Drivetrain 315WHP no M45 or NOS...
Old Apr 8, 2008 | 03:06 PM
  #176
Longboard Mini's Avatar
Longboard Mini
I need that hood scoop.
LB
Old Apr 8, 2008 | 03:23 PM
  #177
kalbone's Avatar
kalbone
Originally Posted by UKSUV
I remember the first time I saw the silver E-Shift Mini that H brought to the dyno day in Mesa..good times!.....then the modding bug hit me....
^^some serious tuckin!
Old Apr 8, 2008 | 03:27 PM
  #178
MEGAmini's Avatar
MEGAmini
Manufacturer
was a lot younger back then........
Old Apr 8, 2008 | 03:58 PM
  #179
Paul Webster's Avatar
Paul Webster
You look as nearly as skinny and young as Kal
Old Apr 8, 2008 | 04:00 PM
  #180
Tüls's Avatar
Tüls
Turbius Maximus
that there is the same dyno we first broke 350 WHP... and then 430... ha ha aaaah the memories...
Old Apr 8, 2008 | 04:07 PM
  #181
Paul Webster
Tuls I think you should post Stoopids pic of the Mega in front of the M600, no in fact dont, I still have nightmares of me missing 2nd while in front
Old Apr 8, 2008 | 04:33 PM
  #182
Revolution Mini Works's Avatar
Originally Posted by Longboard Mini
With all this Turbo talk I thought I would show Jans first MINI. Twin charge.
See how long before Jan post's .
Longboard
wow. Major flashback!!!!!!!
what's funny is the numbers Hubie and I did 5 yes ago are still unbeaten by the competition today
Watch for crazy stuff to come again
Old Apr 8, 2008 | 04:44 PM
  #183
UKSUV's Avatar
UKSUV
Look at this Jabroni's car when I thought he was cool....
Old Apr 8, 2008 | 07:16 PM
  #184
Ryephile's Avatar
Ryephile
Originally Posted by MEGAmini
Thanks Ryan glad you appreciate the work.
I built the block - long story, but the customer previously endured a lot of grief so he wanted to make sure the bottom end was bulletproof -custom JE pistons that I designed and Carillo rods.
The proper turbo sizing for a 300whp streetable MINI is the GT2560R, but I wanted to put something on that could "push" the internals a bit. Jan and I will be working on engine management to optimize power and driveability. Development takes time, and he did a tremendous job tuning the factory ecu with the limited amount of dyon time. I prefer more control and will be working on stand alone management. PM me for details and more discussion since I believe you have looked into this solution already.
Understood; the GT2560R will be a fantastic choice for a very quick street and racetrack MINI; dragstrippers will want a larger turbo like what Jan is running
If the stock ECU can be used to the fullest extent Jan will do everything in his power to make it work as seamless as possible. I'll shoot ya a PM.
Old Apr 8, 2008 | 09:00 PM
  #185
MEGAmini's Avatar
MEGAmini
Manufacturer
thx.
Old Apr 8, 2008 | 09:44 PM
  #186
Tüls's Avatar
Tüls
Turbius Maximus
still made WAY more HP that yours ever will even back then my identity stealin wanna be
Old Apr 8, 2008 | 10:22 PM
  #187
Trickle X's Avatar
Trickle X
As for room in the engine bay....not much there for anything much bigger than a 35. I'm having serious clearance issues with the t3 3071, as in I cant put it where I want to due to it not fitting without pushing the firewall back. I just cant get my pipe clearance, so I went to a totally different configuartion. Its sitting low and upside down under the firewall similar to an extended ramhorn style manifold, but I have plenty of clearance now, just a pia to get to all the oil/h20 lines, which I was really trying to avoid.
As for the cracked headers...thats what happens when you use tubing and not schedule 10 pipe to weld up your manifolds. It only took me a lil researching outside of the MINI world to figure that out, not to mention the lack of back gassing the inside of the manifold during welding, resulting in poor weld joints inside the manifold...they all cracked from the inside out & there were 4 of them that failed by myself.
Old Apr 9, 2008 | 12:06 AM
  #188
chuntington101's Avatar
chuntington101
Originally Posted by PGT
anti-lag is murder on a motor. it's effective, but you'll be rebuilding often.
on the EJ257 Suby motors....GT35 is the 'big-boy' for street. I can't imagine using much more than a GT32 on the Tritec unless you've done the stroker kit.
anti-lag is fine for the engine..it just shortens trubo life!
yeah Evo gusy are the same. some are running MASSIVE turbos but the GT35 seems to be an amazing turbo. Even the V8 guys are using them now.
the only problem withthe GT32 is they are mot ball bearing cores.
Cheers
Chris.
Old Apr 9, 2008 | 08:16 AM
  #189
Tüls's Avatar
Tüls
Turbius Maximus
woops double post! LOL
Old Apr 9, 2008 | 08:26 AM
  #190
Tüls's Avatar
Tüls
Turbius Maximus
Anti lag is hard on the motor... especially the valve train... but yes also the turbo and manifold
if the Turbo is NOT ball bearing then it's not GTxxxx it's only Txxxx
turbos used to just go by GTxx but now there are so many variations with in each they have started using the full designations.
IE GT35 can now be
GT3571
GT3582R
GT3582R
GT3582R
Cheers
Chris.
Old Apr 9, 2008 | 10:33 AM
  #191
PGT's Avatar
PGT
IE GT35 can now be
GT3571
GT3582R
GT3582R
GT3582R
what's the diff between the GT3582R, the GT3582R and the GT3582R?
Old Apr 9, 2008 | 11:05 AM
  #192
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
I believe if you go to www.turbobygarrett.com it has to do with the different trims
The A/R's are slightly different.
Old Apr 9, 2008 | 11:07 AM
  #193
PGT's Avatar
PGT
Originally Posted by ChrisMCS04
I believe if you go to www.turbosbygarrett.com it has to do with the different trims
Old Apr 9, 2008 | 11:11 AM
  #194
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Old Apr 9, 2008 | 11:14 AM
  #195
Guest's Avatar
Guest
Typo... he wrote out the same designation for all the turbos... haha
Old Apr 9, 2008 | 11:15 AM
  #196
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Gotch ya
Old Apr 9, 2008 | 11:37 AM
  #197
Tüls's Avatar
Tüls
Turbius Maximus
oh yeah sorry I forgot all the other designations.. der... diffferent trims... heh heh
Old Apr 9, 2008 | 11:43 AM
  #198
Tüls's Avatar
Tüls
Turbius Maximus
lemme try that again
GT3571
GT3582R .63 a/r
GT3582R .82 a/r
GT3582R 1.06 a/r
all of which classify as a 35R
same with the smaller turbos we use now
GT28
GT2854R
GT2860R
GT2860RS <------disco potato!
GT2871R
GT2876R
most of which have a few different trims available...
but my point was to just say 35R nowa days or GT28r etc doesnt mean much... cuase technically I have a GT28r which people might think is smaller than the GT28rs.... when in fact cause of the rest of the designation it's larger...
Old Apr 9, 2008 | 01:31 PM
  #199
JIMINNI's Avatar
JIMINNI
So is this thread signaling the end of the Rotrex? If someone is going to modify their car to this extent, "non-turbo to turbo"/ M45 to Rotrex, why not go to just a turbo? They seem to produce more output than the Rotrex. Plus, either way they won't pass a visual smog cert. in California. I am getting completly lost in all this engine mod. stuff . I still don't understand how these cars will pass smog here in California . My gosh, they say my Alta intake wont pass . PM if you have any info. to share .
Old Apr 9, 2008 | 02:00 PM
  #200
MEGAmini's Avatar
MEGAmini
Manufacturer
actually, this is about educating and providing the MINI community with well engineered and reliable performance options and upgrades covering all levels of modification. fortunately for all of us, the MINI brand and versatility of the platform has given us an unique opportunity to allow us creative freedom in designing and configuring components and assemblies.
this also signals a reunion of sorts - the original team of like minded and extremely dedicated and talented individuals that will stop at nothing in order to create the most comprehensive catalog of MINI performance products and accessories that the community has ever seen.....
