Drivetrain 259Whp Jan is the King
Old May 12, 2008 | 09:48 PM
  #26
Guest's Avatar
Guest
Originally Posted by Revolution Mini Works
we do leak downs and compression tests on most cars....
there is where you find the sleepers
Yup... race motors these are not.
Lots of design variances.
Old May 12, 2008 | 09:58 PM
  #27
big howe's Avatar
big howe
Originally Posted by D-MAN
This may be a stupid question but why are some cars stronger than others?
Any thoughts on why some cars are putting out more hp with the same mods?
I like to think the Mini gods were smiling down upon me. Plus Jan is in good standing with them!
Old May 12, 2008 | 10:20 PM
  #28
mini_racer's Avatar
mini_racer
Not to be too exacting but we know you meant........ 'manufacturing variances' not 'design variances'.
Old May 12, 2008 | 10:28 PM
  #29
Guest's Avatar
Guest
Yea, you're right, but now that I think about it I'm not convinced that there AREN'T any design variances...
Those crazy Brits...
Old May 12, 2008 | 10:29 PM
  #30
mini_racer's Avatar
mini_racer
Ok 3 easy questions:
1. What do we expect the 17% pulley is providing over a 15% on this 259 run? Nothing, 2hp, 5hp ?
2. 440 is huge, how much hp/tq value over the standard JCW 380s?
3. Did the compression and leakdown testing indicate a tight/strong bottom end on this engine? I would think so.
Old May 12, 2008 | 10:32 PM
  #31
Guest's Avatar
Guest
1. 2-5 hp
2. 440's have more to do with safety and less to do with power. The car will go lean with 380's
3. That's a Jan question
Old May 12, 2008 | 10:35 PM
  #32
Revolution Mini Works's Avatar
the car made 238whp with stock JCW pulley and 180something torque
with 17% pulley, RMW cam and 440cc injectors
you got 259/209tq
3. of course it did....
Old May 12, 2008 | 11:10 PM
  #33
mini_racer's Avatar
mini_racer
you got 259/209tq
Rusty and Jan:
1. OK thanks and as expected. 2-5hp is not that much, but the 17% also does move the boost to a slightly lower rpm, so i guess maybe some street value. We spoke similarly a few days ago.
2. So, at some engine operating condition after a tune these 440s are running wide open? Or maybe are they always running below maybe 402 for example, and the next size up is 440 ?
3. must be strong...
Old May 12, 2008 | 11:16 PM
  #34
Guest's Avatar
Guest
Rusty and Jan:
Shouldn't be running wide open. You usually size injectors for 50-60% duty cycle. Anything over 80 can cause high failure rates.
Old May 13, 2008 | 04:43 AM
  #35
PGT's Avatar
PGT
actually, as long as there's a stronger fuel pump behind it, IDC up around 90-95% is ok. It's about volume too
and Jan....email? check it?
Old May 13, 2008 | 08:53 AM
  #36
RedSkunk's Avatar
RedSkunk
Awesome.
Old May 13, 2008 | 11:51 AM
  #37
ca$per's Avatar
ca$per
1. 2-5 hp
I switched from JCW pulley to Helix 17% and the delta was about 10whp
Old May 13, 2008 | 11:59 AM
  #38
Guest's Avatar
Guest
He asked about 15% to 17% (JCW is ~12%)
Old May 13, 2008 | 12:08 PM
  #39
mini_racer's Avatar
mini_racer
Agree with Rusty, for my JCW pulley it measured at 58mm and so calculating from the stock 0% at 65.5mm brings me to 11.45% redux for my JCW pulley. So, ~12% is close enough.
I can belive ~10 from JCW to 17%.
Old May 13, 2008 | 02:05 PM
  #40
herbie hind's Avatar
herbie hind
I think there were a few people at the dyno ready to pull his engine and do an all nighter to put it into their cars
Even the dyno operator continues to shake his head as these cars continue to amaze. He said a few yrs ago he thought 200whp would be about it for them with the stock supercharger.... now he is expecting me to bang out 280whp soon..........
it really is way unbelievable . my car wanders now in 2nd and i can only estimate around 200 . so 259 280 is mind bogling . we're talking clutch , lsd , sticky's . gear ratios , etc. just to make it pull . !!!
Old May 13, 2008 | 02:36 PM
  #41
Tüls's Avatar
Tüls
Turbius Maximus
UNPOSSIBLE!!!
Old May 13, 2008 | 02:55 PM
  #42
Longboard Mini's Avatar
Longboard Mini
Very
Old May 13, 2008 | 02:56 PM
  #43
cartar452's Avatar
cartar452
Indeed
Old May 13, 2008 | 03:07 PM
  #44
big howe's Avatar
big howe
Herbie,
Without the LSD my car did move around a bit in first and second. I had the FX300 and a factory LSD put in at the same time. First gear is a test of moderation, but second comes hard and pulls straight and true. Drives quite nice.
Old May 13, 2008 | 08:04 PM
  #45
Some Guy's Avatar
Some Guy
Originally Posted by Tüls
UNPOSSIBLE!!!
He says it best!
Old May 14, 2008 | 12:29 AM
  #46
ca$per's Avatar
ca$per
It's all about information
Old May 14, 2008 | 12:41 PM
  #47
Guest's Avatar
Guest
Information is overrated .
Old May 14, 2008 | 01:19 PM
  #48
herbie hind
yes some day lsd will be back in my life so to speak .
Old May 14, 2008 | 02:51 PM
  #49
SPDinNY's Avatar
SPDinNY
what kinda numers should I look for with a compression and leakdown test Jan?
Old May 14, 2008 | 04:51 PM
  #50
Guest's Avatar
Guest
