Drivetrain RMW's "Guess what's in the box?"
Old Nov 17, 2008 | 05:56 AM
  #576
Revolution Mini Works's Avatar
Originally Posted by Myke@RPI
Nope... I know what this guy wants, He wants power with reliability... a balance between both...JAN, What should I tell this guy to get?
Have him call me to get the best fit of what he wants
Originally Posted by NajaNaja
I believe a comparison between s/c and T only cars is useless.
Imho in similar intake pressures always the T only cars will have
an advantage of 40-60hp. Also better fuel economy
But if some day Eaton releases TVS roots for the M45 then
it will be a nice and easy buff but not to be compared
with the car you made with the stroker.
I think a comparison is needed
you are comparing the powerband of a supercharger to the powerband of a turbo and HOW that power is applied
the supercharger is much easier to drive fast as the power is linear and your powerband is 3,000 rpms bigger
the fastest car at the track last Friday wasn't the turbo cars it was a supercharged car and by a heft margin
Old Nov 17, 2008 | 09:20 AM
  #577
NajaNaja's Avatar
NajaNaja
of course driveability is like comparing day with night
but in these cases the Driver must understand the cons and pros!
Old Nov 17, 2008 | 10:36 AM
  #578
so how is the turbo better
Old Nov 17, 2008 | 11:24 AM
  #579
Myke@RPI's Avatar
Myke@RPI
Maybe just being able to turn up the boost on the fly... or turn it down... bigger turbo for more top end... certainly not better for road racing but maybe more straight line speed... just speculation jan...
Old Nov 17, 2008 | 11:42 AM
  #580
NajaNaja's Avatar
NajaNaja
If you compare a T only against a s/c car that both
have e.g. 1.6lt engine, 1.5bar and 8000rpm limit
then the difference in max bhp should be about 50+ for the T only.
But I am sure the s/c car will be much more easy to drive BUT
for me it is tottaly useless to compare. These setups are tottaly
different except that the supercharger you have a goldern rule
to follow in order to have balance between s/c efficiency and engine load.
Similar with T only, were you can fit bigger turbos but you destroy
the power curve.
But for me the biggest problem on daily driven cars with s/c car upgraded
to make over 300whp from 1.6 lt is that you cant have
the option of low and high boost which is very helpfull in daily cars.
I believe in a track it is possible to see a 250 n/a car run faster than
a 280s/c car and both to be faster than a 330Tonly car.
thats why I say the driver+owner must know all of these so it is useless
to compare.
Old Nov 17, 2008 | 11:46 AM
  #581
NajaNaja's Avatar
NajaNaja
imho best setup stroker with a 2871
Old Nov 17, 2008 | 12:03 PM
  #582
Paul Webster's Avatar
Paul Webster
That would be nice
Have you got past Longboards 299.7 yet Jan ?
Old Nov 17, 2008 | 12:25 PM
  #583
newbs49's Avatar
newbs49
I'm sure he has even without the tune or the ECU fix he has planned.
I'll wait for his answer when the car is complete.
Old Nov 17, 2008 | 05:26 PM
  #584
the power curve.
to compare.
so if it's faster why would you want to buy the turbo car then?
Old Nov 17, 2008 | 11:01 PM
  #585
//MZero's Avatar
//MZero
FOR TEH POWAR!
Old Nov 18, 2008 | 12:19 AM
  #586
NajaNaja's Avatar
NajaNaja
s/c: could be faster in cornerning but not on the drag.
I cant understand why you try to compare them!
and 2lt cars we see a lot of them from the JDM market
such as s2000 but these have massive issues when they
reach 330+whp... imagine with the little mini what will happen.
anyways...
  #587
NajaNaja's Avatar
NajaNaja
Originally Posted by //MZero
FOR TEH POWAR!
+1
Old Nov 18, 2008 | 06:12 AM
  #588
anyways...
probably because you are trying to compare them
you brought up the differences so now you have comparisons
I have tested the 2.0L over 600hp on my turbo car.....
any questions?
Old Nov 18, 2008 | 06:27 AM
  #589
Paul Webster
any questions?
What does it run
Can you post the dyno sheet up
Old Nov 18, 2008 | 06:31 AM
  #590
Originally Posted by Paul Webster
What does it run
when you want to send me 10k in axles I will take it to the strip
Old Nov 18, 2008 | 07:25 AM
  #591
PGT's Avatar
PGT
why can't just have proper axles built? raxles.com has a good rep
Old Nov 18, 2008 | 07:33 AM
  #592
I secured a builder at SEMA
Old Nov 18, 2008 | 07:41 AM
  #593
PGT's Avatar
PGT
sweet.
Old Nov 18, 2008 | 08:00 AM
  #594
Paul Webster
There you go, at least you have the right machine to test them out with.
What psi you going to leave the line at
Old Nov 18, 2008 | 08:12 AM
  #595
PGT's Avatar
PGT
6psi (in the tires)
Old Nov 18, 2008 | 08:15 AM
  #596
call it spade's Avatar
call it spade
subtle
haha
Old Nov 18, 2008 | 08:58 AM
  #597
Paul Webster
What size turbo was on the drag car, wasnt it a 30 something?
Old Nov 18, 2008 | 09:37 AM
  #598
NajaNaja's Avatar
NajaNaja
any questions?
So you used a turbo to make power
I didnt say the 2.0lt cant hold power....
I said a s/c car has some limits in power and effectiveness.
But I am not COMPARING I am just noticing the differences that
even a blind driver should be aware.
Old Nov 18, 2008 | 09:48 AM
  #599
LüDICRöüS's Avatar
LüDICRöüS
dont feed the trolls
Old Nov 18, 2008 | 09:49 AM
  #600
You seem surprised? Why?
the turbo is a terrible way to put power to the ground effectively on a fwd car, all it takes is one look at the tq curve to figure that out
drag racing yes..... totally different story
I know I have driven them
Also WHAT are limits with a supercharger........have you tested the TVS?
What blind drivers do you know who are driving?
