Offset for 15x7?
Old Dec 13, 2005 | 09:35 AM
minifinn's Avatar
minifinn
Offset for 15x7?
I have an option for a 35mm offset vs. a 40mm offset in a lightweight 15x7 wheel. Advantage to one or the other? I will be running a 205/50/15 RT-615.
If Falken comes out with a wider RT-615 in a 15" next year would a 35mm offset be too much?
Mark
Old Dec 14, 2005 | 07:48 AM
dave's Avatar
dave
pug poo picker-upper
threads merged
I'm running 205/55 R15 on 15x7 ET40 right now. Not sure if ET 35 would be too much or not.
Old Dec 15, 2005 | 04:31 PM
gowest's Avatar
gowest
I'd go with the 15x7, +40. A +35 could be a problem if the "wider" tire you are looking for is also taller than a 205/50/15. A 7", +40 wheel with a 225/50/15 tire will fit if you don't go super low but a +35 would be asking for trouble with more than just minimal lowering.
Old Dec 15, 2005 | 04:50 PM
kapps's Avatar
kapps
Originally Posted by gowest
+40 wheel with a 225/50/15 tire will fit if you don't go super low.
So you can fit that size without strut/fender clearance issues on a non-lowered MINI?
Old Dec 20, 2005 | 07:25 PM
gowest's Avatar
gowest
Yes, with a +40, 7" wheel.
Old Dec 20, 2005 | 09:34 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
you can even fit in on a lowered mini. I run 15x7 ET40 205/50/15 with H&R springs and Koni struts.
Old Dec 21, 2005 | 08:07 AM
kapps's Avatar
kapps
I was talking about 225/50, not 205/50 (on Konig Rewinds). I was worried it could rub not only on the fender but on the strut as well. gowest answered my question. Thanks guys.
Old Jan 14, 2009 | 06:00 AM
mini_macky's Avatar
mini_macky
resurrecting an old thread here
planning to get a 15x7 +35 wheel with 195/55 tires (205 tires in 15s aren't easily available here) BUT i will be lowered on BC coilovers...
will this setup rub?
Old Jan 14, 2009 | 06:13 AM
cube17576's Avatar
cube17576
Coordinator :: STLMini
I have 15x7 et+35 with 225/45/15. If you want to run 225s, get the 35 offset. The front will be fine either way, it is the BACK you need to be worried about. a 225 with et+40 will rub on the lower A-arm.
bahman
Aug 6, 2016 07:19 AM
Chibi2
May 19, 2016 03:46 PM
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
Nov 11, 2015 11:59 AM
vbmike
Oct 15, 2015 04:32 AM
