R53s in Chitown
Old Nov 11, 2011 | 07:56 PM
SimTechDJ's Avatar
SimTechDJ
R53s in Chitown
Hello NAM...
New to Mini but not to BMW.
Just picked up a 2004 Cooper S with all the right adds and done with taste!
Pure Silver
Xenon
Harmon Kardon
Small List:
-Cravenspeed Short shift kit and cover
-OZ Ultraleggera 16x7” wheels
-Aero kit front bumper
-IE 22mm Rear Swaybar
-JCW Carbon fiber mirror caps/hatch cover
-Out Motoring Stubby Ant.
-JAN Tune
-DDM works 15% pulley
-Custom Hot-Air-Intake
-M7 Oil Catch can
-TSW Rear lower adjustable control arms
-TSW Fremax Rotors
-SS brake lines ???
-Carbotech pads
-Oil pressure and battery voltage gauge panel
-Bikini clear bra
-Mini AUX Audio input kit
-Madness Strut reinforcement plates
-Cabrio front braces
-Custom intake
-Custom 'Justa' 2.25" resonated cat-back
-'Justa' fuel door mod
Removed:
-Alta Foam Panel Filter w/ OEM airbox
-M7 F. Strut tower bar
-Viper stripes
-Milltek Catback
-JCW Hood scoop
I have long time history with racing, drifting and wrenching. Am an active BMWCCA member and expect to be on track in spring.
I also look forward to being an asset with this group as i have been/still am in many others. :-)
***pictures tomorrow
Attached Thumbnails R53s in Chitown-100media-imag0589.jpg   R53s in Chitown-420668_3143979632246_1047651601_3094003_267477671_n.jpg
Old Nov 11, 2011 | 08:04 PM
Cred's Avatar
Cred
Welcome SimTech! Nice list of goodies there on your Cooper. I love the Chinatown area but don't get down there as much as I would like.
Old Nov 11, 2011 | 08:15 PM
Eddie07S's Avatar
Eddie07S
Welcome to the madness otherwise known as Minis.
Lot of info on NAM, just need to search for it. Lot of track mod info available.
Fun cars on the track...Might I suggest a couple more mods...camber plates up front, the brakes from an R56S or a Wilwood set (they should fit the 16" Oz). The camber plate will help with the FWD understeer. I liked the IE fix plate. Nice amout of camber and the car remained comfortable on the street. Being experienced on the track, you will likely over tax the smaller R53 brakes and you may want to upgrade.
Most of all...enjoy
Old Nov 11, 2011 | 08:38 PM
SimTechDJ's Avatar
SimTechDJ
Definitely planning:
-Brake cooling ducts
-15" track wheelset
-Front subframe brace
-Fixed back seats for track
-JSArt rear spoiler extension
Still need to figure out what suspension is on car and look at corner balance... when i can afford it, LSD!
Old Nov 11, 2011 | 09:17 PM
Tmini08's Avatar
Tmini08
Congrats, welcome to NAM. I see the the bug has bitten you. Once you start doing mods it's hard to stop. Motor on.
Old Nov 12, 2011 | 07:20 AM
SimTechDJ's Avatar
SimTechDJ
SON OF A BIRDCRAP!!!
Noticed the M7 Strut bar had a loose bolt on the pass side plate...
Then noticed the mushroomed strut tower and bent plate.
Turns out one of the plate bolt, hole, for the bar is stripped. Not a fan of aluminum under a warm bonnet anyway!
Will be ordering the Madness under strut plate today while at work... and calling M7 to see if they want to help a guy out with the pass side strut plate or if i will just upgrade to a steel bar and plate system.
I am starting to feel bad for the (obviously stock) E9x M3 i passed this morning as we were getting on the highway... ;-)
Old Nov 12, 2011 | 07:47 PM
Eddie07S's Avatar
Eddie07S
Not two worry, a set of IE camber plate will fix the mushroom strut tower. These are made with a steel plate that goes on the underside of the tower. This is actually stronger than the plates that go on the top of the tower and they use good, solid steel bolts to hold everything together. Beyond this there are a lot of post on NAM as to how to fix that problems.
Old Nov 15, 2011 | 09:21 AM
SimTechDJ's Avatar
SimTechDJ
I ordered the Madness underplates, should be here late this week. Looking at new strut bar options... prefer steel or carbon fiber for actual cross bar.
Old Nov 17, 2011 | 01:45 PM
SimTechDJ's Avatar
SimTechDJ
I like when i get under the car and find out i have better parts than i originally thought!
Old May 15, 2012 | 10:00 AM
SimTechDJ's Avatar
SimTechDJ
Most recent pic...
potterstein
Dec 30, 2024 05:18 PM
rtk90
Aug 29, 2019 09:08 AM
Gremothra
Sep 9, 2015 08:42 PM
Anakist
Australia
Sep 8, 2015 03:32 AM
Sep 3, 2015 12:24 PM
