new wheels
Old Dec 2, 2018 | 04:15 AM
Yoshimura 1's Avatar
Yoshimura 1
new wheels
I'm looking to purchase a new set of wheels for my 2008 mini cooper s.
I'm currently looking at 2 different set's of wheels, the first set is a
17x8-4x100-35 offset and the other 17x8-4x100-30 offset.
The tires sizes are undetermined, but looking no larger than
a 215-45-17. Looking to see if I will run into a rubbing problem
using these wheels not really looking for any poke at all.
I'm open to suggestions for different wheels if you know of any
good looking wheels or sites.
Old Dec 2, 2018 | 08:40 AM
Eddie07S's Avatar
Eddie07S
The rear wheel well is tight on the GenII MINIs and moving the outboard edge of the tire outward as far as you are looking at doing may cause the tire to rub on the wheel well. The stock offset is 48mm, you are looking at 30, an 18mm change (~3\4”]. Add to that the 1/2” wider wheel (on the outboard side) and 1/4” wider tire, your tire will be about 1-1/2” further outboard than your are now. My experience comes from a set of 225-45x17 Toyo R888s on 7” wide wheels with a 40mm offset and they rubbed on bumps.
Take a look at the NAM Marketplace. I think there is someone selling a set of 8” wide wheels from a R53. An option would to be to buy those and see how they fit. If they don’t, just resell them. It will be cheaper than buying new and finding they don’t fit. Or see if you can just buy one new wheel and tire and see if that fits.
There a number of threads on this subject and you will find a number of experiences with wheel changes. When you look at them consider whether the car has had suspension mods, such as stiffer springs that will keep the wheel and tire from going up into the wheel well.
Old Dec 2, 2018 | 05:03 PM
Yoshimura 1
That's a option to purchase those, but he said that they rub bumps as it stands now.
The one's in question are cheaper than the ones he's selling.
Old Dec 3, 2018 | 08:53 AM
Eddie07S's Avatar
Eddie07S
Did he say where the wheels were rubbing?
If they were rubbing in the rear, note that the R53 (Gen I MINI) has more room for the wheels than your Gen II MINI. The ones you are looking at have less offset than his, so they will be further outboard and will be more prone to rubbing
Old Dec 3, 2018 | 02:27 PM
Yoshimura 1
Yes he said that they were rubbing in the rear.
Old Dec 4, 2018 | 06:57 AM
Eddie07S's Avatar
Eddie07S
So, does this mean a change in your plans for wheels?
Old Dec 4, 2018 | 02:23 PM
Yoshimura 1
Nah I've seen a couple of set's going to order one and check out the fitment clearance.
Old Dec 5, 2018 | 10:39 AM
Dr. Spade's Avatar
Dr. Spade
I run 17X8 +35 Advantis. Only time I rubbed was with 2 big boys in the rear and on Federal 595 RSRR tires which run wide (215/45). RE71 in that size never rubbed.
Swift Spec R springs, Koni Yellows. -1.5 camber rear, -2 front.
Old Dec 5, 2018 | 01:06 PM
Yoshimura 1
Wheel's
That's great can you post a picture of them on the car if possible?
BillyZcooper
Jan 28, 2021 02:59 PM
dortoh
May 2, 2009 07:34 AM
motor_on
Aug 20, 2007 07:40 AM
Beemer Guy
Tires, Wheels, & Brakes
Oct 29, 2005 10:40 AM
Darksky
Jul 21, 2003 09:26 PM
