touchy peddle response but that's ok. The real problem is the rpms keep going up after pushing in the clutch when under boost so when the higher gear is engaged the car jurks or surges forward (unless you deliberately wait until the rpms drop which is a stupid thing to have to do). You probably have a different effect from an Auto but the same root problem.
Old Mar 21, 2013 | 01:11 PM
  #3296
LawrenceC's Avatar
LawrenceC
Just got mine today. Idle is fine everything is in order I reflashed my 07 MCS earlier.
Big difference is power delivery is much more smoother definitely feel more torque and hp increase.
I have an intake and mid cat/res removed the AP recorded 16.7psi
Old Mar 21, 2013 | 01:56 PM
  #3297
Bigjoeski08
Never heard from Chris today, so nothing to report. I did drive it today in 45 min traffic a and it was jumpy but didn't effect the drive ability.
Old Mar 21, 2013 | 07:48 PM
  #3298
CarlosDMotor
Mike
I think that the idle is purposely high to get the engine up to temp quicker when cold starting or cold outside
Old Mar 22, 2013 | 05:45 AM
  #3299
Richieb0y28's Avatar
Richieb0y28
Quick question - We have 93 here in Jersey, but when I travel out of state this summer, should I switch the map to 91 before traveling out of state, in case other states don't have 93? How will this affect the car? eg. if I have 93 in the car now, then switch the map to 91, what issues could I experience?
Old Mar 22, 2013 | 10:50 AM
  #3300
MNIPWR's Avatar
MNIPWR
Do some of you with just buy the AP with a no absolutely no knowledge of anything! You should probably learn what the octane number means. Then make decisions yourself instead of listing to people on the Internet. That being said be extremely careful running the best commercially available gas could cause some issues.
