Drivetrain RMW's "Guess what's in the box?"
Shiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiit that's already started. You should have heard Collin up at Church's the one/only time I ever met the guy in person.
"I made that for him, you know..." blah blah blah..
Sure. Sure you did. Go play with your V-8 M3 and stop messing around with the Minis.
lol... Colin did make the mount drawings
Both bits look very nice
That might be the little grain of truth to all his story telling, but from the way he talks, you wouldn't be anywhere without him or Daniel.
Those pieces look great, by the way... why must the Time Attack at Buttonwillow be the same weekend as AMVIV?
You should head over to SOW next Friday and bring your track monster with you.
if you saw the inside of the blower hat you would be even more impressed
bummer.... have to make up my mind as I want to go to Buttonwillow for the Time Attack..........If I can get it all back together and tuned I may take it to SOW as I have some Hoosiers that are toast and it will be fun cording them and not feeling bad.
It's going to start..... that's a given
when people see the power under the curve at the same hp levels of these turbo cars they will wonder why they have a turbo except to hear the blow off valve
Is that the Redline event on 3/29? If so, I'll probably see you there. I'll be running on 3/27 in my measly little 170hp car shooting for a 2:08-2:09, that will be a challenge
. I won't be running the time attack obviously as I'm driving a street car, but was planning to hang out and check everything out.
tested the new ECU today
runs the stock throttle body and is fully calibrated now
accepts tuning changes while it runs. Will be able to run alternate maps for methanol and nitrous. Has two step and the all of the features you need.
We will be going through the canbus now to turn off the check engine light. This may take some time but the ecu is operational now.
I will be running this on the TVS for now to see what it can do.
Wish this was around when I blew my ECU up at the start of last year!!
Good thing is the car is fully controllable now.......
The throttle body was the hard part
the final key is to get all of the lights to go out
I plan on starting it before the rotors even get done. We have the dimensions of the rotors so building a case around them will work
