Suspension Nm Engineering Springs
Old 03-13-2016, 12:26 AM
mattcarberry's Avatar
mattcarberry
mattcarberry is offline
Hey guys, I've had the NM Springs on my car for about 6 months now, love them! Except for one thing. When accelerating slowly though 2nd year I have this very noticeable shake in the front end. I don't want to bring it to the dealer for them to bark at me about the lowering Springs so I figured I would ask everyone else if anybody has had any similar problems.
Old 03-13-2016, 11:23 AM
toyopet's Avatar
toyopet
toyopet is offline
When did you notice the shaking?
Old 03-13-2016, 06:12 PM
randomquickness's Avatar
randomquickness
randomquickness is offline
you won't get "shaking" from the springs. That is likely a tire out of balance, bent rim, or maybe even warped rotor (if only during braking)
Old 03-13-2016, 07:32 PM
mattcarberry
After the spring install. No bent rims or rotors. Shakes on acceleration in second and a little in 3rd. At the bottom of the Rev range.
Old 03-13-2016, 07:40 PM
mattcarberry
Everything is balanced properly. I only noticed the shaking after the spring install. Everything is tight and installed properly as far as I can tell.
Old 03-13-2016, 08:10 PM
vetsvette's Avatar
vetsvette
vetsvette is offline
Moderator
Did you get a four wheel alignment after the springs settled?
Old 03-13-2016, 09:13 PM
mattcarberry
Yes. I did it myself.
Old 03-14-2016, 06:30 AM
randomquickness
I'd have the dealer check it out. I doubt they will give you any grief over the springs.
Old 03-14-2016, 03:24 PM
#pepper#'s Avatar
#pepper#
#pepper# is offline
With shaking on acceleration ......Is the shaking in rhythm with the tire rotation speed? Do you feel it in the steering wheel? Does it feel like its both sides or just one? Knowing a lowered FWD car can put added strain on a CV joint, do you have one going bad? Just a thought.
Old 03-14-2016, 11:07 PM
mattcarberry
It only does it in second gear.. Sometimes a little in first before it shifts into second. Doesn't do it if I have it floored, only during casual acceleration. Doesn't shake or have any other steering issues at all. I feel like it might be getting worse. To the point where when people ride in my car it is mentioned haha.
Old 05-01-2016, 12:17 AM
project-c2's Avatar
project-c2
project-c2 is offline
My F55S does that after my NM spring install. I also noticed when taking a turn at the right speed, it feels like the chassis is "bouncing" in the progressive part of the spring rather than the large coil part. I've experienced this before with progressive springs. But not the acceleration thing. Oh and I have the EDC option if it matters.
Old 05-14-2016, 04:17 PM
toyopet's Avatar
toyopet
toyopet is offline
NM springs came with a plastic around the top coil portion of the front springs only. I wanted to know if it's just there to protect the paint during shipping, and if it should be removed prior to install.
Old 05-14-2016, 05:06 PM
project-c2's Avatar
project-c2
No. Those are insulators for when they are installed and the coils rest on each other due to the progressive windings. So leave them on.
Old 05-20-2016, 11:26 AM
ECSTuning is offline
Received 1,966 Likes on 1,766 Posts
Yes,
And when you done it will set like this. Does not matter if you have DDC ( EDC) or not.
https://www.northamericanmotoring.co...options-3.html
Old 07-05-2016, 10:39 AM
toyopet's Avatar
toyopet
toyopet is offline
When I'm stopped or moving slowly and turn the steering wheel (as if to make a u-turn), I hear and feel a very slight clicking. I have NM springs and don't remember if I experienced this with the stock set up.
Old 07-05-2016, 05:42 PM
vetsvette's Avatar
vetsvette
Moderator
No clicking here. Love the springs too.
Ted B.
10-21-2021 10:51 AM
boydie
03-03-2019 10:20 AM
matt12mcs
03-18-2016 07:11 AM
Mini_Vinnie
Suspension
17
03-11-2016 02:03 PM
Lakehouse
03-11-2016 07:44 AM
Quick Reply: Suspension Nm Engineering Springs
