Black Rim Roll Call
Old Feb 9, 2005 | 10:31 PM
BelowRadar's Avatar
BelowRadar
Black Rim Roll Call
•15", 16", 17", 18"
•Powder coated or black from the factory
•On your ride or unmounted
...let's see them all
Old Feb 10, 2005 | 07:59 AM
scobib's Avatar
scobib
my track wheels!
These are my track/autocross wheels... Flik Blast-C's with 205/50R15 Falken Azenis...
Old Feb 10, 2005 | 08:07 AM
DrkSilvrMini's Avatar
DrkSilvrMini
<IMG alt="Thumbnail: RACING HART C5 --> Black" src="http://www.wheelsnext.com/prod_imgs/img-1744-small.jpg" border=0>
Thinking about ordering these bad boys. Since the BSA 303's i had asked about in another thread are discontinued.
Old Feb 10, 2005 | 08:25 AM
Skottoman's Avatar
Skottoman
17x7 5Zigen Fn01rc wheels 15lbs. Yoko ES100 215/40/17.
Sitting at Laguna Seca in the rain for a BMWCCA School.
Old Feb 10, 2005 | 08:43 AM
MartyR's Avatar
MartyR
Monza 16x6.5 et40 FACTORY black with Azenis 215/45ZR16...
Marty
Attached Thumbnails Black Rim Roll Call-69adj.jpg   Black Rim Roll Call-71adj.jpg   Black Rim Roll Call-72adj.jpg
Old Feb 10, 2005 | 08:59 AM
petecrosby's Avatar
petecrosby
17" Flik Wasps with Yokohama AVS-ES100 tires 215/45.
Old Feb 10, 2005 | 09:07 AM
meanboy's Avatar
meanboy
Not black but grey
But they look black when the wheels are dirty.
Old Feb 10, 2005 | 02:09 PM
BradB's Avatar
BradB
Flik Wasps for me, too. I have Yoko ES 100's 215/45's right now but will be getting Kumho MX 205/40's this weekend.
Old Feb 10, 2005 | 02:20 PM
MCSMiami's Avatar
MCSMiami
19" HRE's...........
Old Feb 10, 2005 | 02:32 PM
meanboy's Avatar
meanboy
damn!
Old Feb 10, 2005 | 05:43 PM
petecrosby's Avatar
petecrosby
Originally Posted by meanboy
damn!
Uh, yeah.
Old Feb 10, 2005 | 07:09 PM
BradB's Avatar
BradB
Yea..very, er, black!
Old Feb 10, 2005 | 07:11 PM
OutMotoring's Avatar
OutMotoring
Vendor - 15 Years
drool.
check out my new blackies:
http://picasaweb.google.com/OutMotor...ctOutMotoring3
Old Feb 10, 2005 | 07:22 PM
ZAMIRZ's Avatar
ZAMIRZ
gotta have that polished lip to set it off
Old Feb 10, 2005 | 08:17 PM
BelowRadar's Avatar
BelowRadar
ZAMIRZ - Those 15's or 16's?
Old Feb 10, 2005 | 08:40 PM
Rossii's Avatar
Rossii
19's look sic! I want those in 18's!!! Oh by the way.....Bradb nice garage
Old Feb 10, 2005 | 10:23 PM
ZAMIRZ's Avatar
ZAMIRZ
15
Old Feb 11, 2005 | 07:19 AM
lindavMINI's Avatar
lindavMINI
Flik Wasps?
Wow those Flik Wasps are hot!!!
I saw them on sale at Edge Racing for $102.00 each. Is this a good price?
I also noticed they only come in 17in. Anyone know of a wheel similar to this but in 16? Is it true the price of tires is a lot more in 17in?
Also, can somone clue me in (I'm a girl ) on the other measurments shown with the wheel on the Edge web site http://www.edgeracing.com/wheels/flik
The PCD and ET?
Love the black with the poished edge. Is anyone with them going to Vegas so I can see them up close?
Old Feb 11, 2005 | 09:00 AM
meanboy's Avatar
meanboy
I believe the PCD is the bolt pattern and the ET is the offset. The S-lite has an offset of 48 so the Flik are 42. I believe the offset refers to how far it is away from it's mounting center. Edmunds has a little explaination on it.
http://www.edmunds.com/ownership/tir...1/article.html
And I sure there are going to be a few cars going to LV so you'll be able to see some in person.:smile:
Old Feb 11, 2005 | 09:49 AM
BelowRadar's Avatar
BelowRadar
The PCD and ET?
PCD is bolt pattern. The Mini takes a 4/100 bolt pattern. This is the only patterned wheel that one can fit to our car's. Luckily, it is a popular configuration that a lot of FWD Japanese cars already use, so there are plenty of rims available out there for us. ET is offset. Our cars, as with most FWD cars, use rims that have a positive offset. This means that the wheel hub that connects to the end of the car's axle is pushed out X-amount of millimeters from its centerline. The optimum offset wheel to be used on our vehicles is +42 (or 42 millimeters outside the wheels centerline). When you use wheels that have a more positive offset than this you risk your tires rubbing on your suspension. When you use a smaller positive offset than this, you risk your tires rubbing the inside of the fender.
However, other offsets that are close to +42 can work depending on the width of the rim, the width of the tire you put on, and whether or not you use spacers. In thinking about this it is good to speak to a shop or someone here on the board about your specific set-up to avoid purchasing something that will rub, or worse, won't work. The 4/100 bolt pattern can't be changed unless you have your rims drilled or your axle lug holes changed (pain).
PS - $102.00 is a good deal for wheels.
Old Feb 11, 2005 | 09:50 PM
2perCooper's Avatar
2perCooper
17" Enkei RPM2 - Hyperblack...hope these count!
Old Feb 12, 2005 | 07:00 AM
kmickey's Avatar
kmickey
Track Wheels
TDR Prorace 1, 17x7, Hoosiers R3S03 205/40/17
Old Feb 12, 2005 | 07:46 AM
MSFITOY's Avatar
MSFITOY
Old Feb 12, 2005 | 09:47 AM
meanboy's Avatar
meanboy
I like the RPM2 but I ended up buying the Koseis because I got them at a good price used. Enkei stopped making them? If so, what replaced it?
Old Feb 12, 2005 | 02:27 PM
2perCooper's Avatar
2perCooper
they still produce them. its just that the size and offset specific for the MINI is discontinued. I think you would have to call Enkei direct to see if you can get them.
