Drivetrain BSH catch can and dual boost port install
Old May 27, 2010 | 09:56 AM
  #151
DarkSideMINI's Avatar
DarkSideMINI
Thanx for the quick reply! That is what i figured but I wasn't sure...very good location!
But I have to see if it will work with the DoS CAI as well!
Have fun in Japan!
Originally Posted by Tron Chief
On the cross bar you can see the silver bolt that came in the kit. All I did was slide the washer into the center of the frame and put the bolt down put the catch can onto the bolt and then attached. Having the cold air intake (I think Custom Mini Shop has one left) allowed me to remove the factory little tube that is the intake since I now have a large air intake thus allowing the catch can to be located there. I would be happy to take a photo of it from a different angle however I'm currently in Okinawa Japan and will not be back in the States until Mid July. Steve at Custom Mini Shop did the installs and has both of the major pieces i.e. intake and catch can along with the dual port boost plug and his contact information is in my signature line.
Old May 27, 2010 | 11:45 AM
  #152
Tym2Relax's Avatar
Tym2Relax
I was curious if someone could drain the can using a quick drain valve. Would something like this work?
Old May 27, 2010 | 01:17 PM
  #153
Mini'mon's Avatar
Mini'mon
Several folks are using the BSH OCC with the DoS CAI. You can see a great example here:
https://www.northamericanmotoring.co...728-post1.html
Old May 27, 2010 | 01:23 PM
  #154
Clubmaste00's Avatar
Clubmaste00
There are a variety of ways to drain the contents. I just returned from a 4k round trip Michigan to AZ and back and drained mine of some foul looking brown stuff - probably 4 ozs. Problem was that I drained into a small plastic cup I had handy and left it on the work bench overnight. Fortunetly it was on a towel as when i looked at it the next morning the plastic cup had dissolved leaving just the very bottom of the cup and the upper rim. Not sure what type of plastic but that stuff must had some serious hydrocarbons in it.
Old May 27, 2010 | 02:31 PM
  #155
Dwight Walhood's Avatar
Dwight Walhood
SERIOUS INDEED !! If I remember right, that's why PCV systems were one of the first smog controls put on cars.
Old May 28, 2010 | 10:37 AM
  #156
DarkSideMINI
Well that spot is already taken...by the W2A-IC!
Old May 28, 2010 | 11:28 AM
  #157
Tym2Relax's Avatar
Tym2Relax
I see this question to BSH was asked before, but also wanted to know if there are any consequence to not emptying the catch can. What happens when it fills up?
Old Jun 4, 2010 | 08:40 AM
  #158
Dwight Walhood
Cracked/blown cam cover, fouled/damaged turbo, clogged/cruded IC and major piston ring blow-by. Other than that, not much!
Old Jun 4, 2010 | 11:10 AM
  #159
Tym2Relax's Avatar
Tym2Relax
Thanks Dwight for the info. That's way worse than I imagined. Even though I don't think I would forget, it's good to know what could happen if I did (forgetting IS a possibility for everyone). I suppose there isn't a way to design a way to release the contents if the volume exceeded a certain amount.
BTW, I see you are in San Marcos. I really like it down there. We have some friends there and love to go down and get on the lake.
Old Jun 4, 2010 | 01:44 PM
  #160
Dwight Walhood
Glad I could help. BTW, if your thinking about an OCC system only 2 are worth considering IMO, the 42 Draft Design and the BSH. They're the only ones I know of with baffling inside, dip sticks and drain plugs. If your MINI's a turbo, go with the BSH as it'll push all the crank case phlegm thru the OCC before ingesting.
Yup, been in San Mucous since '74 when there were 4K folks in town. It's now 85K! GREWSOME .
Old Jun 4, 2010 | 02:30 PM
  #161
MaverickGun's Avatar
MaverickGun
I just got my BSH Catch Can and Direct Dual Boost Tap in the mail yesterday and I wanted to mount it in the same place that onefish2 and 09MellowJCW has theirs in order to accommodate my DoS. It looks like they needed extra hose, though. Does anyone know exactly how much hose I'll need and what kind I need to get? I'm assuming it's something I can pick up at Home Depot or something... Otherwise I'll give BSH a call and see if they can cut me some extra.
Old Jun 4, 2010 | 03:04 PM
  #162
Dwight Walhood
Just give BSH a call and save yourself a lot of leg work. When I put my system together, I looked everywhere for .75"/19mm ID tubing that could handle harsh petrochemicals. Finally got it from BSH for $2.50/ft.
Old Jun 5, 2010 | 07:24 AM
  #163
MaverickGun
Well this is somewhat distressing... I tried sending an e-mail yesterday to minisales@bshspeedshop.com but it was returned saying the inbox was full. I also tried calling them at around 3:00 pm So Cal time and no one picked up. Not even an answering machine! It must have rung at least 15 times. Today I went onto their website to check their hours and it said they should have been open until 6:00 pm on Fridays. So this morning I try sending them a message through their Contact Us page on their website, and that was returned too. Anyone have any idea what's going on?
Old Jun 5, 2010 | 09:06 AM
  #164
onefish2's Avatar
onefish2
Try contacting Sushil Rao sushil@bshspeedshop.com. He is the MINI guy there.
Old Jun 5, 2010 | 09:25 AM
  #165
Dwight Walhood
Try 42 DraftDesign.com. They've got the tubing at the same price ($2.50/ft.).
Old Jun 5, 2010 | 03:14 PM
  #166
MaverickGun
Awesome. Thanks a lot!
Edit: Sushil's inbox is full. That's a little too bad, since I wouldn't mind getting the tubing from BSH. I'll have try 42DraftDesigns.com instead. Hopefully about 10ft should be enough just in case I manage to mess up somewhere along the line. Thanks for all the help!
Old Jun 5, 2010 | 03:32 PM
  #167
tominizer's Avatar
tominizer
I think Sushil is no longer with BSH.............. but I can't confirm that.
Hydraulic supplier !?!?? Wouldn't they supply the same type of hose ?
Old Jun 5, 2010 | 04:35 PM
  #168
tominizer's Avatar
tominizer
The over-sized plug for the boost tap, does that have to be ordered separately?? I got my catcher can and boost tap but the over-sized plug is nowhere in the kit .....................
Old Jun 5, 2010 | 04:52 PM
  #169
MaverickGun
Mine came with the Direct Dual Boost Tap. Inside the little baggie there were ten things: the boost tap, the retention clip, two o-rings, two small silver pipe plugs, one silver buttonhead set screw, a 90 barbed fitting, a straight barbed fitting, and the extra large pipe plug. The pipe plug looks exactly like the two smaller silver ones, but it's black and (obviously) quite a bit larger.
Old Jun 5, 2010 | 05:54 PM
  #170
tominizer's Avatar
tominizer
yeah........ like said, no extra large pipe plug in my kit. :(
Kinda was hoping to have this on for my drive from Toronto to Montreal this week. Oh well. This went hand in hand with the Joey mod I wanted to do but the two lower outside bolts holding the lights to the chassis both are seized and the PO must have torques them so hard they stripped them in the plastic bracket and so now they both spin but no come out. :(
My mod weekend is 0 for 2. Ballz.......
Old Jun 5, 2010 | 06:08 PM
  #171
onefish2's Avatar
onefish2
Installed the BSH OCC on 4-22-2010. Six weeks later, this is what came out of the catch can this evening.
My wife is a nurse. So asked her to bring home some kind of syringe so that I could suck this goop out of the catch can from the dip stick hole.
Its a 2 oz/60ml syringe. I stuck a drinking straw into the bottom of the syringe and was able to remove all of the liquid from the catch can. In total I got about 6 ounces of this nasty stuff out of the catch can.
This stuff is nasty. I can only imagine what is going on down if the gulf with the oil spill from the Deepwater Horizon oil rig.
Old Jun 5, 2010 | 06:12 PM
  #172
Rixter's Avatar
Rixter
Fish
Is that just from street driving or track as well?
Old Jun 7, 2010 | 10:40 AM
  #173
MaverickGun
Okay, so it looks like one of my e-mails must have gotten through to BSH. Despite Sushil's inbox being full, I got an email from a Phil regarding the extra tubing I wanted. Unfortunately, I've already ordered from 42 Draft Designs . Hopefully It's the right stuff.
I suppose that means you can try e-mailing phil@bshspeedshop.com about your missing plug pipe. Good to know someone's keeping an eye on things .
Old Jun 7, 2010 | 10:48 AM
  #174
Mini'mon's Avatar
Mini'mon
BSH made a vendor announcement that Sushil no longer on their team. They mentioned that we should direct all emails or inquiries to Justin@bshspeedshop.com or Sales@bshspeedshop.com
Old Jun 7, 2010 | 10:54 AM
  #175
MaverickGun
Oops. Must have missed that memo . Well, it's good to know for future reference . Thanks Mini'mon.
