Drivetrain BSH catch can and dual boost port install
Old Jan 18, 2011 | 03:31 PM
  #251
etalj's Avatar
etalj
Originally Posted by DneprDave
It looks like a big version of the grub screw. It screws into the dual boost port from the end that connects to the cam cover and blocks flow through that line to the intake manifold.
You can see it on BSH's site, it's shown screwed into the top part of the boost port in the photo.
http://www.bshspeedshop.com/store/po...=17029&imageid=
Dave
Definitely didn't get that
Old Jan 18, 2011 | 04:28 PM
  #252
onefish2's Avatar
onefish2
The dual boost port is an optional part that you purchase separately. It solves 2 things. You can use it by itself as a boost tap for a gauge or if used in conjunction with the OCC it will block off one side to allow use of one catch can. All the vapors now flow through the catch can.
Old Jan 18, 2011 | 04:50 PM
  #253
etalj's Avatar
etalj
Yeah I know, I bought it for both reasons, but mainly so that I could block off the one side
Old Jan 19, 2011 | 06:01 PM
  #254
hollowman's Avatar
hollowman
I just purchased a BSH CC and dual boost port. Looks to be built very well. I have heard that you can use the boost port to do seafoam treatments, but I have two questions regarding that procedure. First of all, if I use the large port plug to route all the vapors to the OCC, can I still put seafoam into a port? I don't plan on attaching any gauges to the boost port but I would like to install one nipple (if that's the proper term, it sounds kinda dirty) and have it closed off when not in use. What would you recommend to seal it off with when I'm not needing to do seafoam treatments? I'm assuming a hose and clamp would work, I'm curious to see what others have done.
Thx.
Old Jan 19, 2011 | 07:00 PM
  #255
DneprDave's Avatar
DneprDave
Leave the plug in the boost port. When the engine is idling, there is a vacuum in the intake manifold. The Seafoam, or what ever solvent you choose to use, will be drawn into the intake manifold and then into the intake valves, just like you want.
Dave
Old Jan 21, 2011 | 03:00 AM
  #256
oldcracker's Avatar
oldcracker
Originally Posted by etalj
Hi guys,
I have a RHD JCW with a DoS CAI, so mounting the BSH OCC wasn't easy, and I ended up using a hold that was free (stock intake uses it). I installed the BSH OCC and dual boost port as shown in the pictures. Now, I don't quite see how this eliminates the need for two catch cans, as the left hand side PCV line hasn't been blocked off in any way, so what have I done wrong?
did you have to bend the silver mounting bracket to mount the can on the hole that the stock intake uses? because I thought that hole wasn't flat?
Old Jan 21, 2011 | 12:21 PM
  #257
etalj's Avatar
etalj
No, didn't have to bend anything, and you're correct, the hole is not flat. I think it's just the camera not picking up the slight angle the OCC sits on
Old Feb 3, 2011 | 05:00 PM
  #258
gregsmini's Avatar
gregsmini
I am getting large amounts of water in my OCC. Sunny is a daily driver whenever the roads aren't icy, which hasn't been often. It's been cold in the Northeast, and with the snow, have been driving my SUV most of the time. I've emptied the OCC about three times in the last two months and get at least a cup of water with some oil. In order to empty the OCC, I have had to remove it which is a PIA.
I received my Da Vinci Syrup pump which I bought on the web, with shipping for ten bucks today. Pulled the dipstick on the catch can and using the pump, emptied the OCC. It doesn't get any easier than this, pumped out about 9 ounces of fluid.
By the way, I drive Sunny to work, about sixty miles round trip mostly expressway driving, when the weather permits. Today was one of those days. Point being, I do get it warmed up, not many short trips and I still build up alot of water. Why? I'm surprised that is the case with the engine being run at operating temperature.
BSH should stock these pumps, without a doubt, best way to empty the OCC!
Old Feb 3, 2011 | 05:18 PM
  #259
DneprDave's Avatar
DneprDave
I'd guess that it depends on the humidity, more water in the air, more will drop ou in the catch can.
Dave
Old Feb 3, 2011 | 05:33 PM
  #260
Mini'mon's Avatar
Mini'mon
Originally Posted by gregsmini
I received my Da Vinci Syrup pump which I bought on the web, with shipping for ten bucks today. Pulled the dipstick on the catch can and using the pump, emptied the OCC. It doesn't get any easier than this, pumped out about 9 ounces of fluid. . . .
DoS will be announcing that we're a BSH dealer next week. Maybe it's time that we start looking for a cheapo pump that we can stock in the online store.
Others have mentioned solutions similar to this, but thanks for this reminder. This looks beyond helpful for this task.
-Clint
Old Feb 3, 2011 | 06:33 PM
  #261
DneprDave's Avatar
DneprDave
I have a big syringe thing, that I got at Harbor Frieght. I don't know what it's called. It's made of steel, about 2" in diameter and 8" long. I put a vinyl hose on the end and stick it in the dipstck hole of the BSH oil catch can and suck the oily water out.
Dave
Old Feb 4, 2011 | 05:44 AM
  #262
///Mflossin's Avatar
///Mflossin
It's astounding what this thing catches. It amazes me that these cars even run without a catch can.
Old Feb 4, 2011 | 10:13 AM
  #263
thevelourfog's Avatar
thevelourfog
Here's the contents of my catch can after about 15k miles. It didn't really fill up much until the humidity level picked up, so about 3/4 of this bottle was filled in the last 3-4k miles I'd say. Looked like a latte when it came out of the can. The water bottle label is on, but the level is right below the bottom of the label.
Old Feb 4, 2011 | 10:58 AM
  #264
Mini'mon's Avatar
Mini'mon
I say this alot to folks, but it's simply amazing how black that collected synthetic oil vapor gets.
Old Feb 9, 2011 | 06:36 PM
  #265
fishbert's Avatar
fishbert
-Clint
Nifty. Maybe I'll order my 2nd catch can through you guys.
Do you know what kind of hose they supply with their catch can kit? The length I got from 42DD appears to be collapsing and I'd like to swap those lines out with something a little sturdier (they're also labeled "heater hose" and I heard those can sweat oil).
Also, any insight as to why BSH got banned on these forums? Nobody seems to know (I thought they were one of the better vendors here in terms of community involvement and interaction), and it's been giving me some pause on pulling the trigger.
EDIT: or... wait... maybe they're not banned any more? Their posts say 'Vendor' again instead of 'Banned', but they still haven't posted anything since August. Weird.
Old Feb 9, 2011 | 06:54 PM
  #266
Rixter's Avatar
Rixter
Just curious howw often are OCC owners topping up oil? Is the crude mostly just water and some oil or is there a fair amount of oil being trapped in the vapors?
Old Feb 9, 2011 | 07:32 PM
  #267
///Mflossin
I have no dark crap...all gasoline colored crap. My car only has 5,400 miles on it.
Old Feb 9, 2011 | 07:45 PM
  #268
onefish2's Avatar
onefish2
Looks nasty to me. About oil, I have never had to add or top of the oil in my car. I change the oil and filter very 5000 miles.
Old Feb 9, 2011 | 07:53 PM
  #269
Dwight Walhood's Avatar
Dwight Walhood
That's mostly water with half burned oil and other nasties temporarily suspended in the water. Ugly, poisonous stuff!
Old Feb 10, 2011 | 12:11 AM
  #270
Mini'mon's Avatar
Mini'mon
Originally Posted by fishbert
Do you know what kind of hose they supply with their catch can kit? The length I got from 42DD appears to be collapsing and I'd like to swap those lines out with something a little sturdier (they're also labeled "heater hose" and I heard those can sweat oil). . .
You're looking for Parker Jiffy Hose or something similar. Measure the inner diameter of the hoses for your catch can (and how much length you need). Once you know that you can go to a local auto parts store and ask what they have. You're looking for oil resistant vacuum line hose, vacuum rated fuel line hose, or "Push On Hose."
Reinforced hose that is made from Buna-N (nitrile) rubber generally has excellent oil resistance. That would be a good choice for a catch can.
Hope this helps.
-Clint
Old Feb 14, 2011 | 08:46 PM
  #271
gothmdoc's Avatar
gothmdoc
Hmm.. good question, don't plan on having to top up but will let you know if I ever do.
Old Feb 14, 2011 | 09:13 PM
  #272
Dwight Walhood
If you're having to top up on oil, it's got nothing to do with the OCC. Could be a much more serious problem. With 42K down the hatch, I've never had to add a drop of oil to my MINI.
Old Feb 14, 2011 | 09:33 PM
  #273
Rixter's Avatar
Rixter
That's interesting. I wouldve thought that the vapors carried portion of the oil into the OCC and therefor out of the engine. Oh well I'm not disagreeing, in fact I'm quite relieved, one less thing to check. Thanks Dwight
Old Feb 14, 2011 | 10:49 PM
  #274
fishbert's Avatar
fishbert
I thought it was generally accepted that the MCSs and JCWs use oil and should have their levels checked at every fill-up, topping up as needed.
Old Feb 14, 2011 | 11:06 PM
  #275
fishbert's Avatar
fishbert
Hope this helps.
-Clint
Awesome. I'll do that.
Thanks!
