Drivetrain Secondary intercooler? Alternative to water-air intercooler?
Old Nov 23, 2003 | 12:49 PM
BC28's Avatar
BC28
from BBR's website (http://www.bbrgti.demon.co.uk) :
"The BBR Phase 3 includes phase 2 with the addition of BBR's twin high flow intercooler assembly. The conversion maintains the original top mounted intercooler and in addition uses a secondary front mounted cooler. This includes all related pipe work, clamps and fixtures, and as with all our conversions BBR custom mapped software."
Unfortunately there are no pics.
Old Nov 23, 2003 | 05:48 PM
vdubdoug's Avatar
vdubdoug
I am just trying to figure how they woudl do that. I wonder if that set up will suffer from a pressure drop but will the lower temps compensate for that? Interesting!!!!!
vdubdoug's Avatar
vdubdoug
Old Nov 24, 2003 | 08:11 AM
kenchan's Avatar
kenchan
im using a nitrous spray ring on the topmount intercooler on my wrx.
i'd opt for that since its cheaper to do (probably) and lots more efficient.
but make sure the fuel injectors and ecu can handle the extra
psi before blowing up the motor. (you'll probably just get a cel at the
worst case though).
Old Nov 24, 2003 | 06:58 PM
BlueMCS's Avatar
BlueMCS
Damn, just when I thought I had figured out all the short forms....
what's a cel?
BlueMCS's Avatar
BlueMCS
what's a cel?
Old Nov 24, 2003 | 08:59 PM
kenchan's Avatar
kenchan
check engine light
Old Nov 25, 2003 | 03:28 AM
jlm's Avatar
jlm
hey blue...what is that short form on the side of your car? a Celtic rune?
Old Nov 25, 2003 | 01:16 PM
BlueMCS's Avatar
BlueMCS
Thanks Kenchan!
No, it's Latin and it means "Now Kiss My Rear Wiper".
It's actually "88" half blown off the car from doing 115 down the back straight at the Glen.
Old Nov 26, 2003 | 12:54 PM
Samtrak's Avatar
Samtrak
this is a very interesting topic yall....
im looking forward to something atainable by us ...
the aftermarket will surprise us in the comming year.
Old Nov 27, 2003 | 08:44 PM
Coopertino's Avatar
Coopertino
This seems stupid unless you have a turbo. You dont want to loose boost. More piping and wide open intercooler = severe boost loss.
What are they thinking
Old Nov 27, 2003 | 09:37 PM
10851CS's Avatar
10851CS
>>Thanks Kenchan!
I like the Latin version better.
Earl
Old Nov 27, 2003 | 10:26 PM
Samtrak's Avatar
Samtrak
Coopertino, maybe that explains why BBR GTI got the worst review from EVO Nov03.
So then what do you think of the cold "stuff" intercooler sprayers?
Old Nov 28, 2003 | 05:31 AM
kenchan's Avatar
kenchan
easiest way to get more boost is to chill the intercooler. but im not
familiar with the mini's ECU and how it will accept/reject the frigid temps.
at this momement, i would be worried about the clearance of the scoop.
not sure if you can route a 6AN fitting tube in there. the solenoid will
definitely be have to be placed elsewhere.
Old Nov 28, 2003 | 09:24 PM
minicoop78's Avatar
minicoop78
_________________
Old Nov 29, 2003 | 07:16 AM
kenchan's Avatar
kenchan
do they sell rings with the fitting facing outward like that instead of perpendicular to the ring, or did you cut/weld it?
Old Nov 29, 2003 | 05:41 PM
minicoop78's Avatar
minicoop78
like this minimadness sell it ask for george.
SJ-R50
Oct 28, 2015 08:39 AM
schr5530
Oct 5, 2015 08:28 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
Adam Bradbury
Sep 28, 2015 04:15 PM
daviday
Sep 25, 2015 01:31 AM
