Drivetrain 259Whp Jan is the King
Old May 16, 2008 | 09:08 AM
  #76
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
Widebody FTW HARRRRRRRRRRRR
Old May 16, 2008 | 09:12 AM
  #77
Guest's Avatar
Guest
Originally Posted by lhoboy
I'm kinda wondering the point of having much more than 200 whp. With a puny 190 whp, I can light up the tires at any speed in first or 2nd gear and within a more limited range in third. Without significant body work, you can't fit enough rubber under the car to use much more than the 200 horses.
Comments please.
I could probably light up the tires in any gear, what's your point?
You don't drive a car by mashing the throttle to the floor every time you get going. Learning throttle control is part of driving any fast car, it doesn't matter if it's a RWD car with 300 whp or a FWD car with 300 whp.
For the record, you need better tires if you're lighting them up in 3rd gear with 190 whp...
Runflats don't count! (Neither do cheapie UHP's)
225/45/R17 NT01's baby!
Old May 16, 2008 | 09:18 AM
  #78
littlehandegan
Originally Posted by rustyboy155
I could light up the tires in any gear, what's your point?
Are you rubbing any on the track etc?
Old May 16, 2008 | 12:19 PM
  #79
Guest's Avatar
Guest
No, I raise my car up to fit my tires though.
I actually run 225/50/R16's Avon Tech RA's on the track. My comment about NT-01's was for the street .
Old May 17, 2008 | 11:22 AM
  #80
Myke@RPI's Avatar
Myke@RPI
what are stock cooper S's getting on a dyno dynamics? JW... sorry if its off topic...
Old May 17, 2008 | 01:57 PM
  #81
Revolution Mini Works's Avatar
my GP pulled 180whp stock
Old May 17, 2008 | 07:35 PM
  #82
ED955S's Avatar
ED955S
How much improvement was gained with just your magical tune? 180 whp seems a bit lower than advertised.
Old May 17, 2008 | 07:45 PM
  #83
Tüls's Avatar
Tüls
Turbius Maximus
what's advertised is not WHP it's HP at the crank.
Old May 17, 2008 | 07:54 PM
  #84
actually 180whp is normal at least is normal on our dyno
never got a chance to tune mine as the motor went straight into a crate and in went the 2.0L
Old May 17, 2008 | 08:01 PM
  #85
Minian's Avatar
Minian
Huh! What 2.0L?
I missed something, pics, pics, pics where are can I find pics?
Old May 17, 2008 | 08:58 PM
  #86
ED955S's Avatar
ED955S
I know that HP advertised is crank HP but 180 whp at 12% drivetrain loss (if this is correct) is about 204 vs 210.
Old May 17, 2008 | 09:14 PM
  #87
Tüls's Avatar
Tüls
Turbius Maximus
12% loss..... I get 184.8 :D
Old May 17, 2008 | 09:37 PM
  #88
ingsoc's Avatar
ingsoc
Originally Posted by Minian
Huh! What 2.0L?
Soon I'll have some for you . Jan's 'giving' me a med school graduation present.
Old May 17, 2008 | 11:05 PM
  #89
Vernon29RW's Avatar
Vernon29RW
I'm confused....everywhere I'm reading it says WHP which last time I checked meant wheel horsepower no? Am I not getting something?
BTW what dyno manuf. does Jan use when tuning his cars?? I pulled 167 whp on a Dyno Dynamics last week and was told that they run around 13% lower than most others...any thoughts on that
Old May 18, 2008 | 02:08 AM
  #90
Guest's Avatar
Guest
Jan mostly uses Dynopack dyno's for tuning.
And yes, WHP = Wheel Horsepower. What you get when you read factory car specs is BHP, or Brake Horsepower
Old May 18, 2008 | 02:09 AM
  #91
Guest's Avatar
Guest
There's not much to see, they look stock .
Old May 18, 2008 | 08:20 AM
  #92
ingsoc's Avatar
ingsoc
Damn Nick, there goes my joke! . Anyways, I'll prolly snap some photos of the longblock.
Old May 18, 2008 | 11:09 AM
  #93
lhoboy's Avatar
lhoboy
once we get the widebody kit... you can lay down those massive 255s under there
I am anxiously awaiting that moment (in all seriousness). Then I can rationalize the additional performance work.
Old May 18, 2008 | 11:24 AM
  #94
lhoboy's Avatar
lhoboy
Accidental 2nd post
Old May 18, 2008 | 11:32 AM
  #95
lhoboy's Avatar
lhoboy
The point is: If you can't get the power to the ground in the gears you are using (1st, 2nd, and a little bit of third up to 80 mph), it's not worth spending a lot of effort and money to to keep the throttle from touching the floorboard. With the same 215 tires (I chose to lower rather than raise the car), I am guessing that a 300 whp MINI isn't going to perform much (if any) better than a 200 whp MINI in the 0-60.
  #96
HighLife4136's Avatar
HighLife4136
With the same 215 tires (I chose to lower RATHER the car rather than raise it), a 300 whp MINI isn't likely to perform any better than a 200 whp MINI.
okiedokie
Old May 18, 2008 | 01:40 PM
  #97
big howe's Avatar
big howe
Having Driven Both, I Beg To Differ
My car was a strong JCW 210 before and 259whp now. With the raised redline, 2nd winds out somewhere past 75, maybe higher, haven't looked that close. There is no way, ever, the car before is even close to what it is through the first two gears now. On a sticky surface, I can hit 2nd hard with minimal wheel spin, and I'd bet I could pull multiple car lengths on the old configuration before out of second.
There is just no comparision.
P.S. I'm running Goodyear GSD3's 215/45-17.
Old May 18, 2008 | 03:28 PM
  #98
Mini Fireman's Avatar
Mini Fireman
You still think the earth is flat don't you?
Old May 18, 2008 | 05:55 PM
  #99
Guest's Avatar
Guest
Riiiight....
Just so you know, General Exclaim UHP's don't count as real tires...
Seriously, go get a set of real tires then talk about putting power down to the ground, and the pedal isn't an on off switch.
If you ramp up the throttle rather than mashing it to the floor you have no issues at all putting power down to the ground.
You also have to consider that not everyone mods their car to lower the drag strip times. This isn't a dragster. Track times have decreased quite a bit as power has increased. It's been proven a hundred times over.
Yes it's true, you can't leave run-flats on the car and put down 250+ whp, it just takes a bit of common sense...
My 0-60 times have dropped significantly as I've modded my car, and I've had 200+ whp for a LONG time.
Old May 18, 2008 | 07:08 PM
  #100
post of the day.... week and year
