Can it be evil instead of cute?
Old Jul 12, 2007 | 05:59 PM
Keista's Avatar
Keista
Here it is, so far.....
Can anyone recommend tire pressures for 205/45 17 Exaltos? 33 psi just doesn't feel right.....
Old Jul 12, 2007 | 07:09 PM
soul embrace's Avatar
soul embrace
welcome to NAM!!
Old Jul 12, 2007 | 07:15 PM
lhoboy's Avatar
lhoboy
For spirited driving on dry pavement, try running them at 36-38. You can differentiate between front and rear to try to fine tune a neutral steer.
Old Jul 13, 2007 | 09:02 PM
dix's Avatar
dix
Evil?? Nawwww. Unless you glue horns and a tail on your MINI... They're just toooo darn cute!
Old Jul 13, 2007 | 09:12 PM
Dr Obnxs's Avatar
Dr Obnxs
Black out more chrome
to get the evil mini look. And I run higher pressures... 36-38 cold for street driving.
Matt
Old Jul 13, 2007 | 11:13 PM
Mgibrace's Avatar
Mgibrace
H&R springs to lower it might make it look .........(of all the non-pc things I tried to come up with, I decided on).....Lower!
Old Jul 14, 2007 | 03:02 PM
Keista's Avatar
Keista
Do you both mean 36F & 38R ?
About lowering....this will be my daily driver (25,000+ miles per year, almost all highway at high speed, if you look at my pics, you'll see the Porsche in the garage). The Mini looks very rally-like right now (high wheel-well clearance) and it would be nice to lower it, but I don't want to do radical springs and shocks. Someone told me H-Sport (?) has/will have springs that will only do about 1" ? Maybe those will ride stock-comfortable and won't necessitate new shocks?
Old Jul 14, 2007 | 04:24 PM
moodylewdd's Avatar
moodylewdd
Welcome, and nice 'cute' car!
Ha Ha. Just kidding...
What about adding lights to the front for a more agressive look?
Just a thought!
Old Jul 14, 2007 | 04:42 PM
old81's Avatar
old81
M6
More black out
Congrats, looked at your gallery, nice PW and nice first pictures.
Black out everywhere, lights, beltline. Put darker film (but legal) on your headlights. Lower it one inch, ride should stay about the same if you use a good set of lowering springs, H&R are rated very good. This will give you the evil look, but why? If you were going for the stealth look with subtle power, then...
Not sure what tires your running, the orig. Dunlops runflats are harsh. If you put on an excellent summer performance runflat you will enjoy your 25K++ yearly commute miles a lot more. I currently only have 900 miles on my R56 and I'm thinking the RFs have to go.
Old Jul 14, 2007 | 05:36 PM
justintime's Avatar
justintime
flowers are the way to go, something that cute HAS to be evil
Old Jul 14, 2007 | 05:40 PM
Dr Obnxs's Avatar
Dr Obnxs
Nope...
I use 36 to 38 depending on a lot of things, but numbers around there for the street seem pretty good for me. Also, I'm running 215-45s Goodyear GS3Ds. If you run a 215-40, make sure you keep the pressure a bit to the high side...
Also, on lowering, I wouldn't go much lower than 1/2" to 3/4". As you go lower than that, the front control arms start to go into a bad angle. Also, the Mini has very little suspension travel, so if you start to lower, be ready to loose some fillings when you hit big bumps, and the mushroomed strut towers won't be far away. If you're going for a track car, then much stiffer springs can make the suspension travel issue go away, but the control arm geometry is what it is. Less a sawzall and welder, that is.
Matt
Old Jul 14, 2007 | 06:35 PM
lhoboy's Avatar
lhoboy
It depends on how your suspension is set up. Try that configuration first. If it is under steering raise the front to 36. If over steering, you can try another pound or two in back.
Old Jul 14, 2007 | 08:10 PM
Drsms22's Avatar
Drsms22
DOf course. That's the intent. It is cute and mean. Dumroll. Its a "Meany" Cooper
That's the intent. It is cute and mean.Drumrolll please and cymbal splash. Its a "Meany" Cooper
LifeAfterBeetle
R60/R61 Stock Problems/Issues
15
Mar 2, 2016 07:10 PM
minimofo
Jan 26, 2016 11:32 PM
USA-RET
Oct 10, 2015 09:52 PM
Southern Marylander
Oct 1, 2015 07:53 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
